Project: [Ice Cold Li Project] Small update december 17th
Discussion in 'Project Logs' started by Brabus Freak, 12 Oct 2005.
  1. Brabus Freak
    Brabus Freak What's a Dremel?
    13 Aug 2005
    Introduction
    It all started with the purchase of a Prometeia 2GT, I had to buy a case to fit the Prom. Soon it was clear, that this should be a Lian Li PC75.
    When everything was delivered, I could see the final height:
    After some time the interior had to be changed. Due to the big window I needed to get rid of the cablemess and a few ccfl's and fans were placed.
    Just the standard stuff:
    Hardware
    -AMD 64 3000+ Venice @2961mhz
    -DFI Lanparty nf4 SLI-DR
    -Corsair LED memory 3200XL
    -X-connect 500watt psu
    -1* 36GB Raptor for OS
    -2* 200GB Sata for leeching
    -Prometeia 2 GT
    -DVD reader and writer
    The modding
    After seeing the mod of a famous modder in the Netherlands named Ediejo, I wanted to enlarge my prometeia, I also ordered a plexi plate for between the prom and the case, just because that gives such a great effect.
    Prom enlargement
    This enlargement is made out of wood, the second thing I did was placing some V2000 wheels under the case.
    The wooden box:
    It fits :)
    Fitted with the wheels under the prom:
    And the case on it:
    The first pics:
    I placed the aluminium panels on it to see how that looks, the protectionfoil is still on it:
    That's starting to look good! :thumb:
    Hardware in the case:
    Time for the panels, I didn't want screws, so I attached them with magnets:
    That's the case on this very moment.
    To Do
    -Watercooling
    -Second computer in it
    -Some polishing
    -Some accents with blue uv plexi
    Watercooling
    I've ordered this:
    This wil be combined with:
    -Swiftech mcp655 pump
    -BIX3 radiator
    -Innovatek fass-o-matic reservoir
    Second computer
    I want a mini-itx mobo in it with some hdd's, this would be the ''leech-pc'' for lans, there will be a ps one display in front of the case connected to the leech pc.
    Some polishing
    Some things should be *bling bling*
    -drivecages
    -psu cage
    -mobo tray
    Some accents with uv plexi
    You'll see :clap:
    The plan
    The plan is to fit the watercooling and the leech computer in an extra compartment on top of the case. That's why I bought a second hand Lian Li PC75 to make this compartment, I've made a design in sketchup:
  2. J-Pepper
    J-Pepper Minimodder
    20 Jul 2004
    bloody hell lol, you can fit me in that, let alone computer bits!! :p
    but seriously, the ideas are looking good.. :)
  3. Brabus Freak
    13 Aug 2005
    Clickable, because you never know wether you win something!
  4. Gascan1888
    Gascan1888 What's a Dremel?
    15 Dec 2004
    ITS HUGE !!! but its gona be awsome when finished :thumb:
  5. Boswell
    Boswell Minimodder
    23 May 2005
    im pretty sure you could get your cpu higher than that :p my friend had his 3000+ stable at 2.7 with watercooling and this is wayyy colder :p Looks very nice though
  6. sc4mpi
    sc4mpi OG watercooler
    16 Jan 2005
    if its a 3000+ i doubt it. not unless hes running dividers =/
    forgotten what the multi is but i no its locked., but if its 9x i presume his running dividers
    if its 10x then his ram might just do 292fsb, but iv never seen the corsair xl get into them figures. any way looks nice did u extend the vapochill side panels to to same lenght as the pc-70?
  7. Brabus Freak
    13 Aug 2005
    I did, altough it isn't a vapochill, but a prometeia.
    I'm running dividers, and my cpu is 9*329fsb :)
  8. Brabus Freak
    13 Aug 2005
    Update 1
    Made a window in the prom:
  9. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    Great Idea... Have an internal KVM
  10. blue_lawnchair
    blue_lawnchair What's a Dremel?
    25 Mar 2005
    Great looking so far. All in all what is the total hight of the case?
  11. FragK
    FragK What's a Dremel?
    18 Jul 2005
    looks like a blue version of Ediejo's lian li. gl tho
  12. Brabus Freak
    13 Aug 2005
    Just some interior shots, because I know you guys like that!
  13. Brabus Freak
    13 Aug 2005
    Just bought some wood to make a transportcase for the Lian Li.
    I have some lanparties in a few weeks, and I don't want to damage it.
    I did make it big enough to fit the upper compartment too, when it's ready.
    Case will be 115cm high :rock:
    Also bought some wheels for it, there will be a lot of handles on the case too.
    ps. Argh! They only had 3 wheels with brake, so one is brake-less :wallbash:
  14. PA!N
    PA!N What's a Dremel?
    16 Jul 2005
    OMG your taking THAT monster to a LAN :hehe: ?
  15. Brabus Freak
    13 Aug 2005
    Yup, don't have an other pc :duh:
  16. LoneArchon
    LoneArchon What's a Dremel?
    15 Jun 2004
    hosting the lan to me seems easier than moving the envisioned beast. But great idea how tall will the final heght be
  17. sadffffff
    sadffffff Minimodder
    20 Oct 2003
    lol hahhaahhaahahah i love it! so tall it starts to get scary
  18. Brabus Freak
    13 Aug 2005
    LOL, final height will be 114cm, but I don't know how much that is in inches!
  19. Brabus Freak
    13 Aug 2005
    Thanks dude!
  20. Blackcrown
    Blackcrown What's a Dremel?
    1 Oct 2005
    It's about 44,9 Inch.
    It's huge! Why are you trying to make a ediejo case replica like one? Wasn't it more cool to think of a new more revolutionair idea, and a more unique design?
