Scratch Build – Complete Project Hexagon
Discussion in 'Project Logs' started by Gas_designs, 30 Dec 2016.
  1. Gas_designs
    Gas_designs Minimodder
    29 Sep 2014
    Hello guys, I want to present my 4th project in the field modding. :dremel:
    This new mod is just on building a Wall Mount, but that will not be fixed to the wall.
    I leave for now the imagination, a big screen 40"
    Special thanks to Bitspower, and Vincent and LiHan, Mayhems and Mod-One thank you immensely for support.
    Special thanks to Danilo Lettieri for his creations cnc
    Find her page here: :thumb:
    https://www.facebook.com/pg/creazioniDanilo/photos/
    Motherboard: Asrock Z270 Taichi
    Cpu: Intel i7 6700K
    Ram: Corsair Platinium Dominator 3000MHz DDR4 32GB
    Vga: EVGA GTX 1070 Founders Edition
    Ssd: Corsair Neutron Series XT 480GB
    Cable: Mod-On
    Wb Cpu: Bitspower CPU Block Summit EF (Intel) (Acrylic Top Version)
    Wb Vga: Bitspower Nvidia GTX 1080 Reference Acrylic V1
    Wb Hd: Bitspower S350 Acrylic Top With Clear Panel
    Pump: Alphacool VPP655 - single edition
    Top D5: Bitspower Dual D5 MOD TOP (Acrylic Version)
    Reseivor: Bitspower Water Tank Hexagon - Acrylic (Limited Edition)
    Tubing: Bitspower None Chamfer PETG Link Tube OD14MM-Length 500MM
    Fittings: Bitspower Black Sparkle Fitting
    Liquid: Mayhems
    Radiator: Bitspower Leviathan Xtreme 360 4xG1/4" Radiator
    Material for the realization*
    Wood - imitation leather - screws varies - glue.
  2. Vault-Tec
    30 Aug 2015
  3. Gas_designs
    29 Sep 2014
  4. Gas_designs
    29 Sep 2014
  5. Gas_designs
    29 Sep 2014
    Then finally after a long journey, It came the first material by Bitspower.
    => Stay tuned.
  6. Gas_designs
    29 Sep 2014
    Some pictures of Bitspower material. :clap: :clap: :clap:
  7. Gas_designs
    29 Sep 2014
    Start building the big pedestal, wood then hold up the entire mod. :dremel: :dremel: :dremel:
  8. Gas_designs
    29 Sep 2014
    Continuous with the step of gluing and screwing, the pedestal. :clap: :clap: :dremel:
  9. Gas_designs
    29 Sep 2014
    Continuous modification of the pedestal, slightly shortening the legs, and smoothing out all the angles, and adding other safety screws. :thumb:
    Then start with the central panel. :dremel:
  10. Gas_designs
    29 Sep 2014
    That afternoon I decided to begin to place the trays department, folding and cutting the rigid pipes. :thumb:
  11. Gas_designs
    29 Sep 2014
  12. Gas_designs
    29 Sep 2014
    Here we are after a week of fever. :duh:
    I started this afternoon to cut the parts I had traced.
  13. Gas_designs
    29 Sep 2014
    Some other image ... :thumb: :clap:
  14. Gas_designs
    29 Sep 2014
    Here we are with a new step. :dremel: :dremel:
    I adjusted and fixed at the rear of the 5 reservoir, set the pumps and made holes for the bulkhead, and bend the upper tubes of the radiator, with the use of the templates of Bitspower.
    Stay tune ..... :clap: :clap:
  15. Gas_designs
    29 Sep 2014
    This morning I went to finally withdraw the faux leather fabric :clap: :clap:
    He was missing the adhesive to glue it. :thumb:
  16. Gas_designs
    29 Sep 2014
    Thanks to Mayhems Solutions, for sending me their fantastic liquid. :clap: :clap: :clap:
  17. Gas_designs
    29 Sep 2014
    Before and after the first pass of epoxy resin spray, to harden around the panel, before pasting the skin. :thumb:
  18. Gas_designs
    29 Sep 2014
    I begin the step of bonding the fabric, with plenty of white glue, in several steps ..... :clap: :clap:
    ......... :thumb:
  19. Gas_designs
    29 Sep 2014
    And after a few days of drying glue you begin to reassemble everything..... :clap: :clap:
    And in the meantime came the new girl: Asrock Z270 Taichi :hip:
  20. Gas_designs
    29 Sep 2014
    ?wmode=opaque" frameborder="0" allowfullscreen>
