Thank you Today I've continued with the front... At first I've routed a rabbet After that I could measure it and cutted a metal sheet I've found a nice jig on the internet so it was very easy the drill the holes The last times I cutted the fan holes with my jigsaw and filed it down. That was very annoying so I decided to buy a whole saw. It is a very nice toy :explosive: it doesnt fit perfectly but I'm very satisfied Tomorrow I will check if every hole fits correctly
Hey, nice project! The milling work on the front panel looks really precise. Why did you make a separate panel for mounting the fans though?
