Case Mod - In Progress Project High-Res (Xmas update) Asus Xonar gets the treatment.
Discussion in 'Project Logs' started by Bradley8988, 14 Mar 2009.
  1. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Lovely block!
  2. Bradley8988
    Bradley8988 What's a Dremel?
    16 Jun 2008
    Thanks. Im thinking the only one like it anywhere :)
  3. The boy 4rm oz
    10 Apr 2008
    The GTZ looks amazing with the custom plexi top.
  4. Bradley8988
    16 Jun 2008
    Added some bitspower :)
    1920x1200 Wallpaper. Clicky.
    The boy 4rm oz likes this.
  5. The boy 4rm oz
    10 Apr 2008
    Now it looks even better :D. +rep
  6. Bradley8988
    16 Jun 2008
    Thanks mate. Kind words as always :)
  7. Bradley8988
    16 Jun 2008
    Update 26th August.
    Well i made a mock up res again to test if this way will actually work when filled with water. Using 2mm clear acrylic all around for the mock up i got some silicon. I saw this and well it said xtreme so I had to buy it :)
    Anyway this was the end result. (upside down).
    Now to test if this will hold water its time for a basic leak test. Straight water wouldnt have shown leaks too well so Robinson's to the rescue.
    Adding alittle at time all seemed ok.
    Soo no leaks and im pretty happy that if i do it alittle better with the plexi it should stay nice and strong. Iv gotta cut 3 holes into it for the fillport and inlet/outlet but may send it to Tom to be cut on CNC as i can see it breaking with a drill bit.
  8. The boy 4rm oz
    10 Apr 2008
    Nice res, love the shape, and the weird coloured liquid you put in it lol.
  9. Djayness
    Djayness phwupupupup
    7 May 2008
    Just a heads up, large res's seem to have a problem with rises in heat, they can expand anything up to 1-2cms easily and if the plexi is 3mm or around that, it may easily crack.
    I have a similar project res that I made, held 10 ltrs of water and in the summer it got to 35 degrees in my room and the water even hotter and it just split.
  10. Jozo
    Jozo This is bit-tech
    14 Mar 2009
    Pressure test it?
    Plug one hole and on the other connect a bicycle (air) pump, dump it in water and see if there are any bubbles coming out.
    Love the block, it's awesome! :thumb:
  11. Bradley8988
    16 Jun 2008
    Thanks mate.
    In that case i may leave the fillport slightly unscrewed to allow for this. Thanks for the heads up dude, first time iv done anything like this. :)
    Ima re make the res alittle better over the weekend if the suns out. Glad others like the block as much as i do :)
  12. Djayness
    7 May 2008
    is there anywhere special you guys are getting the bitspower fittings from? I cant seem to source them in aus.
  13. The boy 4rm oz
    10 Apr 2008
    GAMMods have them in Australia, they got a ton ;), PC Case Gear also have some.
  14. Djayness
    7 May 2008
    Hot damn, I should know that since GAMMods is sponsoring me lol :duh:
  15. stonedsurd
    11 Mar 2009
    You might want to shoot SNiiPE_Dogg a PM. He made a massive res for his project 'Flow' :thumb:
  16. stuartpb
    stuartpb Modder
    16 May 2008
    That Bitspower block is stunning. :jawdrop: Very nice build you have going on there too!! Well done!:thumb:
  17. Bradley8988
    16 Jun 2008
    Will do mate.
    Thx boss :)
    All comments help :)
  18. Bradley8988
    16 Jun 2008
    Update xmas.
    Sorry for lack of updates i have just been busy with life but few tiny bits done. Gotta get this res done soon....
    Anyway :)
    The dude who did the CPU block top for me kindly sent some little stainless steal inserts for the top. Im pretty happy with it now.
    Plain top.
    With inserts.
    Also Tom@ChilledPC came through again on my sound card to match the build better.
    Stock Xonar D2X
    Modded Xonar.
    Cover has been anodised blue and the rear bracket chrome plated.
    Thanks.
  19. Jelle46
    Jelle46 Belgium
    14 Feb 2009
    Looks like some kind of special edition. nice!!!
  20. Xonar
    Xonar What's a Dremel?
    2 Nov 2009
    That is such an nice finish on the sound card it looks awesome, would love to see one finished in red for my own rig :]
