Congrats man! I am liking stackers more and more everyday because of your mod. BTW, how is the epox mobo?
Thanks, it works fine, Hav'nt done any OCíng, but it's my 2nd epox mobo, and it's very complete, status led's, nice post screen, many bios options, good voltage range for OC'ing. And offcourse the RAM-VU meter You can buy it at a bicycle shop
What second???!!! That´s not possible!!!? is there somebody whose mod is better then yours?!?!?!?!?! Can you show us the guy who won the first place??? For me you are the winner!
grtz with you're 2nd place I really like the light effects and as I hear you talking I think it will only get better [dutch mode] Ik wou dat ik in Nederland was; hier in België organiseren ze geen casemod wedstrijden,... . Ik ben al blij als ze reply's geven op m'n project log. Ik denk dat we op dat gebied wat ontwikkelingshulp van Nederland kunnen gebruiken [/dutch mode]
A tweaker casebadge, d0h........ what did the first place winner won? the prizes don't seem all that great.
Looking around I cant seem to find anything like it. What is the actual name of such a thing? Brake hose? Thanks for any help. I really want to get these for a monitor mod I am doing to my LCD. Need things for some thin wires.
A realpower 550watt PSU Instead of the cooldrive 6. The prices arn't a big as past year indeed. Then they gave a vapochill case as 1'st price. But it's not all about prices Yeah, i think that would be braking hose in english, just those black cables witch walk to your braking levers. Note that there is also transmission/deraillieur cable, don't take that It's has a different construction, not the spiral thing around. Nice seeing other people being infected with the brake hose
You have to remove the vulcanized rubber isolation!!!! I was searching for those Break cable(hose), too. I´ve searched and searched, then i took a closer look at the cable and saw that the cable i searched for was under the isolation.!!!
hehe, thats a mate from my tent there on one of the pics, he's looking at the mod It looked great in real life too, hope you can finish it anytime soon
update Wel, i almost finished the baybus: These are the switches, 7 of them, only 6 are needed for the baybus. The 7th will replace the powerbutton on top of the case, i think this one looks better This is the place where it should be. Note the cooldrive 6 witch i mounted hidden beyond the front, i don't realy need to see the display, because i've got the software to check it out. Getting those holes in aluminium is a time expansive job, alu is soft, but very hard if you had to sand down those small holes I made the plexi parts of AC ryan's 8mm UV blue plexi Yes, it does fit Over here you can see how they are mounted, a small hole with a copper wire (from a welding machine) trough it. Note that you are able to see the parts beyond. That's why i painted the backside of the plexiglass by now. Jum jum Like i havn't got enough cable's running trough the casemod It's difficult to get a clear shot of the UV reaction. the color is normally deeper blue, and not overlighted where the led's are mounted Note that some light frome a switch lightens up the next switch a bit. I think i should put some black paper between the switches witch blocks the light.
Thanks guys. Well i was thinking about making switches on both sides, but the idea beyond making them all at the right side was that n00bs will thinks "ah, some nice lightened plexiglass" and they don't see that those are switches. When some of them are off, they will think that the led's failed or something like that. When all the switches are a 1 side i hope it's more clear that those arn't just plexi pieces, but switches.
