project: i-spider |stacker mod | 11-4: up and running (again)
Discussion in 'Project Logs' started by _ferry_, 19 Aug 2004.
  1. Buzku
    Buzku What's a Dremel?
    7 May 2004
    Holy god!
    It is BIG. Subscribed.
  2. Sub-Zero
    Sub-Zero What's a Dremel?
    6 Feb 2005
    lol, and we have the same keyboard!!! :thumb: --> same taste :thumb: :D
  3. Sub-Zero
    6 Feb 2005
    I`ve send you an email. Check it.
    here is a pic of what I need.
    I will pay for it!
  4. _ferry_
    _ferry_ What's a Dremel?
    22 Apr 2004
    update
    Past sunday i've ben polishing the PSU, and made some kind of cover for it, there is some space now between the fan ande the grill. So i hope there won't be noise of air fowing trough the grill.
    The PSU+ cover for it. Don't look at those fingerprints and tape ;)
    When i did a test fit the cover was way to high for it, i guess you can see that black piece of the frame below the PSI slots. It pretents adding high PSU's. So i decided to mount the PSU 2cm more in the case.
    Ofcoourse you will have a space around the PSU if you do that. I've got an idea for that
    Today i've cut down the sidepanels:
    Do'nt mind the different intensity, i just quickly added 2 CCFL's for the show.
    These are the things witch will fill up the hole between the case and PSU, 2 plexi and 3 of alu, the 3'th one is the version witch will be on top, like the standaard mounting plates. But now with the holes 6mm lower.
    All i did today was cutting down those sidepanels. cutting out the pieces above i will do next time because i'm having a headace now :duh:
  5. Rufus-Seal
    Rufus-Seal Guest
    Looking very good :dremel:
  6. advance
    advance What's a Dremel?
    18 Apr 2005
    I just read this whole thread... holy crap, your the man.
  7. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    Nice done dude!! :rock: :dremel:
  8. _ferry_
    22 Apr 2004
    update
    Finaly an update, ive been busy with some other things in the resting piece of my social life :D :D But i've been working on it. Bu i've done things witch are hard to see, like fine adjusting the upper case on the lower one, made some drawnings and new idea's and stuff like that. I've also bought a new camera, so i had to learn working with it as you can see at the pictures.
    Both the PSU's. Dont mind the bad white balance.
    Note the alu profeles on the edge, they are now on the right side.
    It fits perfect :D
    The backside of the PSU's. I'm going to hide them :)
    Notice the distance bolts, i'm going to mount a alu plate on it with some kind of grill witch will hide the PSU's and radiator. I'f i could describe it better in english i would do, now you guys should wait for new pics ;)
    Damn, wat a cable mess :p
  9. Buzku
    7 May 2004
    Your Stacker is soooo mighty :jawdrop: . I am definitely going to keep my eye on this (as I maybe said earlier :) )
  10. AngelOfRage
    AngelOfRage Minimodder
    8 Dec 2004
    that is one cool mod. it all looks sooo professional and smooth, especially the cable managment. very nice.
  11. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    I would call this project overstacked, but I-spider is good too.
    Gr8 work. As if a stacker wasent big enouf...LOL
  12. GigantoR
    GigantoR What's a Dremel?
    21 Jul 2004
    Love the sections of plexi joining the 2 cases together.
  13. Sub-Zero
    6 Feb 2005
    hello my friend! what is with my aluminium-tube? check your mail!
  14. _ferry_
    22 Apr 2004
    update
    Finally some time for updating, i worked on the sidepanels. I had the idea of finishing the rear, but i had to work out some things, and i need some money to purchase the stuff for it.
    The side like it used to be
    Taped, al the lines are 19 degree, the same as the italic font i used.
    Well, you might have never expected a rotating disk for this, but it works great :rock: I used a 1mm disk, it didn;t bite into the aluminium, and lines were very straight, i think because a large disk can't make small turnings.
    Still with the tape on it.
    Note that the corners should be finished with some fine dremel tools or some sandpaper.
    The resting piece of the sidepanel will be used for something like this.
    I want to make something that looks like a air intake, made of plexi. To give you an idea:
    This is 1 of the milion sketches i made during my training period. The pieces witch are sensored will be shown soon i hope so :)
  15. -Erik-
    -Erik- Guest
    This is one bigass bigtower... whats the actual height of this case. It looks HUGE!
    Surely a interesting project, subscribed!
  16. Pitbull
    20 Mar 2005
    Looks great :)
  17. Bloody Mary
    Bloody Mary What's a Dremel?
    15 Apr 2005
    Man thats bad-ass big, I love it. I've noticed a lot of great projects coming from holland, what do they put in the water? :D
  18. _ferry_
    22 Apr 2004
    hmm, maybe anti-corrosion fluid? It's prevents getting rust on your brains ;) But i must agree, together with germany and other countries we are quite active in casemodding.
  19. _ferry_
    22 Apr 2004
    Well the past day's i've been busy with mounting the rad's.
    Cutted the hole in top of the case.
    The backside is made of carton, yust a temp. solution to check the exact dimensions and te check if the rad's and tubes will fitt well.
    Dremel time :dremel:
    EIf you look good you can see some plexi. I'm not gonna use that. But i might mount some plexi between the case and radiator.
    Well, that's it for now :D
  20. Jipa
    5 Feb 2004
    That owns! Only one problem, it made ME wanna mod my KME :D I guess I have to do something tomorrow ;)
    Keep going bro, I love that!
