Project: HYPERCUBE² 21/03/2005 PICTURES FROM CEBIT
Discussion in 'Project Logs' started by Joungne, 18 Jul 2004.
  1. JungleGorilla
    JungleGorilla What's a Dremel?
    21 Apr 2004
    Orac3 was the reason I joined these forums, But it's mods like this one right here that I keep coming back!
    Excellent work there mate, keep it up :dremel:
  2. Zion
    Zion What's a Dremel?
    11 Apr 2004
    man this one sweet mod, keep it up :rock:
  3. Bradish
    Bradish What's a Dremel?
    7 Mar 2004
    Bravo! I <3 your excellent cuts :rock:
    Keep Up The Grand-ious Work! :dremel:
  4. fg0d
    fg0d Banned
    18 Jan 2004
    looking nicer and nicer everytime i see it, and thanks for using that white led idea :D
  5. preatorian
    preatorian What's a Dremel?
    18 Aug 2004
    dude that's totally schweet ;) ;)
  6. -N4cR-Stigma2K
    -N4cR-Stigma2K Banned
    8 Jul 2004
    This is one of the best mods I've seen. Maybe not the coolest (yet) but definately the best one!
  7. Joungne
    Joungne What's a Dremel?
    11 Jul 2004
    Tnx guys for all those replyes,
    It keeps me on the modding track. I find it hard to finish the project because its taking too long. I wanne start something new. (I got this great idea...)
    But every time I look at the replyes, it gives me that little extra to keep gooing
    greetz,
    Joungne
  8. Acid_B.
    Acid_B. What's a Dremel?
    6 Aug 2004
  9. theagent
    theagent What's a Dremel?
    4 Nov 2003
    Do It For The Home Team Joungne!
  10. Joungne
    11 Jul 2004
    :D
    if I only knew what "the home team" means.... :confused:
    greetz,
    Joungne
  11. theflinger
    theflinger What's a Dremel?
    21 Mar 2004
    Then I need to reply. Your project is friggin awesome, and I hope you find the motivation to finish it :D
  12. botchla
    botchla What's a Dremel?
    25 Aug 2004
    It means, like we say in dutch "doe het voor de thuisploeg"
    only we don't this as an expression.
    I've been following projects a long time here, also on tng..
    but I just registered here to tell you..
    DONT QUIT.. QUITE THE NICEST CASE EVER SEEN!
  13. Thunder_return
    Thunder_return What's a Dremel?
    8 Jun 2003
    You are mad , you better get that thing going cause this is
    a killer , never seen something like this ( apart from garden houses :hehe: )
    I know it is a problem to get to the finish line , it´s the same here but
    I do some stuff when I have the time and it is going slow to the finish...
    Anyway , if you get a day off , grab that case and work on it the whole day
    and I promise you will get the fun modding-feeling back!
    Remember: Only one project at the time !!
  14. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    I don't know something else to say than "you own 2 right hands" :hip: This mod is so perfect going, every detail seems to be perfect. A good inspiration for us, and a good supporting reply for you :D
  15. Joungne
    11 Jul 2004
    tnx for all the support guys,
    I think I ow you big time, so tonight I'll have a new (kinda special) update ready :)
    greetz,
    Joungne
  16. preatorian
    18 Aug 2004
    that's what we wanted to hear ;)
  17. Joungne
    11 Jul 2004
    Project HYPERCUBE² DAY 19
    26/08/2004 DAY 19
    Custom IDE cable time :)
    I bought me some rounded ide cables from coolermaster for the HD's, but when I attached them it really looked horrible (it came in front of the fan, and it was very visible... not what i wanted at all) That meant that I had to make my own custom rounded and hidden IDE cable.
    Here goes....
    First thing I made is this ALU profile with 2 10mm holes in it to get some cables trough. You'll see what I'm gonna do with it in the next pictures.
    It fits underneath the bottom plexiplate.
    I bought me some flat cable (40 pins) and some connectors. Time to start the custom cable :)
    the first connector at the end in place.
    cut of the leftover piece at the end.
    Bend over the cable, and attached the upper connectorbit.
    The victim out of its shell. I cut the flat cable in the middle.
    I marked it so I know at the end wich sides go togheter.
    Attaching the IDE on the HD
    the split cable through the two holes.
    cutted the wire in 10 so its smaller behind the HD.
    Attaching the HD back to the bracket..
    Getting the wires through the holes in the bottom plate.
    The wires need to go through these tubes. See what I'm getting at.
    This was a very difficult step. Its not easy getting 20 wires through a 10 mm tube.
    back through the holes to the second HD.
    Second HD in place and cables ready to go to the Mobo (I need to get some more tubing tomorrow, I used it all).
    I hope you like the idea of the cable. You cant see the connection to the HD at all. :)
    I'll post a picture of the connectors next time.
    Greetz, Joungne
  18. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    (what i did when i saw your ide cable idea)
    :jawdrop: :jawdrop: :jawdrop: :jawdrop:
  19. Morphious
    Morphious What's a Dremel?
    19 Jan 2004
    Impressively sexy. Great work. :)
    What are the dimensions of the case?
  20. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    k i love how the tubes kind of curve that is so nice!!!!! now i want to make my own IDE cables (just wondering where did you get that 40 pin cable?, link maybee?)
