Case Mod - In Progress Project High-Res (Xmas update) Asus Xonar gets the treatment.
Discussion in 'Project Logs' started by Bradley8988, 14 Mar 2009.
  1. stonedsurd
    11 Mar 2009
    That's a nice list - all great kit, but PLEASE, go with white powdercoat, not blue.
  2. Bradley8988
    Bradley8988 New Member
    16 Jun 2008
    The whole case outside is been painted white and with the mobo i have on the way the blue should match perfectly. Outside is totally white with baby blue inside with lots of white accent parts. You dont think the blue is going to look nice? I already bought the power :)
  3. stonedsurd
    11 Mar 2009
    I don't like baby blue ever since my room was painted that color when I was a kid :worried:
  4. Bradley8988
    16 Jun 2008
    LOL well im sorry if the case gives you nightmares but most of the blue shouldnt be too in your face :)
  5. stonedsurd
    11 Mar 2009
    In that case, go for it :D:thumb:
  6. Bradley8988
    16 Jun 2008
    Update 8th June.
    I dont want any black in the whole build if i can help it so the rear of my card is on show and not fitting in with my all white and blue look so something needs to be done. Im going to make a cover out of differnt colored bits of acrylic sandwiched together with my project name and sponsor CNC cut into it which will hopefully glow blue along with a strip all around the edge. I made a load of designs up but settled with this.
    As i have a few bits been sent to Tom@ChilledPC next week I got on sorting what i needed cutting for the rear card cover. Now my cards arrived i measured it and transfered that to Photoshop to be able to accurately print it out.
    This is how its going to sit on the card.
    As im happy with it I then cut a piece of White acrylic(Has blue protective film on) that it will be cut into.
    Also my mate Oggie sorted me out with a side panel which im not 100% sure i will use but its def different to the normal square or rounded corner cuts so may go with it. Been Genuine lian-li it fits perfectly and is very good quality.
    Cheers.
  7. stonedsurd
    11 Mar 2009
    Looking good! Especially the card :D
  8. Bradley8988
    16 Jun 2008
    Will look nicer with that nasty black cooler gone :)
  9. stonedsurd
    11 Mar 2009
    Yep. Will you be going full-cover or...?
  10. Bradley8988
    16 Jun 2008
    Yah waiting on the new koolance blocks. My card is the new PCD 285 but my block is the old so going to return it. :(
  11. stonedsurd
    11 Mar 2009
    Ah. Koolance makes some nice looking blocks :D
  12. Bradley8988
    16 Jun 2008
    They do :)
  13. The boy 4rm oz
    10 Apr 2008
    The card back cover looks sweet, as does the side panel.
  14. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    i believe i see epic win
  15. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    definitely have to agree with you there.
    +1
  16. Bradley8988
    16 Jun 2008
    Thanks mate i hope it turns out as well as i can imagine it in my head :) Still gotta figure out how to get the nice glow effect i want.
    :thumb:
    Thanks chap! All the nice comments are a nice boost :)
  17. [ZiiP] NaloaC
    [ZiiP] NaloaC Well-Known Member
    9 May 2008
    Big fan of Koolance and their kit myself. My own WC kit nothing but their stuff. Gotta love compression fittings. Have an obscene amount of tube splitters lying around from my PhD project...maybe for my next machine they might provide a use.
    Liking the look of the cover for the GFX. Looking forward to the next update.
  18. Bradley8988
    16 Jun 2008
    Yah there blocks are very nice and i was planning on getting a CPU block of theres but they were really hard and expensive to get ahold of at the time but have a one of a kind GTZ which should hopefully be finished in the next month or so :)
  19. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
  20. Bradley8988
    16 Jun 2008
    Update 11th June.
    Well against all the odds i finally got all the hardware together and did the pic thats normally in the start of the thread.
    Going to try set it up this afternoon. :001_cool:
    llamafur likes this.
