Scratch Build – In Progress Project: Honeycomb - Completed - CustomPC Featured Mod Nov 2012
Discussion in 'Project Logs' started by Fuganater, 7 Jul 2011.
  1. SXRguyinMA
    SXRguyinMA What's a Dremel?
    28 Jun 2011
    The sleeved tubing look SICK!!! Nice work man keep it up!
  2. bugeye
    bugeye Sleep Deprived
    16 Aug 2011
    What I really like about this mod is that despite being bright orange and having enough leds to shame an airport it all works , it all comes together to make something that is strangely subtle and very cool :)
  3. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Thanks!
    Haha, true. I did use alot of LEDs so far. Thanks for watching!
  4. Fuganater
    6 Jul 2011
    Sleeved Tubing + UV??
    Since Lamptron was so nice to give me some UV Cold Cathodes I figured I would see how everything looks.
    I think it looks pretty good. I'm going to see how it looks with the blocks lit up and the fans on.
    Cheers till then.
  5. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
  6. l3p
    l3p www.^.nl
    1 Nov 2010
    I thought green was THE UV colour, but this simply rules!
  7. DirectOverkill
    DirectOverkill What's a Dremel?
    22 Sep 2011
    sick color show!
  8. AK71
    AK71 What's a Dremel?
    29 Jul 2011
    Very nice so far Fuganater. I know it's a bit late now since you have done all your lighting, but did you know that filing the top of an LED flat then sanding the whole outside can diffuse the light on most LEDs? I did this a while ago and it helps to stop the spot lighting you can get.
  9. Fuganater
    6 Jul 2011
    Thanks guys! :rock:
    I used SMD LED strips so I don't think that would have worked. Unless your talking about the regular LEDs that are in my waterblocks?
  10. AK71
    29 Jul 2011
    Yup, regular 5mm or 3mm LEDs. With a flat top and a sanded outside you can often get the whole LED to glow rather than the spot of light you get with modern LEDs
  11. AK71
    29 Jul 2011
    Sorry for the double post but wanted to show what I mean. Both LEDs here are the same type from the same batch and I tried to take photos from the same distance and consistent lighting direction etc...
    Standard 5mm LED
    5mm LED sanded with 180 grit sandpaper so it has a consistent 'frosted glass' look to it and a flattened top.
    Standard LED lit with 12V and appropriate resistor. You can see most of the light comes straight out the end.
    Sanded LED with exact same power source and resistor. The entire thing lights up!!! Take your time, not like me, and you get an even better effect, great for illuminating panels or waterblocks etc.
    Fuganater likes this.
  12. Fuganater
    6 Jul 2011
    Thanks for the suggestion! I'm going to give it a try as soon as I can.
  13. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    This is one aewsome build mate!
    The finish on the case looks brill!
  14. Fuganater
    6 Jul 2011
    Not sure wha that means? but thanks!
  15. Fuganater
    6 Jul 2011
    UV + LED lighting
    I connected the WB LEDs now and put power to the fans. Here are the results.
    This first set of pictures are with 1 UV Cold Cathode running from front to back on the top of the case and one on the front panel running up and down.
    Now these pictures are with both UV Cold Cathodes running the width of the case on the top panel. 1 in front and 1 in back. (That was really hard to explain lol)
    I still have a lot more work to do. Going to make the res LEDs tonight and try to figure out how I'm going to do all the switches for all the different lights.
    Cheers till then.
  16. l3p
    l3p www.^.nl
    1 Nov 2010
    Oh man I love it!
  17. bulldogjeff
    2 Mar 2010
    That is looking sweeeeeet. love it dude. There's some thing about orange under UV that always looks so good.
  18. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    That coller theme is just sick! Keep it up man! :thumb:
  19. SXRguyinMA
    28 Jun 2011
    that is absurdly gorgeous!!
  20. Fuganater
    6 Jul 2011
    Thanks guys!
