Project: Ignis (w/c mATX Case) -- BAWLS HOT MOD-ITB WINNER!!!
Discussion in 'Project Logs' started by 3N1GM4, 23 Mar 2004.
  1. JEEVES
    JEEVES Minimodder
    14 Jul 2003
    need to order them first
  2. cderalow
    cderalow bondage master!
    23 Jan 2002
    how are you planning on mounting a fan on that rad without blocking off some vital things... (ide plugs)
  3. slater
    slater Mummy Says Im Special
    18 Apr 2003
    Well for a low flow system thats aimed at noise reduction like yours 5lpm is acceptable but for a performace system its well under the requirement. Whats more important when chosing a pump is to get one with the best head rating (also known as pressure). eaven if the pump was rated for 10000lpm its still the head rating that matters, The more the better :thumb:
  4. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    im going to try a few different things
    A: create a low preasure case and "suck" air in through the front, and then through the radiator, and not use a fan...
    B: put the fan on the outside of the case between the frame, and the front bezel
    i am going to try for option A: first, i have a feeling it should be sufficient, becuase i have run it with the fan completely off for a few days straight, when it was in my old case (the one im uisng now, im on air cooling right now, boooo) and it worked fine...
    but if the temps get to high, i will slap on on the front of the case, and it should work quite nicely :D
  5. cderalow
    23 Jan 2002
    and those pvc pipes won't get in the way? :wallbash:
  6. JEEVES
    JEEVES Minimodder
    14 Jul 2003
    you can always cut them down some more :dremel:
  7. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    Not sure if this has been said but the Via aqua 1300 is a cheap and very small pump equally there's the hydor l20 and l30 which are both small and all have good flow rates. A lot cheaper then the mag drive pumps by danger den and swiftech. off the Top of my head a via aqua is about 3"x3"x4" approx without fittings
  8. x3r0
    x3r0 What's a Dremel?
    29 Oct 2003
    For the mounting of the fan onto the rad,
    You could get some scrap pieces of pvc / acrylic , cut them to shape, glue them together and craft them into some sort of shroud that is angled away from the problem area.
  9. Providence
    Providence What's a Dremel?
    23 Jan 2004
    Check your email Enigma.
  10. jaguarking11
    jaguarking11 Peterbilt-strong
    10 Dec 2003
    Well Ive seen thse Here pumps on diferent sites and realy dont know the reliability of them but it pushes 370galons per hour and it looks quite tiny. I myself am doing a similar project with a small atx case (dell xpsr-350) and I am going with the hydor l30 as I hear its reliable and flowrates are very good on it.
  11. slater
    18 Apr 2003
    Yeh Via Aqua 1300s are ok flow wise but there not exactly the most reliable pump ever
  12. PC JUNKY
    PC JUNKY Banned
    7 Jul 2002
    This is looking really good 3N1GM4 and a damn fine job on those flames . . . :rock:
  13. Arkangyl
    Arkangyl What's a Dremel?
    16 Dec 2003
  14. 3N1GM4
    23 Jun 2003
    Well because i decided where to mount my pump (in the 3.5 holder) i needed to find a place for my 2 hard drives.. well the top bay, and well i didnt want my 2 hdd's sitting in the top of the case with no air, i decided to make a "hard drive cooler"
    after the initial fittings (bondo to hold the tubes in place)
    after cutting them down to size
    first coat of bondo
    after alot of sanding, and well sanding
    and 293847 hours later :p the "final" version
    and the whole case put together, and stuff
    i did this last night, so be ready for another update today
    :dremel:
  15. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Interesting... So what are the holes in the top for...? HDD cooling?
    Keep up the good work. I always like seeing something new. :D
  16. Etacovda
    Etacovda What's a Dremel?
    4 Nov 2003
    "i decided to make a "hard drive cooler"
    Less and less people are actually READING posts now days ;) haha
    Awesome work so far man, well done :>
  17. 3N1GM4
    23 Jun 2003
    right right, keep the comments comming
  18. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    and exactly where are you planning on placing said pump and res, besides maybe bolting them directly onto the window???
    I sure don't see any other place. jesus that's one tight fit.
  19. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Sorry I read the post but did not see this... :read: more next time
  20. 3N1GM4
    23 Jun 2003
    more on that tomorrow ;) :D
