Project: HYPERCUBE² 21/03/2005 PICTURES FROM CEBIT
Discussion in 'Project Logs' started by Joungne, 18 Jul 2004.
  1. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    OK the UV lights look ok the plexi i say put the frosted in the entire thing cuz that what the hypercube looked like, but at the same time i say keep them out so you can see the inside that you've worked so hard on. so it's 50/50 with me as well.
  2. Joungne
    Joungne What's a Dremel?
    11 Jul 2004
    Hi guys,
    You're not making it easyer for me. I have to agree with the uv lights. They kinda look out of place. Ok it does look better in real life, but I didnt see UV lights in the film either... So I guess they have to go. I have to be a little consistent.
    About the plexi... I should be able to have both, but thats not an option.
    I'm gonna wait a little more to take the discission, its still 50/50 for me.
    greetz,
    Joungne
  3. Cisko
    Cisko What's a Dremel?
    6 Jun 2004
    nice job mate :thumb:
    but i don t like the uv light :blah:
  4. z\\\\ffs
    z\\\\ffs What's a Dremel?
    2 Aug 2004
    damn...just perfect,really just perfect :rock:
  5. SirShaw
    SirShaw What's a Dremel?
    24 Aug 2003
    you should put up a poll for this kinda decision, IMO it looks better w/o the white plexi, gives the whole case more of a even flowing look. looks good either way, keep up the good work ;)
  6. coorz
    coorz Miffed
    25 Apr 2003
    Sublime stuff :thumb: . Just a tip from me on your Luxeon, thermal epoxy a heatsink on it and get a 3watt resistor for it. 1watt will do but if you're gonna have it on for a long time, best to go for a 3watt resistor.
    Mod on kerel!
  7. Firehed
    15 Feb 2004
    I agree - the UV lights look out of place.
    Is is possible to show a pic showing it with one type of plexi and one in the same position with the other? Of course I'd really have to see it in person but I'd end up stealing it :naughty: I like the frosted effect but seeing the innards is cool too, especially with those hard drives and whatnot - that mounting system is amazing.
  8. Joungne
    11 Jul 2004
    I will try to put up two the same pics tonight if I find the time
    greetz,
    Joungne
  9. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    A small 40mmx40mm piece of sheet aluminium would dissipate the heat if there's no room above the luxeon. A large heatsink isn't required for these things. Also if running the luxeon from the 5V supply, the resistor is only dissipating just over half a watt, so the 1 watt resistor really is fine. No need for 3W.
  10. SMOVE
    SMOVE What's a Dremel?
    17 Apr 2004
    This looks awesome
    :jawdrop: :jawdrop: :jawdrop:
    really impressive work! :rock: :rock: :thumb:
  11. Atomic
    Atomic Gerwaff
    6 May 2002
    Now that I will agree with!
    I really must read the project logs more, Im missing too many excellent cases.
  12. theagent
    theagent What's a Dremel?
    4 Nov 2003
    i liked it more when it reminded me of an ice cube
    no, i'm serious :) the white was sweet!
  13. preatorian
    preatorian What's a Dremel?
    18 Aug 2004
    high sweetness :> (eventhough it was about time ;))
    btw those feet look kinda wierd, maybey make them a bit shorter?
  14. GMan
    GMan Minimodder
    14 May 2004
    I'm very impressed with this mod. You've really managed to capture the HYPERCUBE theme perfectly!
  15. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    The case looks great.
    BTW that's the same board I used in the AmmoPC
  16. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    i say scrap the white plexi in the front so that you can accuatlly see the work of art INSIDE, through faily good sized "windows" instead of just the little fan holes cause i don't know about you guys but i would want to be able the the craftmans ship that was used on the inside of the case, well that it's for me i'm done
  17. ShockSonic
    ShockSonic What's a Dremel?
    10 Oct 2004
    Yes, very nice case so far. I hope you plan on adding more lighting inside?
  18. kobaj
    kobaj Banned
    4 Jul 2004
    Put white plexy it looks better than seeing the nasty green or red motherboard and stuff that doesn't work well with all the white. Oh and after looking through the pictures more and more I have changed my mind I acualy like the purple now it's a good contrast. Looks awsome.
  19. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Im afraid I still dont like the purple :blah:
  20. Joungne
    11 Jul 2004
    Project HYPERCUBE² DAY 24
    11/10/2004 DAY 24
    Time for a little update. I got a lot of comments about the UV lights and the legs on the cube. I took all these comments into consideration and came to the conclusion they both had to go. I wasnt so shure about them myself. Guess I needed to warm up after my holiday. So I came up with something different. I replaced the UV lights with normal ultra bright white ones, and that'll have to do the trick. The legs are something different, you'll see an update of them further down the update. First I did some work on the Baybus.
    I made these 25mm round disks (4 in total) using the drill on the picture.
    They are coming behind the knob and should be lighted with one small led.
    They look something like this. I need to clean them up a little, but you get the picture.
    One led in place. I dont have a pic of the placement of the led. I drilled a 3mm hole just underneath the part (is it called a rheobus?) as high as possible. The led comes out nice behind the white plexi and the effect is ok
    Allready connected 3 of them and 4 switches with the leds above them.
    Now onto the feet.
    I found these round feet on an old pioneer reciever I got laying around.
    I dremeled out the insides of all the feet (left on the picture) You see where I'm getting at?
    Here you see the bottom side of the cube (In the middle the luxeon, and in the 4 stars 4 white leds. they were allready there, so why not put them to good use.)
    Then I made these 50mm plexi disks that will go under the feet.
    Now there are no connection with the ground on the sides off the cube and it seems like its floating, and light is coming out underneath it.
    This is a really bad picture, but just to show how it looks. In real life the feet are much more bright, but the camera focused on the luxeon...
    Next thing was the wiring under the MOBO. Here it is al in place and ready to be hooked up (the right in the picture is the front of the cube.)
    To finish off, a little test setup when I was working on the Baybus.
    Thats it for today. Its just a small update, I hope you liked it.
    Greetz,
    Joungne
