Case Mod - Complete ⭐ Project: I.S.A.C - Thermaltake 2020 Case Mod Challenge Winner and MOTM July 2020
Discussion in 'Project Logs' started by The_Crapman, 29 Mar 2020.
  1. kim
    kim hardware addict
    10 Jan 2016
    Hard to find new words, Adidan used them all :grin: : Awesome, outstanding, fantastic, impressive...that's the feeling I'v got :clap:
    The_Crapman likes this.
  2. Vault-Tec
    30 Aug 2015
    Yeah as I said elsewhere, mind just totally blown. There really isn't anything else to say.
  3. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    Top job, that looks fantastic.
    I really appreciate it when people take the time to do things by hand instead of using CAD, laser cutting, milling, 3D printing, etc. Don't get me wrong, people can get absolutely amazing results with that sort of stuff, but to me it's more impressive when people get such amazing results through doing stuff manually with power tools.
    Voted, btw :thumb:
  4. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Thank you everyone. I'm so pleased how it's turned out. I'm going to start the write-up for the last week or so of the build tomorrow, now I've had time to recover. Mad to think how much got done in the time frame, although a lot of prep work had been done before hand and it all came together very quickly in the end from seemingly nowhere. Although some bits offered some stern unnecessary resistance. :hehe:
  5. The_Crapman
    5 Dec 2011
    On the 15th July, WarBoys commented:
    I thought that was a bit cheeky given how much work I'd put in so far, little did I know he wasn't wrong and the next 2 weeks would descend into chaotic hell I can only now talk about without being reduced to tears. It's been a difficult couple of years, today should have been my wedding day, but instead I'll make do with cricket commentary and build logs.
    As a sign of just how right WarBoys was, the following and final log will be in 13 parts. 15 including final pics! :eeek: At this stage I was doing about 5 things at once and I could tell the story in actual chronological order, but it would be like a reverse Tarantino and would just be a bit of a mess. Instead I've tried to pluck out threads of parts from the chaos and form some sort of orderly fashion. There are little things that may be missed, but it will make a heck of a lot more sense and at this stage, such was my urgency that I started to forget to take pictures of entire processes. If you have any questions just ask, but maybe wait till all 15 parts are up (will be posted as simultaneously as possible).
    Part 1 of 15
    Lets start with the cables. I shown you I'd started on them previously, having measured the required lengths, cut then crimped.
    Next up was to start the process of getting them soldered to the female side of the aviator connectors. This would be done in the comfort of the front room. lol
    First job was to get a good blob of solder on the terminals of the connectors.
    All 13 done and I was pretty pleased with the job I'd done seeing as how I was a soldering noob.
    As usual I had my little mod mate Ralph at my heals supervising.
    Then I stripped the other end of the wires and tinned them. Once tinned, I could hold the wire to the soldered terminal and heat with the iron to melt the 2 together. Had to be careful to get the natural curvature of the wire in the right direction. There were also 3 different length of wire for the 24pin and EPS lines, so had to be careful to solder the right length to the right terminal too. I labelled them all too to make sure they then went to the right motherboard connector.
    You may have noticed that there are 2 white wires standing out, being used for one of the longer GPU connectors. This is just one of the 'dramas' that befell me in the wiring saga. My original plan, from the design submitted for the competition, was to have the cables bundled inside steel braiding, the type you often see around hoses in an engine bay. I'd already got a sample of it for a proof of concept, but the pandemic dried up all sources of the braiding by itself without paying astronomical prices, postage and then likely import tax to get it from the states. Next I turned to braided shielding 4 core cable, but the thinnest core cable I could get was too thick for the aviator connectors, as was the 18AWG wire I got from pexon :duh:.
    Luckily I had this orange wire I'd bought ages ago when I had orange coolant in my personal rig that was still "18AWG", but just a smidge thinner than the Pexon and had a silicon sheathing that would give a bit more and just fit. However, in the process of figuring out the correct lengths required for all the connectors, some stripper mishaps and just plain bad measuring on my part, I'd ended up just 2 lengths short so had to use the pexon wire. This also meant changes to how the 6pin PCIE connector would be wired, for 2 sets of 3 to 1 set of 4 and 1 set of 2. This would probably work out for the best as I could pull the 2 slightly thicker wires in between the 8pin and the other 6pin wires. Not that you can even tell in the end result.
    Next up were the rear cables to connect up the PSU to the male aviator connectors. First job was working out which terminals on the PSU went to which terminal of the 24pin. This was not as straight forward as I was hoping, the layout is nowhere near the same and there were 4 terminals on the motherboard side that had 2 cables from the PSU.
    After a double check and a reverse check, I attempted to remove the cables from the PSU connectors to reuse them, waste not want recycling and all that. Only they would not budge. I couldn't get them out for love nor money so there was only one thing for it, chop of the 24in and use the existing cables!
    After labelling each cable for where it went in the 24pin, I bundled then into there aviator connector groups and got to work splicing the doubles together.
    I managed to not take any pictures of the sleeving and soldering of rear cables and I didn't get any pictures of the GPU or EPS process. This is probably due to the difficulty I had in getting into a reasonably comfortable position. I needed the case next to me as I needed to get the lengths right and the orientation and twist on the wires would play a big part. As the rear section would be a horrid dank and dirty affair, the last thing i wanted was pristine sleeving and cable combs, so the cables would need to be able to hold themselves inside the grey SATA sleeving I'd be using. I went from the desk upstairs, to the dining table to the sofa to upstairs to dining table and finally, made a soldering den on the floor of the lounge.
    End of Part 1 of 15
    ivory2k19 likes this.
  6. The_Crapman
    5 Dec 2011
    Part 2 of 15
    In the end they came out alright, despite the trials and tribulations of their production.
    The poor old soldering iron had taken a beating too.
    With the main rear section cables complete, It was time to finished the front section with some nifty sleeving in the 'The Division' colours of Black, White and Orange. Heatshrinked at both ends to keep it from going anywhere as I'd had to keep it short and tight to fit it through the covers on the aviator connectors.
    Was pretty tricky slipping them on, had to put 2 cables through first, then slip the 3rd in in the tiny space between the other 2. The 4th was an ordeal, having to get the other 3 cables exactly where they should be, pull the 4th into position where you could just get the terminal through, then grab hold of all 4 and pull the cover down. Then there was a tricky twist at the end to lock it in. There was really very little room for manoeuvre once on and if they weren't in the right place once on it'd have to come off for another go.
    Then I only had the motherboard connectors to fit, just push it in... just push it in... push...... in....... nope. They're not going in. :sigh: I'd given the ends a quick blast with the lighter to prevent fraying whilst being pushed on. That slight bump from the melted sleeve plus heatshrink was just too much to push in for most of them.
    At this point it was 4 in the morning. I was distraught at the thought of having to take all the sleeving off and start again, with no idea for how to avoid fraying the ends. So I took myself off to bed to try again the next morning. At this point (23rd July) my body was already suffering badly from having to step up my work volume. This was how much I could clench my hand in the morning when I first woke up.
    After a coffee or 2 it was back to the sleeving. I worked out that I could get the tip of a knife of tweezers under the heatshrink to loosen it and allow me to pull it back to insert the terminal into the connector ( :eyebrow: ) then release it and it would jut up nicely against the connector. I still had quite a difficulty getting a couple in having to try and grab the very end with needle nose pliers to push it in. I eventually worked out the the crimping wasn't quite as tight as it should have been (likely due to my cheap ebay crimper or using slightly the wrong size). A quick squeeze with the pliers and they were slimmed up and slid in fine, still catching well inside the connector.
    Finished! :grin:
    End of Part 2 of 15
  7. The_Crapman
    5 Dec 2011
    Part 3 of 15
    With the cables pretty much sorted, lets look at some pretty metalwork. I didn't want to leave the rads as great swathes of black, so got some stainless steel louvres to cover them with. The louvres are only 90-100m wide, but a good 10mm deep so will still give plenty of ventilation. As the thin rad would be being placed under the case as exhaust, it would probably improve the performance, directing airflow out to the back of the case instead of straight down into the desk.
    I couldn't get any the right size, so some chopping would be in order. Such an awkward shape to get a cutting device in there. being stainless steel it would eat Dremel wheels for breakfast, so it would have to be the Jigsaw.
    After cutting the panel in 2 and trimming some from what was the outer edge, I had to decide how I'd arrange the louvres. For the thick rad that's going in the vertical slot, I didn't want a louvre right at the bottom edge as it might interfere with the fans for the bottom rad and other things going on in the bottom of the case. This would then be attached by 1" aluminium angle (in the background)
    As if it was meant to be, the aluminium angle sat perfectly against the louvres, keeping them nice and central. The thinner rad is also not as wide, so used half inch angle instead. You might see the holes for the screws are, well, rubbish :hehe: Don't ask me what was going on, just went a bit measurement blind.
    With the protective plastic off, the alu angle cleaned up and some chrome screws with brass washers, you can't even tell and it looks so good.
    The motherboard tray and rad surround got brushed up and a rub down with WD40 to both protect and bring out the shine. Not that you can tell from the terrible picture. (light, dam it man! :rollingeyes:)
    Thermaltake make a massive variety of fittings and adapters in all sorts of colours. I had wanted some that were a straight 90 and combined fitting for the front, rather than the slightly bulkier adapter plus a fitting. Unfortunately with supplies cut off from COVID, I could only get them in black. But where there's a will (and a Dremel) there's a way :dremel:
    With the black paint removed by way of an abrasive wheel, it revealed the beautiful solid brass body beneath.
    With a very warn wheel, where there was a solid core, I was able to remove the indented lines to make it a bit more solid looking. The line didn't look right with the brass and really improved the 'OEM' feel to the final result.
    Just Beautiful :baby:
    End of Part 3 of 15
  8. The_Crapman
    5 Dec 2011
    Part 4 of 15
    With a lot of ancillaries done lets turn our intention back to the case. First up was the front IO panel and the corresponding strip across the top of the case. These received a strip of the mild steel used for the internal panels, but with the crap beaten out of it, plus I'd removed most of the plastic ventilation holes in preparation for it's replacement mesh. I also put in a couple of holes for the obligatory anti-vandal switches.
    But not without drilling them too high and running into clearance issues internally :duh: A bit of dremel action solved that.
    As for the main case, it had had some damage beat into it in brutal fashion, but it still needed a fair bit of work to achieve the look I wanted. The first stage happened entirely by accident. I'd moved the case with some JB Weld on my hands from the parts I'd just glued and it had rubbed off onto the case. At first I was annoyed but after a bit more rubbing, it actually looked pretty good, an added dirt effect. So I went over the case with the leftover glue, just to give it a light smudge of dirt.
    Next up was some proper paints: AK's rust streaks and dark yellow enamel wash. Their application was far from 'proper' though, using a combination of old paper towels and scotch pads to apply and remove paint till there was a uneven base coat inside.
    You can see some new holes that have been drilled in the top right, more on those later :naughty:
    Externally was more about highlighting the damaged metal with rust spots, as well as general grubbiness. It was tricky to get them on and looking "right" having to apply and remove quite a few times till it looked good. I also attached some aluminium extruded mesh to the vents and aged that up with paint too.
    After that first pass had dried properly I went back to further accentuate with more rust and some run-off streaks.
    Internally I layered it up in the corners and creases where dust and debris would collect.
    End of part 4 of 15
  9. The_Crapman
    5 Dec 2011
    Part 5 of 15
    Next up for the "dirtification" was the internal components. First the PSU which I also removed some of the paint from the corners and edges using a needle file, followed closely by the vaccum. lol Labels and panel covering would also get roughed up before getting some paint on using a sponge, as well as the pump/res.
    I still needed to do a bit of cable work in the back. Firstly the SATA power, which was trimmed down and a connector removed in between the 2 I needed. I pulled the cable apart and applied some electrical tape where that connector had been.
    With those and the pump cables all sleeved they looked far to clean to be living back there. :nono:
    Much better :thumb:
    The power and reset switches would also need similar treatment.
    Seeing as though they would pop out in the front sectionm to connect to the motherboard, I sleeved the end section like the power cables and swapped the 2 seperate 4pin connectors into 1 8pin for neatness and simplicity.
    The CPU and GPU block RGB cables got re-sleeved to. I may be making them look a mess on purpose, but they'll be a purposeful custom mess! :lol:
    End of part 5 of 15
  10. The_Crapman
    5 Dec 2011
    Part 6 of 15
    Next on the agenda we have the case feet, and I figured plastic case feet wouldn't have made it, so would be replaced with 1"x!!x1/8" thicccccc aluminium U channel and attached and supported by some heavy M16 threaded action
    This meant some big holes in the bottom of the case, a couple of which needed some additional "amendments" to allow the bolts to sit on the bottom properly.
    Finished off with some Dome nuts for extra lift and to provide breathing room for the bottom rad.
    I also stripped the paint from the bottom and rear panels inside the front chamber with an abrasive wheel and wire wheel. This was much more difficult than anticipated. I had wanted to dismantle the case to allow decent access for painting and paint removal, but with a month getting knocked off the build time and not wanting to weaken the case too much. It was so awkward getting into the corners and other nooks and crannies.
    Next up a nifty little piece I knocked up that's purely for aesthetics and for the theme of the build, but also happens to feature some nice chunks of metal.
    A test tube holder!
    The longer piece of angle sits on the bottom preventing the test tubes falling out and also has holes drilled into it so it can be attached to a fan to keep it secure and upright.
    This is the kind of thing that happens when you're tired, rushing and not paying attention. Dropped my drill on a can of cutting lube, narrowly avoiding taking the resulting explosion to the face and reacted quickly enough to chuck it out of the shed to stop it spraying over everything. :duh:
    It also broke my only 3.3mm bit used for M3 bolt holes. :wallbash:
    End of part 6 of 15
  11. The_Crapman
    5 Dec 2011
    Part 7 of 15
    Now while there will be 9 LED fans in the case, their LEDs will be more used for a decorative theming purpose, rather than illumination. There's going to be a lot of features and highlights, so I'll be using 6 high SMD LED strips in the case. 4 bright white in the fron, 2 warm white in the back. They'll be mounted in aluminium LED housing, these 2 for the top of the case have been drilled and bolted in.
    The ones for the front panel would need to be re-sleeved. The first one I did had got some glue in the sleeving and I ended up pulling out one of the wires :rollingeyes:
    Time to put my new found soldering skills to the test. It was attached, but would it work?
    Lazarus!
    The LED strips to be put in the bottom were sleeved in grey to fit the metallic scheme
    Bit of heavy duty double sided tape and they were stuck fast to the newly manicured interior. You can also see the brass G1/8 fittings I'd be using as pass-through ports for the cables.
    The top LEDs I sleeved in white to match the fan mount, which had been left intact to help with the illumination. But what's that PCB at the back of the case?
    If you remember the new holes in the back, they're for a PCI bracket fan controller which I'll use to adjust the brightness of the LEDs
    In amongst the chaos and calamity, there were of course moments where things just came together and worked, like the LED control which at one point I had a dreaded feeling was genuine 4pin pwm control, but thankfully cheap chinesium rules applied and it was in fact voltage controlled. Another was the VERY close proximity of motherboard tray to upper fan bracket and the LED strip to the EPS cables. so many measurements coming together to fit perfectly. :rock:
    End of Part 7 of 15
  12. The_Crapman
    5 Dec 2011
    Part 8 of 15
    Something I'd had on the to do list for quite some time but for one reason or another had put off, was getting the custom graphics etched into the glass panels.
    The guys at 4D Model Shop had done a fantastic job with the vinyls and I was so glad I paid the extra to have them do the weeding.
    I'd marked 3 lines on the masking tape alignment marker and the back of the vinyl to make sure I got it in the right place, which was off-centred thanks to the asymmetrical frame. I gave it a good squeegeeing to remove any bubbles from the edges, there were a few in the middle but nothing damaging.
    The etching process was fairly straight forward. I started the timer from when I'd finished applying, giving it a bit of a dab about with the brush at 1.5 min and 3.5 min mark and then began to remove it after 5 mins. When removing it, it seemed to have taken quite well then i wiped with a wet cloth and seemingly just wiped it completely off :worried: It turned out it was fine, they is a layer that gets a little attached, but once wiped and rinsed you're left with the etched surface of the glass, which needs to dry a minute to see the full effect. Came out perfect! :clap:
    As did the others :grin: They were then glued back into their prospective frames. Please forgive the local and backdrop, it was the only place left large enough to house them all. lol
    You may also notice a small strip of alu angle on the bottom edge of the front window. The foot section house the bottom lip and this was a quick fix to prevent any slippage, not that there probably would have been given all the glue I'd used. lol
    This was the start of the build, all the mods complete, it looks pretty messy but it's actually fairly organised, for me anyway. But this was the decent into sleep deprived madness. lol
    To prevent getting finger prints everywhere I tried wearing gloves, but when previously wearing them my hands get disgustingly sweaty, so I made some sweatbands from old socks :hehe:
    First issue, I'd managed to damage one of the terminals in the CPU RGB extention, so I had to splice them into the controller cable. You can just see the squished terminal in the middle of the cables, took an age to figure out what the problem was as hadn't done anything with it since taking the demo rig apart 3 months ago. I thought it was the wrong connector and was trying to find ones that match up to either end before I realised what the problem was.
    After installing those bottom LED strips, the first and what should have been straight forward simple job was to get all the ancillary cables through the holes in the motherboard tray and get it attached.
    4 hours. It took 4 hours to get the dam thing attached properly with all the cables through.
    The brass g1/8 fittings I was using for the LED cables should have been simply attached with a G1/8 nut that I'd bought. NOPE. The threads on the fittings were tapered and the nut didn't go up high enough to attached it securely to the tray. Joy. Rummage round in my box of crap, find a bag of smaller aviator connectors I'd bought and deemed too small, pinch the nuts which are a little oversized, but act great as washers. problem solved.
    It's a bit of a struggle getting the tray in position with all the cables on the lower right corner coming through and having them orientated properly, but I manage it. Start putting in the motherboard standoffs to connect it, get to the middle right one and there's a big gap that wont close properly. Very odd. Check everything over and find that my new washer solution for the fittings is too fat, hiting the original motherboard tray and stopping the new one attach properly.
    Everything off. Attach the fittings to the tray using cable ties, tied round the base to keep them in check. They don't form any part of structural integrity so as long as they stay put, sod it! Get the tray back on, get down to the bottom where I've drilled new holes to keep it steady and I've forgotten to attached the standoffs for them. :duh: Back off then.
    Attach lower stand-offs. Attempt 4. Cables in the bottom left being SUCH a PITA, takes an age to get them to play ball so I can get the lower right corner attached. get down to the bottom left, it won't go on. Theres an old screw thread that protrudes from the bottom of the case that it's snagged on and wont get past it without damaging something. I know it's there, Iknow I've got to slide the tray round it, but with the new lower standoffs the bottom edge of the tray wont go back as far and I haven't made sure it's not past it. back off.
    Attempt 5. Lower right cables again pissing me off, big time, sworn into submission after an age. Get to the last mother board standoff in the bottom middle, it's out of alignment. Everything else exerting force on the tray has shifted it enough that I can't get the thread to catch and not end up at and angle. I remove a couple next to it and file it bigger, being careful at first, but gradually lose patience and hammer the ****er with a bigger file, vac up the dust.
    4 hours after I started the motherboard tray is finally on. It should have taken 4 minutes. Not 4 hours. But it's on.
    Can only get better from here, right? :eyebrow:
    End of part 8 of 15
  13. The_Crapman
    5 Dec 2011
    Part 9 of 15
    Finally The case was ready for some actual components. Best get the motherboard ship shape with new thermal pads on the VRM and M.2
    here you can see the additional detailing I did in the back, with some heavier streaks off the cable tie points and a very dirty bottom of the case, making it look like it's flowed to the drain hole. I also got the fans and verticle rad attached with the Thermaltake drainvalve underneath. Nice and simple.....
    Nice and simple until I realise I've left one of the temporary G1/4 port plug on the rad and it needs swapping for a proper one. I try just loosening the screws and swapping it without tasking it all off, but can't quite get it. I stop and think "you always try and do this, make 'less work' but ends up taking far longer, just take them off and do it properly." so I take the rad and fans off and swap the plug out. Can I get the rad and fans back on? Can I ##########
    I try the top fan first, I try the bottom fan first, I try the middle fan first! I can manage to get up to and half the screws in then just can't get it lined up for the rest. I JUST had this one, how is it not goin back on!!!??? Notice the rad is getting blocked a little by the drain port on the bottom, really weird seeing as how I attached that to the rad before installing it the first time. So I take that off, put a plug in it, it's still a real struggle to get them all on, but eventually I manage it. 1.5 hours later. ONE AND A HALF HOURS to put a rad and fan back where they had just been, but sans drain port. That is no where near fitting. Just does not compute??? Cursed I tell thee!
    But it's on, I get the motherboard on, looking good. Got the 3 brass fittings for the fan cables in, looking good. On the up from here.
    Or not. :wallbash:
    I take the siding off the rad, screw the valve into the passthrough, go to put the panel back on, won't go on. It just won't, no matter how hard I try and something is getting broken in a minute. So have to take the rad and fans off. Again. Get the rad cover sorted eventually, Rad and fans go back on without putting up too much of a fight, but it's more time lost to complete lunacy. or more likely a total lack of sleep. lol
    With that sorted I can get to work on the loop.
    My 2nd ever bent piece of hardline. It's a bit of an odd one, the pipe has to go under the 24pin cable, then up, round and back into the CPU block. I had wanted that to be more of a continual curve, but it was much harder to heat up an area of the PETG evenly than I thought. I kind of botched my way into this piece that worked, so with time not being on my side would do.
    The heavens opened, bringing a bit a coolness to the air that was desperately needed.
    Both the weather and this cable tie point reflecting my mood at the time. Tired, battered, dejected. Gotta push on.
    Got this long run from the bottom corner to the res done in one go, pretty pleased with that.
    In this pic we can also see all the fan cable down the bottom. I'd taken the stock sleeving off ages ago, as it's massive, stiff and unyielding. The plan was to sleeve it with tinned copper braid. I'd got the braiding, had a test go with a bit of wire off another fan it seemed to go ok. I checked how long I'd need the wire, snipped the connector off and cut the wire to size as I had new terminals to crimp on the wire. But because by this point I'd had about 4 hours sleep in the last 72 and I was running out of motor skills, time and patience. I just could not get the wire through the braiding, It kept on snagging on this one bit and after getting past it, just couldn't feed the wire to move up through the braiding. I had to make a call and cull the braiding. At least I could still get all the cables cut to length and it would still look better than stock.
    So I took out the terminals and got to crimping, or at least I would have, but a combination of my tired decrepit postman pat hands and a crimping tool not suitable for such a small terminal just could not get it crimped properly. I ended up splicing the cable back into the connector I'd cut off. Quick test with a spare psu and controller confirmed it still worked, at least I hadn't killed it. I just had to forget it, 'cable manage' as best I could and push on. Time was desperately running out.
    And it did. No idea where the time went. I had a little trouble with the GPU bracket I think. That's another think that's got missed in the rush. I had to cut the back off the bracket having installed a new motherboard tray and removed about 10mm of space it used to occupy. This made it fairly flimsy, so I put a new screw hole on the back left edge and made a support bracket from 1/2" aluminium angle. The support bracket comprised of 1 piece attached to the bottom fan to keep it nice and solid, with 2 vertical struts bolted in tight that the original bracket would then rest on. No GPU sag here. :thumb:
    I got a couple more runs done, had some trouble with the small run at the front because I didn't realise they weren't level. The run from CPU out to GPU in round the back was meant to just be a solid extension, but no combination of pieces I had fit properly. I tried so many combinations of 90s, 45s and extensions. I think one fit, just, but looked absolutely ridiculous as it used about a dozen different pieces. It was also too short for a small straight piece. I had decided to tray a 45 into a 90, but offset so the angle would probably be more like 30degrees and was beyond my mental capacity at that point.
    I was so tired and drained I could barely stand or talk. so I just crawled off to bed and left it. Failing terribly.
    End of Part 9 of 15
  14. The_Crapman
    5 Dec 2011
    Part 10 of 15
    Needless to say I had a fair old lie in the next morning. Had to take a few to wake up and my hands to loosen up before getting back on it. First thing I notice with refreshed eyes is the the weird CPU loop has got to go. Apart from just plain looking pants, it will interferewith the GPU out loop.
    An afternoon later and we're done. I think the only line I didn't redo in the front was the one round the back of the GPU.
    I'd figured a way of using tape to help mark where the bend had to start so that when I took it away there was no doubt where that bend was going. Everything tight, level and with some nice symmetry to the runs.
    That front run with the little level change was daunting, but I just heated a small spot, held the bend flat to the table and pulled the end up. Fit beautifully.
    I gave all the fittings, o-rings and tubes a good clean and tidied up the ends, made sure there was no rough or sharp edges and got rid of the tape marks.
    The tight bend in the back I also ended up doing by hand as it was tighter than any of angles offered on the mandrels. Took a few goes to get it right, but by jove we did it!
    The keen eyed of you will see the future in this picture :worried:
    It's loop filling time! Non of that fancy air pressure nonsense, just good ol' fashioned tissue.
    Warning. The following video contains strong language and scenes of a disturbing nature.
    Yep, I'd left the rear drain valve open :duh: Good job it was pointing straight down next to the massive hole in the bottom of the case, so the majority of it flowed out onto the mat below and what remained inside didn;t get very far or near anything shocking.
    After that little mishap it was plain sailing. Get it filled up no further problems, no leaks. :rock:
    I'd made the PSU a cagoule incase there were any "mishaps" in it's vicinity :hehe:
    It was so close to being finished, I could feel it, like it was just over my shoulder.
    End of part 10 of 15
  15. The_Crapman
    5 Dec 2011
    Part 11 of 15
    With no leaks overnight All the tissue could be done away with and the power cables installed. I hadn't been too sure about them until I got them in and caressed them into shape with the combs from the extension set we'd been given. Once in though, :jawdrop: I installed all the rear cables, the top fans bracket with fans and LEDs and attached external panels, but of course forget to take any pics of that :rollingeyes:
    Now we have to travel back in time, way back to the 13th July for the genesis of the next feature. 1000x600mm of 1" hole galvanised steel mesh, 6m of 37mm galvanised steel angle and a bunch of corner braces to make this beast a cage!
    First up was cutting the mesh to size. I started with the dremel but it was slow going as the wire was so thick. The hecksaw made quick work of it however and gave cleaner tighter cuts.
    Typically for me, the first piece I cut I cut the wrong size, meaning there wasn't enough to make the other 2 pieces the size I wanted. luckily I could just fit 2 pieces big enough in that would still work.
    Next up was to cut the steel angle to size, with angled cuts where 2 pieces would meet. This was jigsaw territory, made light work of the steel.
    Along the bottom edge of the cage I would only need one side of the angle and small lip to cover the mesh. This was done in 3 goes with the jigsaw, moving the clamps as the cut progressed.
    Soon had the 9 sections needed cut out
    Then I started to make the sides up, joining them with the corner braces. I marked up the braces with which angle they joined with and where. This would make sure there were no cock-ups come assembly time when all the holes were out of alignment.
    Coming together nicely. When there was crossover between 2 sides on the braces, I'd keep the first side built and connected so they would sit as they would in final form.
    End of part 11 of 15
  16. The_Crapman
    5 Dec 2011
    Part 12 of 15
    I cut out one section of braces for the lower corners, to let it fit round the case.
    With all sides complete it was time to start figuring out the mesh attachment, with where the bolts could go through without fouling on the mesh and drilling out the holes.
    The mesh would be attached using 1.5-2" sections of the angle made from the offcuts. These were then drilled out with holes to match the main pieces (with mesh in place of course). These were all individually marked on both pieces so there was no mistaking what went there.
    With everything marked up the wazoo, there was nothing left top chance and it was time to construct. Nothing could go wro...... Oh, the bolts I've got aren't long enough. So with 32 pieces cut and 102 holes drilled that was as far as I could go.
    Fast forward 2 weeks and I had the new longer bolts, it was assembly time. This was done on the shed floor, which was so, so uncomfortable. Quite painful even. I'm not currently formatted for floor work. lol
    But he got built! And to even my surprise it was pretty darn sturdy :clap: Bit of JB Weld used as locktite and you could actually use it to keep things safe :hehe:
    That was it. Everything was built. Everything was finished. All I had to do was put the cage on and.... it doesn't fit :sigh: I had done all my test fittings without the side window hinges on the case and they interfered with the back edge of the cage. I could probably have cut a couple of notches in it, but by this point I was at the end of my tether, so I lopped the entire back edge off. At least it now fit! ha ha
    Oh yeh and at some point I'd attached a staple loops to the top and front. another thing I forgot to document. There's probably more, but who knows? lol
    End of part 12 of 15
  17. The_Crapman
    5 Dec 2011
    Part 13 of 15
    So that was it. I was finally finished. there had been some absolute nightmarish, soul destroying mishaps and moments in the last few days. I was so, so tired, my body was crying and I was emotionally drained. But at least it was finished and I could get on with the video.
    I had taken some pics with the case on when I first finished, but then realised the cage had red pen all over it. So had turned it off and given it a good clean before getting those pics above. I took the cage off and then thought "I should probably get some pics of the pc on with the clean cage". So I put the cage went back on, back on go the locks and....
    Taking the key out of the last lock and the barrel just comes out with it. It just had to **** with me one last time. I was absolutely distraught. How am I going to get this off? Anything I do to cut it is just going to send shards of steel everywhere, I can't take the cage apart, it dam near killed me making it in the first place. Resigned to taking the cage apart, find I've built it too well and it's not going anywhere. Fall onto floor crying. Like i said at the beginning, it's been a difficult 2 years. lol
    Luckily a few folk here and elsewhere talked me down and helped me to the realisation that I could cover it up with something and cut carefully and I should be fine. So
    Here's the after shot. You get a good view of the staple and also the mesh I put in the top panel that i forgot to take any pics of or record in any way. I don't do rushed. lol
    And the cage and case survived! :clap:
    One last little snippet, the test tube contents. For those who don't know, The Division series is set in a time when a genetically engineered flu has been released. All the test tubes contain samples of things you'd find in the game.
    Fro Right to left:
    1) Green Poison - the virus unleashed in New York on Black Friday using contaminated money, which is why it's also know as th 'Dollar Flu'. This isThermaltake P1000 pastel green coolant
    2) E. Shaw's Blood Sample - Emeline Shaw is the head of one of the enemy factions know as The Outcasts. Emeline is an asymptomatic carrier and upon her downfall (at your hand), it is said that they can use a sample of her blood to help develop a cure. This is made from Paprika and water.
    3) DC-62 - an anti-viral agent that was released in the worst contaminated areas, however in extreme cold temperatures, the DC-62 changed and became toxic and as deadly as the virus itself. These quarantined contaminated areas form the games 'Dark Zone' PvP areas. You sometimes get dust storms of DC-62 in the games weather patterns. This is made from dry turmeric, as the DC-62 in the game is also a powder
    4) Anti-viral sample - in a secret underground lab in DC, scientists had been working on an anti-viral to combat the Green Poison. This was stolen by President Ellis and given to the Black Tusk, a paramilitary group trying to take over America, to whom he defects. You get back the sample of the anti-viral after defeating Milla "Wyvern" Radek at the end of the Black Tusks Styronghold mission 'Tidal Basin'. This is just some distilled water.
    End of part 13 of 15
    ivory2k19 and cobalt6700 like this.
  18. The_Crapman
    5 Dec 2011
    Now the moment you've all been waiting for, the final glory shots. These were all taken right after I finished, so they may not be as spot on as they could be. There are so many angles I could cover, so many details to pick out, I may well take some more when I've tackled tidying the room. :hehe: Until then, enjoy the pics and don't forget to vote for me in the competition!
    Size Warning - All these pics will be posted in original size without hyperlinks you can enlarge them to your hearts content. :thumb:
    End of part 14 of 15
  19. The_Crapman
    5 Dec 2011
    Part 15 of 15
    That's all for now folks! Now go and vote! Thanks to everyone who's helped and supported me throughout the process. This community is just the best :thumb:
    And thank you for the MOTM nomination! :grin: :rock: :clap:
    ASPHIAX, lowfat, ivory2k19 and 4 others like this.
  20. Defyant Mods
    Defyant Mods Multimodder
    14 Sep 2004
    AMAZING! You accomplished such a high standard of modding in such a short period :rock::rock: You got my vote :thumb:
