Project: HTPC - [style] UPDATE 6/9 PICS ADDED!
Discussion in 'Project Logs' started by tapius, 12 May 2004.
  1. tapius
    tapius What's a Dremel?
    12 May 2004
    Project .::HTPC - [STYLE]::.
    Housing: - Sony Mini HiFi Component System
    +Amplifier with Graphic Equalizer (VFD)
    +AM/FM Tuner with 20 Presets and Timer (VFD)
    +Compact Disc Player
    I will be using the CD player housing for my HTPC
    Hardware:
    +VIA Epia M10000 Nehemiah ITX (SFF) Motherboard
    +60 Watt ITX Powersupply
    +Sony Slimline CDR/DVD
    +128MB DDR PC2100 Ram (Low Profile .8")
    +2.5" Seagate 20GB Harddrive
    +CrystalFontz 631 USB LCD Red
    +IRMAN
    work done:
    Gutted CD PLAYER
    Kept 4 original buttons, soldered leads onto 3 of them
    Kept Power Button - Power lead with clip for mobo
    Replaced the old numerical VFD with the new Crystalfontz LCD (running off my main computer)
    Changed ALL casing screws on all components with Aluminum Thumb Screws
    (going to get adonized black thumb screws later)
    Put case logo sticker over ugly button holes on the front bezel
    put case logo on back of all components
    Pictures thus far:
    _______________
  2. A13n0rma1
    A13n0rma1 Wannabe
    17 Jul 2003
    :hehe: Angelfire...
    Uploadit.org is your friend. :hehe:
  3. tapius
    12 May 2004
    sorry about that: pics fixed :)
  4. boardsportsrule
    boardsportsrule What's a Dremel?
    9 May 2004
    no they arent! plz try again! :D
  5. tapius
    12 May 2004
    k, sorry guys these should work this time, they're no longer being hosted on a freehosting site
  6. tapius
    12 May 2004
    Today I've decided to stop by radioshack and replace the back of the amp. There are 4 Speaker terminals, RED and BLACK for two speakers - I've decided to change this to an RCA Female Connectors - and then doing the same with both my speakers. I will post pics tonight
  7. infernis
    infernis What's a Dremel?
    5 Jan 2003
    You're using RCA connectors for speaker cables? Are you aware of the current limitations of an RCA connection, especially in the very real context of speaker cables? If your speakers draw lots of current, you are asking for trouble.
  8. tapius
    12 May 2004
    Sorry i meant PHONO cables, but even still, the speakers i am using draw very little current and are small home theater speakers, im not powering 500 watt speakers here..
  9. tapius
    12 May 2004
    Updates!! 6/9
    Ok LOT AND LOTS AND LOTS OF UPDATES!
    installed MOBO
    installed case fans
    installed Power supply
    installed Phono Jacks on back of AMP
    installed phono jacks on back of speakers
    cut up the back of the case
    and my LCD died :( but im getting a new one, YAY -
    i will be posting pics shortly sorry for the delay
    :rock:
  10. tapius
    12 May 2004
    Original Back of AMP
    New Back of AMP
    Phono jacks connected to terminals
    back of front panal, IR detector, reset, power LED and open/close button PCB
    power Button PCB, i hope you all enjoy my glue gun over the solder, it adds a nice level of protection
    front panal with new IR detector red plastic window (took place of play button)
    Back panal and MOBO ports (TV out :cooldude: )
    rear case fan, and power connector from AC adaptor to morex PSU
    Top cover with fan installed
    mobo, psu installed :clap: :clap: :clap:
    i had to cut down the heat sink, the orignal via northbridge heatsink rose above my low profile ram and would have gotten in the way of where my combo drive is going, so i removed the heatsink, and then trimed it down and put it back on :naughty:
  11. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    I love when people do this kind of stuff with the electronic peices. One day I will do that kind of mod... some day! :hehe:
  12. tapius
    12 May 2004
    thanks man, yeah so far im happy with the way the projects going - im sad that the crystal fontz USB lcd got killed :waah: but a new one will be replacing it shortly.. and i wait
  13. BadKarma
    BadKarma What's a Dremel?
    4 Feb 2004
    Great work so far man. looks like it might turn out pretty sweet. What do you plan on using to control everything software wise when its done?
  14. tapius
    12 May 2004
    planning on running windows 2k, and IRman to control powerdvd, and winamp
  15. tapius
    12 May 2004
    package with DVD/RW Slimline drive and 20GB seagate 2.5 inch 5400 rpm HD and all adaptor cables, comes tomorrow - I just checked my tracking numbers for ups. then on June 14th i will recieve my Replacement LCD (crystalfontz 631 USB RED) and my IRman
  16. BlackMan
    BlackMan Minimodder
    12 Sep 2003
    looks good, i have never seen a computer in a vcr, or something of the like, before, i always thought of it as a good idea
    keep up the good work :clap:
  17. korhojoa
    korhojoa durr
    31 Oct 2003
    Sorry for bumping the thread, but is it going to be completed?
