project: i-spider |stacker mod | 11-4: up and running (again)
Discussion in 'Project Logs' started by _ferry_, 19 Aug 2004.
  1. FragK
    FragK What's a Dremel?
    18 Jul 2005
    Supergeil man, dat witte licht!
    Keep it up :D
  2. Sub-Zero
    Sub-Zero What's a Dremel?
    6 Feb 2005
    Soon my mod(Obsidian-Spire) will become something that can stand any competition, even your! :D :rock:
    You have taken some inspiration from my mod(extension), now i will take some of you!(but not 1:1)!
    Maybe we will challenge at the coolermaster casemod competetion, but I´m not sure that my mod will be finished.
    Keep up work!
  3. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    Thanks, i'm interested how your's gonna look like.
    Mine would be finished neither, but finished far enough to work on it. (watercooling running, and mounted mobo+cpu etc.)
  4. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Super work!
    Looks like a pro case!
    Whats your budget on this projekt?
  5. c.cam108
    c.cam108 Minimodder
    14 Feb 2004
    Looking great! You really do give a lot of attention to detail.
    I especially love the wire routing using the break cables (maybe just because I'm obsessive compulsive and I like things to be in right angles and straight lines).
    _C
  6. simosaurus
    simosaurus What's a Dremel?
    12 Jun 2005
    ohh wow, that lit up piece of perspex looks amazing, like something from a film set :eek:
  7. horgboy
    horgboy haisup
    25 Mar 2005
    looks like another winner at the coolermaster casemod comp 2 me
    /subscribed
  8. _ferry_
    22 Apr 2004
    Thanks all :D The feedback is very supporting :D it keeps me modding ;)
    Not very large, i'm a 19years student, almost all the money that i earn i used to buy casemod parts or tools. So i'm very happy with my sponsors :)
    On the other way it's good to have an small budget, because you must make everithing by yourself instead of purcasing it. To prevent getting a premod case ;)
  9. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Impressive. Now hurry this a lil bit up. :D
  10. _ferry_
    22 Apr 2004
    update
    The system is up and running, NOT finished, but it works ;)
    Mounting the plexi piece on the meshX (bottom view)
    Both pumps
    Mounted the watercooling stuff. Note that there is only 1 way to mount it/remove it. 2 stackers, and still few space left :(
    I still had to make this grill. Done now ;)
    My new procc.
    Up and runnig, a very special moment :D Also because this is the 1337'th pic i made with my camera :eek:
    The inside (the p-ata cables will be removed)
    No, it isn't a strange color in the water, only a large amount of air. second note is the red tape, it covers the fill-hole on top (the water would otherwise came out trough it :(
    Tonight i made the sides around the lower grill
    a sand blasted spider web on the sidepanel. I want o make something on the top windows too.
    I hope to finish the uppergrill this week too. And do some other small things, depends on the time i've got left ;)
  11. striker289
    striker289 What's a Dremel?
    22 Jan 2005
    thats freakin awsome *two thrumbs up*
  12. invalid
    invalid What's a Dremel?
    23 Jan 2005
    Been following this for a while now. Really like the mod and everything all around.
    On the chasis painting, how is it now? ie is it sensitive? I am painting my chasis black and am worried about how easy afterwards it will be to chip it.
    Thanks for any insight you can give to this.
  13. _ferry_
    22 Apr 2004
    I expected the paint to be a little bit stroger. On flat parts it's not a problem, but on points where you slide the sidepanels over, or slide in the HDD brackets it comes off a bit. Not a real problem, it isn't a powder coat. So i must live with it ;) It looks better than the sandard color anyway ;)
  14. toyomatt84
    toyomatt84 What's a Dremel?
    1 Jun 2004
    Good, clean mod. It's well-done, and I like it. Nice work, bro!
  15. Sub-Zero
    6 Feb 2005
    hello ferry,
    very very very nice mod!
    I have Problems with my white led´s in my plexi. It isn´t brighthly enough, I have 4 led´s mounted in one plexi, each 6000 mcd.!???!! How did you get it so brightly.?????
    You will be the winner of the contest :thumb: , i haven´t enough money to buy the parts that I need to go forward with my mod...
  16. _ferry_
    22 Apr 2004
    Thanks all, i love to get some feedback ;)
    Hi :)
    I'm using 120 degree led's with a output of 1200mcd, that doesn't seems to be much, but you could compare it with your led's i think. (because the wide angle) so might you could try another setup of the leds?
  17. Sub-Zero
    6 Feb 2005
    hmmm, I will try it with wide angle LED´s, that means i will make it myself. just fill of the led´s.... :D but i don´t think that will solve my problem...
    mhh, a thought: Do you use normal plexi???
  18. _ferry_
    22 Apr 2004
    Jes, normal plexi, 5mm, i also used some 2mm and that worked fine as well.
  19. _ferry_
    22 Apr 2004
    update
    Well, today i went to a +/- 2000 visitor's LAN party in the netherlands, i won the 2'nd price on the casemod competition, very aceptable for a casemod that is'nt finished at all (past year i was 2'nd too ;) )
    Anyway, hier enkele pics:
    I finished the sidepanel, and made a piece beyond it for casebadges.
    Because there is a piece of alu in front and beyond the window you get a nice depth.
    On thursday i received some CCFL's, all of them in UV, i was short in time, so i was only able to place the 20cm CCFL's on the front.
    I replaced the standard packages for some smaller ones
    2 pictures on the casemod contest, here you can see the result of the 20cm CCFL's. And the price's i won.
  20. well done mate. well deserved! great mod so far, but is it big enough?!!
