Case Mod - Complete ⭐ Project: I.S.A.C - Thermaltake 2020 Case Mod Challenge Winner and MOTM July 2020
Discussion in 'Project Logs' started by The_Crapman, 29 Mar 2020.
  1. The_Crapman
    5 Dec 2011
    Hi-diddly-hey modderinos!
    Welcome to the project log of my entry in the Thermaltake 2020 Case Mod Challenge; Project: I.S.A.C. - themed on Tom Clancy's The Division 2, a game by Ubisoft Massive.
    For the competition, 5 of us have been given the same components to do a case mod with and we have until 15th June to complete our mods. I'll try and post regular updates to keep you updated on the progress. A huge thanks to all of the sponsors for making this competition possible; Thermaltake UK, Scan Computers UK, AMD, ASUS and Seagate. First off lets have look at the parts we'll be using for the mod:
    Thermaltake View 51 Tempered Glass Snow ARGB Edition
    Thermaltake Toughpower GF1 850W PSU
    Thermaltake ThoughRAM RGB 32GB 3000MHz
    Seagate FireCuda 520 500GB M.2 PCIe 4.0 NVMe SSD
    Seagate IronWolf Pro 14TB NAS 3.5" SATA HDD
    ASUS ROG Strix X570-F Gaming
    AMD Ryzen 7 3700X
    ASUS Radeon RX 5700 8GB
    300mm Thermaltake TT Premium PCIe 3.0 Extender
    Thermaltake TtMod Sleeved Cables & Combs Kit
    Pacific V-RX 5700 Series Plus GPU Waterblock
    Thermaltake Pacific C360 DDC Hard Tube Water Cooling Kit and Hard Tube Bending Kit
    Again huge thanks to Thermaltake UK, Scan Computers UK, AMD, ASUS and Seagate for sponsoring the competition. I'll be back soon with some progress, so stay tuned Crap fans. Same Crap time, same Crap channel.
    AcuteJungle66 and adidan like this.
  2. censored_Prometheus_
    censored_Prometheus_ Minimodder
    26 Mar 2019
    Intelligent system analytic computer and RGB backlight in fans?
  3. The_Crapman
    5 Dec 2011
    AcuteJungle66, kim and adidan like this.
  4. Cheapskate
    13 May 2007
    Is that Alex or Chris Cornell? My bandwidth is too crap to tell.
    MLyons likes this.
  5. adidan
    25 Mar 2009
    :rock::rock::rock::rock::rock:
    The_Crapman likes this.
  6. The_Crapman
    5 Dec 2011
    Yeh there's one of Alex and one of GN Steve. Just a little bit of fun to kick it off with, along with the fittings pipe and 'totally real' fire :hehe:
  7. adidan
    25 Mar 2009
    Looking forward to you bashing the bejesus out of the case mate.
    That's the correct technical term right?
  8. The_Crapman
    5 Dec 2011
    I believe it's called "ruining" :hehe:
    adidan likes this.
  9. kim
    kim hardware addict
    10 Jan 2016
    Mod on :dremel: :grin:
    Vault-Tec, Dot_Kappa and The_Crapman like this.
  10. Cheapskate
    13 May 2007
    "fittings pipe"
    I just figured you were a stoner. Apparently we are supposed to just show tolerance for thing like them stopping for green lights now.
  11. The_Crapman
    5 Dec 2011
    Oh not at all, I'm just a bit fat. The pipe was mearly a prop for comical effect. A barrow extendy bit and an ancient copper alphacool elbow.
    adidan likes this.
  12. Vault-Tec
    30 Aug 2015
    Old bullet here didn't even realise it was you in that video ffs. lmao.
    Good luck dude :D
  13. The_Crapman
    5 Dec 2011
    Thanks :thumb: I was going to originally have a working rig at the end and have my avatar as the desktop (as I do anyway), but time constraints forbid it.
  14. The_Crapman
    5 Dec 2011
    I've sometimes done builds where I have an idea in my head of what I want to do, I might even have sketched some quick plans of what I want, but when I come to actually do the build I find things don't fit in like I thought they would. Sometimes it can be solves with a couple more parts or fittings, but sometimes when things REALLY don't fit, you have to scrap then plan all together, or get drastic with a Dremel. :dremel::dremel::dremel:
    I had to make sure that all the components worked, so what better way to do that and get to know the case properly than do a complete build in it! Whilst this is quite different from the final configuration of the mod, it has allowed me to evaluate some of my design ideas while building and try/figure a few things out.
    So sit back, put your feet up and enjoy the ride.
  15. adidan
    25 Mar 2009
    Now smash it. :dremel::dremel::dremel:
  16. AcuteJungle66
    AcuteJungle66 AcuteJungle66
    3 Mar 2020
    I most definitely enjoyed the ride, nicely done mate!
  17. The_Crapman
    5 Dec 2011
    Kill the case, spill it's blood!
    Kill the case, spill it's blood!...
    adidan likes this.
  18. The_Crapman
    5 Dec 2011
    Just a few pictures from the test build, includes some "behind the scenes" (and by scenes i mean motherboard tray )
    A Spaghetti mess of cables
    Cable Management just means you managed to get them in, right?
    In these difficult times there's no tissue available for leak testing. Fingers crossed!
    Let's hope this isn't a warning :worried:
    Pretty from pretty much any angle.
    A look with the lights on (wish I'd taken a few more picks like this)
    All working A-OK
    While editing my mouse kept catching on something and I saw this poking off the bottom. 6-7 years of owning my R.A.T. 7 and this sticker has only just come off.
    I never thought editing would be such a PITA.
    Stay tuned Crap fans! Another little update should be hitting you soon. Same Crap time, same Crap Channel.
  19. adidan
    25 Mar 2009
    Craptastic!
    As for cables, yeah my policy is stuff it in and make it pretty (also the name of my sex tape).
    Boledile and The_Crapman like this.
  20. The_Crapman
    5 Dec 2011
    Ahoy hoy Modderinos!
    So now we've tested everything works. It's time to break it all down and start modding! :rock::dremel:
    I can't believe how well the case stood up to the pelting I gave it, just shows the quality of the finish on the case. There's a lot of sharp, jagged, pointy edges on those stones and they've really not done much at all. Really going to have to give it some welly to rough it up like I want.
    The brick on the other hand did manage to leave a mark....
    ....and a bit of a dent.....
    ....but nothing that wasn't easily fixable.
    Now it's time to get serious and bring out the big guns :dremel: :naughty:
    This will be my home for the next couple of months, best get comfortable.
    That's all for now folks. Don't worry, there's already PLENTY of damage dealt already for the next update, so stay tuned Crapfans! Same Crap time, same Crap Channel.
