Project: Homebrew CNC Machine
Discussion in 'Project Logs' started by JavaDog, 8 Apr 2005.
  1. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Ok, so with the end-plates all drilled I could finally do a mock-up of the frame. Not all of the 80/20 was tapped, nor did I have enough bolts (estimate about 50 cap-head machine screws total = $$) to bolt everything up - so some parts are held together with some drill bits. :D
    So, minus the rails and ballscrews, here is what the lower frame will look like:
    For size reference, this is 26in from plate-to-plate. :cooldude:
    More updates soon!
  2. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    Wow. I like this very much. Can't wait to see it finished. BTW, awesome job on the ROV!!!
  3. JavaDog
    13 Mar 2004
    Thanks! There will be updates on the ROV too - come spring/early-summer. I will be using the CNC Machine to make some parts to add thrusters to it. :rock:
  4. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Looking awesome so far, keep up the good work.
  5. JavaDog
    13 Mar 2004
    Here are some pictures of the awesome enclosure that I bought for all the electronics and power supply:
  6. kplonk
    kplonk What's a Dremel?
    1 Mar 2002
    Nice to see your still on it.
  7. G69T
    G69T CNC Modder
    6 Jun 2004
    Nice work, I'm curious to see the rest... :rock:
  8. Goth
    Goth What's a Dremel?
    17 Oct 2004
    is it really hard to make that case ? looks yummi anyway :)
  9. JavaDog
    13 Mar 2004
    I suppose if I had a welder I could have made it myself - but when I got it made for me for a fantastic price - why bother. :D Plus, it is customer made for my electronics and PSU components.
  10. JavaDog
    13 Mar 2004
    Ok, back to the frame...
    Tapping the 80/20 Extrusions:
    The frame, not mocked up - actually bolted together:
    Frame with MDF spoil-board (not yet cut to size):
  11. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    Looks good. Ive been following this thing since the begining. Keep up the great work.
  12. Agamer
    Agamer Minimodder
    10 Mar 2005
    Yeh, It's all comming together, Not to long and we'll be seeing the produce from this machine, Well I hope so.
  13. JavaDog
    13 Mar 2004
    Since I wasn't happy with my Dual-Transformer design for my PSU I decided to go another route.
    A friend was kind enough to send me a toroid transformer (what I should have used from the start!). Check it out:
    This is going to make the PSU design so much less complicated...
  14. Liquid
    Liquid What's a Dremel?
    20 Jul 2005
    beautifull stuff...
    keep going :D
  15. Rocket733
    27 Dec 2003
    keep up the good work, sweet as always
  16. JavaDog
    13 Mar 2004
    Since I am now using the Toroid, I decided to update the diagram for those playing along at home. :D
    Revision 3 (Hopefully Final!):
    Click for full-size diagram!
  17. Yumadil
    Yumadil What's a Dremel?
    17 Jul 2004
    how much amp draw do you expect from the motors?
    what is the precision level you expect to attain?
    love the project, awesome work, inpiration for my cnc project
  18. JavaDog
    13 Mar 2004
    The servos are rated for 3A each under load. I hope to get .010" accuracy or better. Because I am using unsupported rails (although not too long) I will lose a little bit of accuracy (they can flex). However, it will be more than enough for what I am planning on using it for. Plus, down the road I may swap out the rails with higher-end Linear Rails (like I have for the Z-Axis).
  19. BobbyMParr
    BobbyMParr GameDemon
    18 Jun 2004
    you interested in machineing stuff for me or other people after this is done?
  20. JavaDog
    13 Mar 2004
    I have some personal projects that will demand some serious machine time, but yes - I will be very open to doing custom work for others. Hey, I gotta offset the cost of this thing somehow! :D
    Some more big updates coming soon! :dremel:
