Project: Homebrew CNC Machine
Discussion in 'Project Logs' started by JavaDog, 8 Apr 2005.
  1. xc3ll
    xc3ll What's a Dremel?
    31 May 2005
    what are you using to convert the NC code to actual commands?? looks sick man... I heard of some crazy dude on the internet making his own CNC machine awhile back, and I was like "NO WAY!"... u proved me wrong man, lol!
  2. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    I am going to use OneCNC XR to generate the G-Code, and ArtSOFT Mach3 to run the G-Code...
  3. (spc)kuhnkejer
    (spc)kuhnkejer What's a Dremel?
    14 Feb 2005
    so it sounds like things are going all right when are we going to see pics. I would like to see how far you have gotten on this project.
  4. xc3ll
    31 May 2005
    dear Lord... onecnc xr is beautiful.... i want to cry! i want it soo bad now!
  5. Nads
    Nads What's a Dremel?
    29 Jun 2005
    is there any reason not to use stepper motors, suitably geared for a cnc machine as here in the UK a company builds servo driver boards and supplys the complete kit. The servo is driven by rs232 and can be daisy chained. Although by gearing down you will increase linear times, it may make a smaller cnc machine viable to make for the masses. heres the address: http://www.milinst.com/
    Oh and they do a natty line in RC controllers too, and also sell a DIY, if not very big CNC machine which joe public could build and create small items
  6. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    I sooooo badly want to see the rest of this beast!
  7. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    I second that - time for an update and more pictures, surely?
    :clap: :clap: :clap:
  8. obzelite
    obzelite What's a Dremel?
    9 Jun 2005
    I'd be interested to know how similar your machine would be when finished to something like this.
    http://www.rolanddg.com/products/mdx650/index.html
    Just got finance for one for my business, but your 2,000usd machine makes me feel sick when i think about handing over the 60,000aud for that roland one.
    Certainly makes me feel like looking for alternatives before i sign on the dotted line.
  9. frodo
    frodo What's a Dremel?
    1 Nov 2003
    any updates on this beast? i really want to see some progress!
  10. obzelite
    9 Jun 2005
    ditto
  11. milgo
    milgo What's a Dremel?
    12 Jan 2004
    obzelite there are several individuals that make cnc routers and then sell them on for more like $5000-$10000 USD depending on size. I will find the forum for you :)
    And anyone seriously interested in affordable small cnc machines should check out sherline and taig (peatol in the UK). In the US you can get a 5400 sherline machine with everything to convert it to cnc for $1249.
  12. obzelite
    9 Jun 2005
    Milgo, that would be really cool.
    I've put the roland machine purchase on hold as i've found another machine that is larger and is not limited to soft metals. It also has liquid cooling, comes with all the software and controller to run it as well. Its just not 3d, but thats not really an issue as the to go 3d on the roland machine required another 10,000$ rotary axis.
    Going to get a demo of it soon as its one of first four in the country and seems to be a far better deal at 20000 aud.
    Still really want to see what javadog comes up with
  13. Flibblebot
    19 Apr 2005
    Unfortunately for us, I think javadog has finished his creation, and is too busy playing with it to update this log :D
  14. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    From memory the exact same thing happened the last time someone made a CNC machine (Kong or someone? *shrug*). We got 9/10ths of a project log and then they vanished.
    Oh noes! Homebrew CNCs are cursed!!
  15. gometro33
    gometro33 What's a Dremel?
    11 Jan 2005
  16. JavaDog
    13 Mar 2004
    I'm sorry guys...the only curse here is the one of being too busy! :D
    Went on vacation, built an underwater rov camera system, working on getting th CNC machine finished...it never ends. Not that I am complaining! :rock:
    Ok, build log pictures in 5...4...3...2...
  17. JavaDog
    13 Mar 2004
    Ok, so the frame is going to be made from 80/20 and Aluminum Plate (for the end-caps) as I previously went over.
    Here is my collection of 80/20 for the frame:
    These are the fasteners that allow you to bolt things to the 80/20. They go into one of the channels on the sides:
    So, I need to cut the 80/20 to size.
    Here is the weapon of choice:
    ...and its teeth:
    On to the carnage!!
  18. JavaDog
    13 Mar 2004
    Setting up for the first cut:
    Cutting the 80/20:
    I actually was amazed, it ate through that aluminum like it was a soft-cheese.
    Now, cutting the smaller 80/20:
    Again, like buttah! :dremel:
    That was easier than I could have hoped! Now, with the 80/20 all cut, it was time to start drilling the end-plates to bolt everything up.
  19. JavaDog
    13 Mar 2004
    Here I started to mark where I needed to drill. Since I have two end-plates, and I want them to be exactly the same, I will drill them both (clamped) at the same time.
    Marking:
    You can see the clear lexan I used to make a drill-guide
    Here is my drill press:
    Now, let me go off on the table a bit. I was driving my Fiance to work, when I saw what looked like a cool table sitting on the side of the road with a "FREE" sign on it.
    Well, that is my kinda price! So, I stopped to look at it on the way back. Turns out this beast 6ft long and about 5" wider than I needed for my CNC machine. It is made out of HEAVY 1" MDF, with the plastic panel coating and swank red bumper-guards. It was like someone built a table for my CNC machine and left it out for me.
    It. Rocks. :rock:
    Ok, on to the drilling...
  20. JavaDog
    13 Mar 2004
    Drilling the first hole:
    I am using some HSS drill bits. Cutting dry was a little rough, so I started spraying my bit with a little WD-40. Worked like a charm!
    Another hole:
    Close up:
    First set of holes drilled:
    I was pretty happy, all the holes were spot on. Couldn't be better so far!
    More to come soon!! :thumb:
