No not @ all, the fans are blowing out of the case... The system is running for a month now and no dust this far. Piloux i'm from Londerzeel near brussels, and u ? Love u work btw m8
Since the air is heated inside the case, and the fans on the rad are blowing from the inside to the outside, doesn't the water get a bit warm? What temps are you running at?
Because there is an intake fan in the front of the case it's actualy like intake air that blows thru the rad. CPU: AMD 2400+ xp now @ 2500Mhz Temps Idle : | case : 25° | socket : 32° | core : 35° | Temps Stressed : | case : 27° | socket : 36° | core : 40° | VIDEO : Geforce fx 5900 xt ( Leadtec ) now @ Core 500Mhz & mem 800Mhz MEMORY : 2x OCZ Dual channel ( Premier series ) 512mb 3500 now @ 3.0V
I would think you could get lower temps on a setup like that. I run a 120 in the front, an 80 on the side and 2 80's in the back, also 2 40's on an hdd cooler in the front, and a Coolermaster Jet 7 and I am running 16C case and 28C core idle right now. Of course it sounds like a vacuum at the moment since I haven't gotten a fan controller yet
Very nice job, very clean and neat. The way i like it . What are your temps you get with this set-up??? //offtopic:Londerzele, nederlandstalige dus..
Thats i nice rig. Kinda oldschool and simple. Sleek. Luvs the res and the etch. What other mods are you planning for this one. Looks forward to a little update with more goodies
