Case Mod - In Progress Project: Hydro Copper
Discussion in 'Project Logs' started by OcSurfe, 26 Jul 2013.
  1. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    Hello guys,
    This log will be very quick as it is practically now completed and being leak tested.
    I was given this case and fans by Nanoxia, primarily to write a review,
    but they also wanted to see what could be done with a DS2 as they were convinced that only a slim 240mm rad could be mounted to the pre-existing shroud on the Hard drive cages.
    I thought, whilst i am at it, ill make a computer for my friend, who has always want a gaming system but never gotten around to actually getting one.
    First off i would like to say thanks to Nanoxia, Eddy, you are a star, thanks very much for letting me use this case and for the opportunities you have given me.
    Another Thank you to Pascal at Alphacool who has supplies all of the water cooling that i needed for this, thanks mate couldn't have been done without you!
    Cheers to Silverstone for supplying a 850w PSU which will have enough juice if another 680 is added a little later!
    Another Thanks to Western Digital for supplying some storage for this build, a 500gb Caviar Green.
    And thanks to Mr. James Churchill AKA Pexon for the sleeving, MDPC is just brilliant sleeve
    Now for a few specs and parts.
    Motherboard: MSI Z77 Mpower
    CPU: Intel i5 3570K
    RAM: 8gb G.Skill TridentX @2400mhz
    GPU: EVGA GTX 680 Signature 2
    PSU: Silverstone Strider Plus 850W
    SSD: 240gb Mushkin Chronos
    HDD: 500gb Western Digital Caviar Green
    Case: Nanoxia Deep Silence 2
    Fans: 9x Nanoxia Deep Silence 1200RPM
    Watercooling
    Pump: Alphacool D5 Vario with Alphacool Top
    Reservoir: Bitspower 150 Z-Multi
    GPU: Alphacool Nexxos GTX 680
    CPU: Alphacool XP3
    Radiator: Alphacool 360mm Monsta
    Fittings: Alphacool all copper compression fittings
    Coolant: Mayhems X1 UV Green
    Below are a few pictures of the build. to make the Radiator fit in the front of the case, i had to drill out all of the rivets holding the drive and optical bays in place then it was a simple case of bolting the radiator to the pre-existing grill in the front of the case. The top fans are not bolted to the case but can breath due to the Drive bay covers being meshed and allowing for airflow.
    I will post up come more photos when it is finished and show where i have mounted the storage devices.
    BEWARE NERD PORN THE COOLER IS OFF!!!!
  2. GamerIDGoesHere
    GamerIDGoesHere www.^.com
    3 May 2012
    EDIT: Removed as of today, see my below post please :)
  3. stuartwood89
    20 Aug 2008
    Wait... what? Of course there is copper in there, look at the fittings, the colour of the waterblocks, the sleeving, even the screws to bolt the fans to the radiator. Perhaps you need to adjust the colour settings on your monitor or something.
    Also, any build images/worklog?
    The_Crapman likes this.
  4. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    There are some coming bud, im just bogged down with work at the moment but they will be coming
  5. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    +1
  6. stuartwood89
    20 Aug 2008
    I think he's referring to the HydroCopper waterblocks he's using in his build, though the words 'Hydro' and 'Copper' can be used for anything that includes water(cooling) and copper, which this does.
    I think the green fans look good with, especially as copper goes green when it oxidises.
  7. GamerIDGoesHere
    3 May 2012
    Ok Guys, I realise what I said was a bit naive and not right to say, so sorry to everyone, and now that I look at it twice, your build actually looks pretty good.
