Case Mod - In Progress Project High-Res (Xmas update) Asus Xonar gets the treatment.
Discussion in 'Project Logs' started by Bradley8988, 14 Mar 2009.
  1. The boy 4rm oz
    10 Apr 2008
    Rad fits perfectly and the new power switch looks great.
  2. Bradley8988
    Bradley8988 New Member
    16 Jun 2008
    Update 1st May.
    Well some nice parts just arrived from ChilledPc. :)
    As the mobo im thinking of getting has multi colored slots and tbh they look **** on the blue and white mobo so got a set of slot protectors which should hide some of the nastiness.
    And will let the rest of the pics speak for themselves.
    The EK blocks iv used in the past come no where close to the finish of Koolance.
    Anyway now i got my braid its time to finish the PSU. :drool:
    Cheers.
  3. The boy 4rm oz
    10 Apr 2008
    Koolance has really stepped up a gear over the last few years. I would actually consider buying their blocks and equipment now, they look awesome lol.
  4. mansueto
    mansueto Too broke to mod
    31 Aug 2007
    bandwidth exceeded... cant see any pics :(
  5. Bradley8988
    16 Jun 2008
    Yah stupid photobucket. Will be sorted on the 7th and will hopefully have a update by then too. :)
  6. ry@n
    ry@n Well-Known Member
    31 Aug 2005
    WOW! that power bulge looks sweet! I like the look of the rotary elbow fittings on the rad.
    Is the text cut out on the Koolance block perspex? If so thats going to look ace with some UV fluid.
    Anyone know if those Lian Li radiator brackets will work with my CM Stacker?
  7. Bradley8988
    16 Jun 2008
    Update.2 1st may.
    My psu is basically fully braided bar a molex cable. This is nearly 40m of braid, 2m of heatshrink, 2 full rolls of insulation tape and alot of time and effort but its done finally....
    Cheers.
  8. Bradley8988
    16 Jun 2008
    Yah the text on the block is a little window into the fluid inside. I see no reason why the brackets wont work in any dvd bay set up :) Glad u like!
  9. Bradley8988
    16 Jun 2008
    Update 7th May.
    Got some parts from my new sponsors:
    Thanks Oggie for the P clips! will come in very very handy with cable management.
    Thanks again dude.
    And also thanks to PaulyD for a Thermochill PA120.3 shroud. Very very nice of you dude! Will be getting painted with the case!
    Oh and thanks for Webbo for showing me these nice fans :)
    And i know the fans are on the wrong side of the shroud but thats how i want em lol. :p
    Thanks lads!!!!!!
  10. disturbed13
    disturbed13 New Member
    28 Nov 2008
    who says?
    looks good btw
  11. Bradley8988
    16 Jun 2008
    Well the idea of the shroud is to lift the fans away from the fins of the rad so you dont get a dead spot where the middle of the fan would normally sit. Im basically still having the fans in the same place but encasing them in the shroud for looks more than anything. Once painted with the rest of the parts it should look good(hopefully).
  12. The boy 4rm oz
    10 Apr 2008
    The sleeving looks amazing, I love it. Those Enermax fans are really cool, they look great and perform well.
  13. Bradley8988
    16 Jun 2008
    Yah they should look sweet once shroud is white too. My hope is if i use them on the rad, PSU and exhaust fan they will basically circle the mobo and maybe light the case so i dont need cathodes? think it may work?
  14. The boy 4rm oz
    10 Apr 2008
    Well you have quite a few fans so it should give you a nice glow. I have 3x120mm and 1x80mm fans with blue LEDs in my case and I get a great glow, no CCFLs needed (except the UV ones I have).
  15. Bradley8988
    16 Jun 2008
    Hmmm well hopefully i get the same effect ;) Not sure if to use any Uv yet.
  16. Omen
    Omen New Member
    6 Jul 2008
    Nice m8.... very nice!
    Never thought of a white based rig before, never fancied it, but gotta admit :jawdrop:
    *Subscribed*
  17. Bradley8988
    16 Jun 2008
    nor me but i cant stand the chavtech 1200 looks of the stock p60 so all the boy racer had to go ;)
  18. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Great job so far! Will keep an eye on this one!
    Idea: what about colouring the fan wires all black or white, depending on overall colour scheme (or just desolder and replace with black/white ones)?
    Question: Are you sure you want the shroud white? I for one, think it looks great with the black/white contrast!! =D
  19. Bradley8988
    16 Jun 2008
    Well the case externals, PSU, rad, braiding, tubing, fans etc are all white with the internals powdercoated baby blue. The only black in the entire build is the plugs on my PSU cables, the mesh in the door and the stickers on those fans. I may cover those cables as you mentioned in white heatshrink or maybe sandwich some mesh between the fans and the shroud to hide it.
  20. Sonnenschein
    Sonnenschein New Member
    6 Mar 2008
    Very, very grat work!!!! I like especially the white sleeved cable.
    I´m looking forwart to some new pictures.
