Case Mod - In Progress Project Indigo / Define R5 ( Completed )
Discussion in 'Project Logs' started by Icelander, 11 Mar 2015.
  1. Icelander
    Icelander Minimodder
    3 Mar 2015
    almost done with the roof. used M4 body screws countersunk but one of them has to be replaced.
    well gonna keep on going and finish that roof tonight :)
    Mod on and I see you soon
    Ice
  2. Icelander
    3 Mar 2015
    Sprayed some dust filters and 6mm acrylic plates which I am going to make something cool with ;)
    Stay Tuned for more...
    ICElander
  3. Icelander
    3 Mar 2015
    polishing
  4. Icelander
    3 Mar 2015
    the front of the case is looking good imo
    Stay tuned for more to come Soon...
  5. Icelander
    3 Mar 2015
    So I havent been updating lately because As I stated few weeks ago my 280x with Wb which I was going to use died so I have been saving up some cash to buy another GPU (Nvidia). So after few days this buildlog can keep on going and I wanted to let you know that I have not abandoned the project.
    In the Meantime my son and I made this small square box 450mm x 350mm and that was my sons Idea so he and I can store more hardware components and Watercooling fittings he said.
    The Picture is of the bottom of the box.
    Stay Tuned for updated of Indigo SOON :)
    ICE
  6. Icelander
    3 Mar 2015
    Oh Happy Day,
    oh happy Day.
    When Gpu Comes :)
    Sorry, Bad joke But yeah I got it in my hands the card and it is MSI GTX 970 Tiger OC Edition.
    So I put the motherboard in the System and since I started this project with an Amd Cpu I will finish it with this motherboard even though I want to switch to my Z97 Platform for this build but I have decided to use tha Intel build in my next project , starting soon because it is so fun modding and making things the way I/You want to do It...
    And the cables from www.icemodz.com . Check it out.
    Full of dust and needs cleaning but it will be tubed up and blocks put on when I Get the Waterblock for the 970 :)
    Hope you enjoyed , Stay cool until next time
    Ice
  7. Icelander
    3 Mar 2015
    Staying excited. Waiting for the VGA Wb to arrive which I ordered today.
    Training the cables and see the system before I take it apart to install the Water cooling components.
    The Gpu has been running smooth and quiet and I always check that out before I install Waterblock on it.
    Stay tuned for more.
    Thanks for checking my build out, Hope you enjoyed
    ICE
  8. bionicgeekgrrl
    bionicgeekgrrl Minimodder
    1 Oct 2009
    Looking great. Liking the colour combination. Suspect my next case will be one of those Define R5s :)
  9. Icelander
    3 Mar 2015
    Thank you and yeah it is a good case and easy to work with when building a Rig :)
  10. Icelander
    3 Mar 2015
    Well My beautiful EK Waterblock has arrived and I am thrilled...
    I hope to do a small Mod on the backplate and will show result sooner rather than later :)
    Also I am working on a custom Radiator Grill and those who look carefully enough should / could make out the case beneath '? A future mod perhaps in form of making it a Real PC hehe
  11. Icelander
    3 Mar 2015
    So today I have been setting up my next project and working on this one.
    Had to plug my Z97 mobo So I have a working fast PC while building up the loop on this project :)
    Also I wanted to make a Radgrill for the front Rad and have started hacksawing and I wished I had a scroll Saw but that is a item I will definetaly invest some money in before I do more builds !
    the Saw
    Lot of Sawing needs to be done but using this 2mm aluminum shroud over the Rad will look much better than the bare Radiator :rock:
    Thanks for tuning in.
    ICE
  12. Icelander
    3 Mar 2015
    So I was on and off between things almost finishing the Radgrill. Only need to sand a bit more and then paint it.
    Thanks for checking it out :)
    Ice
  13. Icelander
    3 Mar 2015
    Hi everyone... :)
    Today I Have started on the tubing. Some pics after I installed the cpu and gpu block + Ram modules. Sorry to say that I got white block but was going for a clear one so I might not install the white one .
    Here is the block with the White top but I thought I ordered clear top... Oh well
    Stay tuned for the tubing coming up ;)
    Ice
  14. Icelander
    3 Mar 2015
    Hello everybody.
    I decided not to use the white Ram block cause it does not fit the Theme
    But will do some changes when I get the clear version If I buy that.
    So tubing is done and I did not manage to fit my PSU cover back because of the pump & Fittings so there are things to be done before this project is over but I am very pleased with the outcome.
    What do you think ?
    Thanks ICEMODZ & Bitspower for supporting this project
    Thanks for checking it out, Stay tuned for the finish for the build :)
    ICE
  15. Icelander
    3 Mar 2015
    Leak Tested and everything went well :)
    Thanks for checking it out guys !
    Ice
  16. Icelander
    3 Mar 2015
    Hi folks.
    I am almost done with Project Indigo.
    Rather small update but stay tuned for the final pics
    ICELANDER
  17. Icelander
    3 Mar 2015
    doing that PSU Cover using aluminum and plexi in two parts for easy installation and removal when ever I feel like it :D
    First the preparations made :
    Then I will do three coats of Satin Matt Black finish
    Stay tuned for more soon to come...
    Icelander
  18. Icelander
    3 Mar 2015
    Well this is it for Indigo and here come the last pictures ...
    Thanks to everyone leaving comments and taking their time to follow this small project.
    Thanks to my Sponsors >
    Kind Regards and see you all on the Forums in future buildlogs :
    Icelander ;)
  19. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Very nice rig!! :)
  20. Icelander
    3 Mar 2015
    thanks mate ;) :rock:
