Case Mod - In Progress Project Iced Blood - Mayhems/Primochill Sponsored - COMPLETE 15/02/16
Discussion in 'Project Logs' started by stealth80, 5 Feb 2015.
  1. stealth80
    stealth80 Minimodder
    1 Feb 2015
    Haha might just be the angle of the photo, its all gotta come out anyway for the radiators to be flushed :thumb:
  2. stealth80
    1 Feb 2015
    I decided to drop the motherboard and PSU in the case tonight as a temporary fit just to see what extra cables I'm gonna need and basically to see how the fans look, and I love them lol :D
    For a start i need a braided 8 pin tax extender, cable is just long enough!
  3. stealth80
    1 Feb 2015
    Just ordered a whole load of stuff including all the fittings, a 7th fan for the 240mm rad, the Mod My Toys Compression fittings, braid kits, pwm extenders, Sata adapters, Fan Controller (Bitfenix Recon, pretty much the only white fan controller!) and 2x pwm hubs. Will have a busy few days i think.
    http://www.overclockers.co.uk/showproduct.php?prodid=BB-002-BX
    Also the Cable for the RoG Front Base was too short as i expected, got to cut this and inline splice some extensions to lengthen it as Asus don't make a longer cable!
  4. Combatus
    16 Feb 2009
    So much room in these cases. Still considering the Core X1 for a mini-ITX build :)
  5. stealth80
    1 Feb 2015
    This case is huge, if the wife wasn't getting a new Sofa and moving the living room around a little there's no way i could fit this in.
    Today I got the partition wall finished with LEDs fitted to the acrylic, so now the wires are well and truly hidden! I also had a delivery which was made up of the primachill tubing, and the 45 and 90 degree fittings (12 of). I got most of the CPU loop complete but i don't have the white compression fittings yet for the GPU and I'm still waiting on some funds to buy the EK CPU, GPU and motherboard chipset block
  6. stealth80
    1 Feb 2015
    So as the 240mm radiator was added later on into the planning stage, it also happened to form one of the lower points in the CPU loop. Therefore i needed to add an additional drain to the one already planned for the res. So this weekend i got that finished which required some metal work on the rear grill to provide an opening for the actual drain point:
  7. stealth80
    1 Feb 2015
    Today i had a couple of deliveries arrive including the Bitfenix Recon fan controller, 2x PWM hubs, a braiding kit, 8 pin red extension and the final Enermax Vegas fan for the 240mm radiator. I spent quite a lot of time wiring everything up and tidying up the looms from the fans in the ceiling of the case and also tidied some of the wires around the back of the partition. I also braided the CPU loop pump wire and the front panel header cables:
    Got the wife to take the pictures as she better with camera than me, took the picture of the text with the lights off and no flash, but i think the exposure was too low, however the text doesn't appear as pink as normal lol
    The front of the case, pretty much the only finished area : )
    Both fans fitted to the 240mm radiator:
    New XSPC fittings fitted to the res/pump combos, wanted to use the black chrome ones which I already had but seems theres a global shortage of black chrome
  8. stealth80
    1 Feb 2015
    THINGS TO DO:
    1) Cable management around motherboard area and towards front of case above the trunking.
    2) Wait :wall bash: for the rest of the White Compression Fittings to be shipped ..... fit those and route the tubing for the GPU loop once its here.
    3) Get the CPU block, GPU and Chipset Blocks ordered and fitted once delivered.
    4) Receive Mayhems coolants and flush kit and start bleeding/leak checks :clap:
  9. Impatience
    Impatience Minimodder
    6 Apr 2014
    Looking awesome there! :thumb: Also, congrats on your MOTM nomination!
  10. stealth80
    1 Feb 2015
    Thanks !
  11. stealth80
    1 Feb 2015
    Really looking forward to getting this finished the EK blocks should look great. Unfortunately I have to RMA the Asus board as the MEI chip appears to be faulty :wallbash:
  12. stealth80
    1 Feb 2015
    Just ordered the remaining 2 red compression fittings and the chipset and CPU waterblocks and as some people have asked how the case looks externally at the moment i figured I should add some pictures. These were quite difficult to get right as the lighting in my room is quite dim and the flash seems to over power the colours in the case:
    Excuse the Intel Cooler, need something to keep that chip cool while she's been snapped!
  13. Vognen
    Vognen Minimodder
    2 Oct 2013
    It's all coming along real nice! Keep up the work :)
  14. stealth80
    1 Feb 2015
    Thanks! Getting close to the finish, cable management needs improving and I will have some of the blocks soon can't wait, I've really enjoyed doing this :D
  15. rrmitko
    rrmitko Minimodder
    14 Jun 2014
    Looks great:thumb:
  16. stealth80
    1 Feb 2015
    Hmm pictures are playing up, I'm in the process of uploading everything to imgur, but then i have to edit all the links ... :wallbash:
    On a brighter note I've just had clarification from Mick at Mayhems that my package has been despatched with something pretty major as a bonus :thumb:
  17. stealth80
    1 Feb 2015
  18. stealth80
    1 Feb 2015
    Update 06/03/15
    Just had some goodies arrive from Mayhems!
    A pretty large box in which contained:
    2x 1 Ltr Pastel Red
    2x 1 Ltr Pastel Ice White
    1x 1 Ltr H2O Pure
    2x Blitz Pro 2
    2x 15ml Red Dye
    1x Blitz Clean Basic
    and 2x something else .....
    Thanks again to Mick at Mayhems!
  19. stealth80
    1 Feb 2015
    What's in the box ?
    2x Mayhems 360mm Havoc Radiators! Quad pass, triple chamber, can't wait to try these, but first I need to paint the primer to match the case, back to annoying the wife!
    Nice paint free threads!
    Ready for painting, a quick layer of white primer (although it's primed I feel going white needs to be over white primer ) before painting
    Using this months CPC to blank those fins almost made me cry!
  20. Icelander
    Icelander Minimodder
    3 Mar 2015
    really like the white color paint job :)
