Project:Hyooj
Discussion in 'Project Logs' started by ouija, 22 Feb 2003.
  1. lord nicon21
    lord nicon21 sexy *******
    29 Sep 2003
    cool its what i have at the min :thumb: why do you want to change it
  2. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Upgrade
  3. lord nicon21
    29 Sep 2003
    no ****
    whats the diffrents
  4. olv
    olv he's so bright
    23 Sep 2002
    I'm guessing nforce2 chipset.
  5. ouija
    10 Nov 2002
    Correct.
    Can you do me a favour nicon and take the img links from your quoted post? It's awkward having the images appearing twice, especially when they're that big
  6. lord nicon21
    29 Sep 2003
    yep :thumb:
  7. complexprocess
    complexprocess What's a Dremel?
    8 Jul 2002
    That's about the coolest thing I've read in ages. :D
  8. ouija
    10 Nov 2002
  9. olv
    olv he's so bright
    23 Sep 2002
    I've read it about 5 times and only just got it :rolleyes:
    /me slaps olv around a bit with a large trout
  10. lord nicon21
    29 Sep 2003
    lol tut tut :hehe:
  11. ouija
    10 Nov 2002
    Sometimes I wonder why I bother :lol:
  12. ouija
    10 Nov 2002
    :baby:
    My motherboard arrived from overclock.co.uk yesterday. It arrived at my old work, so I only got it today. My XP2800+ is on backorder. Stock was expected yesterday, but they've put it back to the 14th :miffed:
    Anyways... it's a Gigabyte GA-7VNNXP. It uses the nForce2 chipset :D and has 4 memory slots for loads of Dual-DDR PC3500. It also has an AGP pro slot, the standard Gigabyte dual BIOS, setial ATA, standard RAID, and Gigabyte's new dual power system (DPS). It's an extra card that provides 3 more phase change circuits which run in parallel and also serve as a backup if anything goes wrong.
    I don't think my heatsinks I made for the MOSFETS will fit. I'll epoxy them on the old board for my next project. I may get some Tweakmonster BGA sinks for this board, if they fit with the DPS card installed.
    The massive box. Biggest motherboard box I've seen
    The box opened out
    The entire package
    Closeup of the board
    Might get another Gb of RAM and have 2Gb of XMS3500
    4 USB ports, Dual LAN, 2 COM ports (these are VGA ports on the VNNXPV model)
    The DPS card. The heatsink fins are vertical, I'm hoping this will direct more air onto the MOSFETS next to the CPU socket below the card
    Under the heatsink, you can see the 6 extra MOSFETS. Might slap some Arctic Silver 5 on this ;)
    DPS card installed with retention clip. It's not the tightest of fits but since the card sits vertically when mounted in the case, it should be Ok
    The CPU socket is rotated 90 degrees. Might be a bit awkward with my swiftech block. Soon see
  13. Seal
    Seal What's a Dremel?
    2 Feb 2003
    whats the DPS board for? looks like some kind of power inverter.
  14. ouija
    10 Nov 2002
    6 phase change circuits instead of 3 mean less strain and they will most likely run a lot cooler, especially with the heatsink on half of them. It also means if there is something wrong with the circuits on the motherboard, there is a backup... something that gigabyte seem to like doing (dual BIOS)
  15. Bust_A_Cap
    Bust_A_Cap What's a Dremel?
    22 Dec 2003
    Dude what would you ever need dual LAN for???
    Nice case so far....nice hardrive...wish i had some money to get a big bertha like that!!!!!
  16. NzC
    NzC What's a Dremel?
    7 Sep 2003
    Dual LAN is great for times when you are say hosting a LAN party and want to be connected to your home network and the party network.
    Nice project--thats a sweet mobo!
  17. Arkangyl
    Arkangyl What's a Dremel?
    16 Dec 2003
    Wow, just read all 12 pages of this project and... WOW :thumb:
    great work Ouija, Hyooj is looking awesome...
    Can't wait to see more
  18. ouija
    10 Nov 2002
    I require dual LAN for internet connection sharing until I get a router. It's still useful to have though. I don't need to have my second PCI network card installed any more.
    Arkangyl: Not much more to go... just motherboard and CPU installation, possibly a northbridge block. Other than that, this mini upgrading spree is to supply my next project with "castoffs". All I need is my new graphics card and some memory for the next project. That, and the case :thumb:
  19. Altron
    Altron Minimodder
    12 Dec 2002
    If you run your machine as a router, an internet gateway, or a firewall.
    EXAMPLE
    Modem > PC > a hub > other machines on network
    Also fi you want to be part of two networks, like a webserver that uses 1 NIC to connect to the internet and the other to connect to the local network.
  20. TheDon
    TheDon What's a Dremel?
    21 Oct 2003
    Very nice setup. I like the dual lan. Makes things alot easier. Plus you can bridge them and run at 200 mpbs. The case is lovely.
