Project HP-Resurrection II--- >Small Updates :)
Discussion in 'Project Logs' started by Defyant Mods, 15 Sep 2004.
  1. (X)TORNADO(X)
    (X)TORNADO(X) What's a Dremel?
    26 Feb 2005
    OMG what caind ofg work really really nice... :clap: :clap: :clap:
  2. mondriaan
    mondriaan What's a Dremel?
    20 Aug 2004
    This last one looks AWSOME :jawdrop:
    Howe did you do that?? You must have excellent skills :jawdrop:
    :thumb: :thumb: up for this dude
  3. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Very nice work, and came together quickly. 5-Star rating. :thumb:
  4. SvampSoppa
    SvampSoppa What's a Dremel?
    20 Oct 2004
    could anyone direct me to the page where he puts the black thing on the motherboard tray, cus i cant find it :wallbash:
    i love ur work, i even stole the idea with the 12v plug in the mbt which i will put in my comp
  5. Kipman725
    Kipman725 When did I get a custom title!?!
    1 Nov 2004
    thought about a roof window? :naughty:
  6. callum smells
    callum smells What's a Dremel?
    26 Feb 2005
    wow...id just like to say wow...have i said wow yet :jawdrop: :jawdrop: :jawdrop: that is n1 mod i have ever seen
    sorry moddin.net :waah:
  7. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    Ty guys :)
    a top windowi did think of it :) maybe hpres3 :)
    Just a qikky update guys, for those who wanted to know how the system would run with the MB be covered?
    Just great!!!
    the fans are working a treat and really moving air up accross and over the vital parts.
    I also think alot has to do with the efficiency of the water cooling, effectivly moving heat away from the hottest parts fast.
    The chipset WB also helps a heck of a lot too.
    anyways after running HPResII now non stop for a few days now i can without a doubt say that is a good workable mod :)
    its not the hotest day here atm, but from what i can see it easily manageble to keep it a few degrees abobe room temp.
    heres a qik screener from today, running the cpu @ 100% for a solid few hours now and temps are just cool :cool:
  8. Defyant Mods
    14 Sep 2004
    a qik update
    Hp res needed some sort of custom stand.
    Heres what i came up with.
    cut to shape this will be the upper deck,
    This is the idea the top deck will be suspended off the bottem on a slight angle to "tilt" the pc forward a little for a show display like look.
    Next was to cut 7 support struts to suspend the upper deck
    glue them into place and clamp the 2 decks together.
    so far soo good!!!!
    Next part is to make a lip around the upper deck so the pc dosnt accidently slide off! :shock:
    Using the solid 6mm tube , some heat and some cloth pegs and glue! ill attach the tube around the whole upper deck.
    clamp the tube at a point
    Using the hot air gun apply heat and bend
    Allow dry and peel the rest of the paper off.Attatch some little rubber footsie pads.
    A test run with the spare base,
    Then its inside to test it on the real thing!!!!!!!!!
    Peal off the plastic skin thats still on the base of the pc.
    even i didnt expect the effect to work this well, but was happy it did.
    The way the base is designed i can now i can just slide my hands under pick it up and move the pc around with no fear.
  9. Lost.Soul
    Lost.Soul What's a Dremel?
    26 Oct 2004
    ummm ... hard to find the right words.....
    AMAZING!! :clap: :clap: :thumb:
  10. Headspark
    Headspark Minimodder
    23 Feb 2005
    F#CKING AWSOME,
    To me the best i have seen, no posh tools, just a guy and his PC, that there is a TRUE mod!
  11. Cowinacape
    Cowinacape What's a Dremel?
    26 May 2003
    :rock: Very nice indeed, a tip o' the 'at to you mate! :rock:
  12. Constructacon
    Constructacon Constructing since 1978
    12 Oct 2004
    This just gets better and better. I'm flabbergasted by it. :thumb:
    Dude - you rock.
  13. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    I must say, that this looks just great :thumb: :thumb:
    Rock on :rock:
  14. Bilbo Fraggins
    Bilbo Fraggins What's a Dremel?
    1 Jul 2004
    once again...
    cool :thumb:
  15. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    Hehehehe Sweet!
  16. cerberus
    cerberus What's a Dremel?
    23 Sep 2003
    That stand is SWEET. Great work.
  17. mondriaan
    20 Aug 2004
    :jawdrop: :jawdrop: WOW
    I can't say anything else, it's breathtaking.
  18. Rufus-Seal
    Rufus-Seal Guest
    :jawdrop: :jawdrop: Can somebody get me some tape? My jaw is falling off. :jawdrop:
  19. frodo
    frodo What's a Dremel?
    1 Nov 2003
    wow... thats not just the most awesome looking thing... it also has a purpose!!! wow
    great work... keep moddin' :dremel:
  20. Sheiken
    Sheiken Wat?
    9 Jan 2005
    Amazing.... :jawdrop: stylish yet still it is able to attract alot of attention! just the way I like it :)
