Scratch Build – In Progress Project: iMac mini - Finished (1.3.) by mischa
Discussion in 'Project Logs' started by mischa, 1 Mar 2008.
  1. mischa
    mischa What's a Dremel?
    10 Nov 2006
    Moin!
    Don´t worry about the title: This aint going to another G5 oder G4 to PC mod ;)
    A few months ago, i got my hands on an old laptop.
    No keyboard, case was broken and ugly, touchpad didt work properly.
    This is how it looked like before i took it all apart:
    Alright. Not possible to work with that thing anymore. So it was time to take it all apart:
    Ah, i see. It seems as if the hardware is mountet on some kind of inner tray. The outer Plastic-case was only "clipped" to this frame.
    Cutted it a little bit smaller, because the battery-tray was no longer used:
    As you might have thougt already, this thing is going to be my iMac. Fitting Test: Hardware-TFT-Sandwich. Juicy :D
    Uh, looks good!
    one Problem was, that the data-cable for the display was not long enough. The flat cable was bended in 90°-Ankles, so i just converted it to a straigt line and had enough calble to connect the tft.
    the Laptop only had 1 USB-Port, so i builded in a 4x USB-hub
    A WLAN-Stick connected to the hub:
    Check: Is the hardware sill running?
    yeah! it survived the mess.
    here everything is mounted on a 5mm plexiplate, with an additional fan. and you can see the USB-Hub and WLAN-device.
    *snipp* a few days later:
    i made distance-screws (ehr... you know what i mean :D) and mounted the hardware on the tray:
    Ok, i could have done it one centimeter less high, but it fits. and: the hardware gets enough air! it was never ment, to put everything upside down, so i need an improved cooling.
    the stand support was bended from 4mm aluminium:
    looks quite mac-like, doesn´t it?
    Well, and you see that this thing is going to bee quite small.
    The laptop only had a 14" tft.
    Alright, update in a frew hours.
  2. Guest-23315
    Guest-23315 Guest
    I like the idea!
  3. widmod
    widmod Minimodder
    9 Oct 2006
    a windows laptop modded to look like a mac and running ubuntu-linux?
    crazy stuff...:rock:
  4. mischa
    10 Nov 2006
    Hi!
    Im glad you like it ;)
    To Widmod:
    Yeah, this machine used to run Linux.
    But for now im going to install a Windows XP with Flyakite OSX.
    The Slot-in-Slot :)D) for the CD-Drive:
    So this is the final status:
    The front is made from 5mm Acrylic, the black part is painted from the inner Side.
    It fits so perfect, it doesnt need any glue or screws to stay in place.
    I hope you like it, because i do so.
    A small and good looking computer with everything in it i do neet.
    Im looking for an Apple Desktop Set with Keyboard and mouse on ebay, to make this a whole thing.
  5. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Very Nice.
  6. widmod
    widmod Minimodder
    9 Oct 2006
    great work looks like a real mac :jawdrop:
    schön gemacht ;)
  7. mischa
    10 Nov 2006
    Hi!
    Thanks for the commendations.
    Widmod: Wow, the first austrian Modder i know.
    I soon will make new Pictures, but for now i had to take them with my mobile-cam.
    The dslr is broken *grml*
  8. studentgaza
    studentgaza What's a Dremel?
    4 Sep 2008
    Looks great
  9. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    oh that came out nice. only thing i would have done, just a little detail, is painted a white apple logo on the bezel before the black back painting. other than that spot on imac concept. nice way to put good use to hardware that probably would have otherwise ended up in the trash heap.
  10. Slatter
    Slatter Mesh Addict
    16 Feb 2007
    fantastic idea.
  11. FrooP
    FrooP can I eat this?
    24 Oct 2007
    mischa, einma pizza mit salami bitte :D
