Project: Ignis (w/c mATX Case) -- BAWLS HOT MOD-ITB WINNER!!!
Discussion in 'Project Logs' started by 3N1GM4, 23 Mar 2004.
  1. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    Pump Mounted
    Alrighty, got the pump mounted and its in there good :D
    i put it in the HDD rack, and then cut a hole in the bottom of the rack to:
    A: have enough room, and to bring it down a lil bit, cause it was too tall.
    B: to have the outlet of the pump facing down.
    so here are the pics
    drew up the hole, and cut it...
    Test fitted the pump... it works :D
    then i added rubber molding that i picked up from "Autozone" to cut down on vibrations, and to avoid scratching the hell out of the pump casing.
    Then came the tricky part... holding the pump in...
    What i did was I took some flexible steel "strips" that had hole already in them, drilled 4 holes on the side of the case (2 on each) and inserted bolts.
    i was originally going to use nuts on the bolts, but the holes in the "strips" fit the bolts perfectly, and they could screw into them. Then i bent down the ends of the strips about 1/2 inch short... i did this, because when the bolts go in, and the strip is tightend down, it will pull downward and hold the pump in place... here how it looks, not the prettiest thing, but it gets the job done. and no one will ever see the strips, as they will be against the bottom of the cd rack.
    and it all mounted inside the case... :D :rock: :D
  2. 3N1GM4
    23 Jun 2003
    O, and i got the front primered yesterday aswell...
    there are a few imperfections, that will have to be sanded down, and possibly worked out with some bondo :D but i should have the side pannel bondo'ed up (finished) and primered today as well
  3. bushd
    bushd What's a Dremel?
    9 Nov 2002
    A very original looking front, nicely done.
  4. 3N1GM4
    23 Jun 2003
    thanks, the bottom is pretty original i hope,
    the top its not too original, but i got the main idea off http://www.mnpctech.com/progressTurbineHD.html, but i think i modified it enough to be original enough, but i'll let you be the judge of that... if you couldnt tell i have it slopping down into the drive bay, and flush with the top as it is curved outward...
    i wasnt going to do the top at all, but decided i should since im putting 2 hdd's up there :hehe:
    once i get my new dvd rom, i believe i will be bondoing a faceplate into the front of the case... but im not sure, im gunna see how it looks normal... :D
  5. Fr0z3n
    Fr0z3n What's a Dremel?
    21 Oct 2003
    Awesome! Cant wait to seem more progress on this case.
  6. 3N1GM4
    23 Jun 2003
    alrighty, like i said, pics of the primered side
    Before i primered it, and after a couple more coats of bondo (just to get it perfect
    then i applied the primer, and let it dry, and put it on the case...
    and a final shot, of the pump mounted along with the radiator...
    thats about it, this project is gunna probably slow down untill i get some cash, or summer comes (my school stops May 7) so stay tuned... im sure ill keep working on it anyways :D
  7. alex{tm}
    alex{tm} What's a Dremel?
    14 Apr 2004
    sw33t kip it up!
  8. Peppo
    Peppo What's a Dremel?
    1 Jan 2004
    This is turning out well keep up the good work
    :dremel: :dremel: :dremel:
  9. mikey
    mikey What's a Dremel?
    29 Mar 2004
    lovin that side panel design :)
  10. Fr0z3n
    21 Oct 2003
    Looking good! :thumb: Cant wait to see more.
  11. 3N1GM4
    23 Jun 2003
    Update time... a tiny update, but an update...
    i worked on the front again and got the drive bezel cover mounted up all nice and stuff...
    heres some pics
    after the initial layer of bondo and what not, and some sanding on the top, with the first heavy coat of bondo on the bottom...
    after the sanding the final coat of bondo...
    and then i sanded down all the rough spots on the front, and re-primed it all...
    thats it, i might update friday or saturday... hopefully
    thats it for now
  12. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Looks good... now how is the cdrom going to attach now? Interesting design...
    Looking forward to more. :D
  13. rob_65
    rob_65 What's a Dremel?
    5 Apr 2004
    very original, innovative design!
    watching closely :) keep up the outstanding work
  14. 3N1GM4
    23 Jun 2003
    i plan on mounting it behind the front cover and attacing the cover so that the cd-rom is completely behind it, and then glue/tape on the tray front on the tray of the cdrom... should work nicely...
    but time will tell
  15. trigger
    trigger Procrastinator
    22 Mar 2004
    Could you let me know a couple of months before you do your next mod? I think I'll buy some shares in Bondo company!! :D
    Seriously though, nice case, love some of the ideas that have gone into it! :thumb:
  16. 3N1GM4
    23 Jun 2003
    lol, my bro is using more thab me really... hehe
    thanks
  17. eddie_dane
    eddie_dane Used to mod pc's now I mod houses
    31 Jan 2002
    edited your jinormous thread title, as per the rules - eddie_dane
    nice work so far.
  18. 3N1GM4
    23 Jun 2003
    oooo woops sorry
  19. Heavytank2
    Heavytank2 What's a Dremel?
    10 Oct 2003
    Awesome. Subscribed.
  20. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Awsome!! :d
