Project: Industrial Progress 12/29/04
Discussion in 'Project Logs' started by Rekarp, 4 Jul 2004.
  1. my58vw
    my58vw Plexi Expert
    22 Sep 2003
    Looking real good there... keep up the good work.
  2. Rekarp
    Rekarp New Member
    7 Mar 2004
    Quick update. Went to fry's tonight and picked up my psu, HD, and socket
    I ran into a problem with the psu and hinge. The hinge's bolts keep the psu from sitting flush on the case.
    i will be replacing the switch on the psu with the socket
    Oh yah i found anoughter snag with the door lock and the radiator. The cam lock hits the radiator preventing it to close. this will be fixed tomarrow.
    Thx everyone for all there support in my project
  3. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? New Member
    13 Jun 2004
    mmmmm looks good m8, what size of HDD is that? just wondering
  4. Rekarp
    Rekarp New Member
    7 Mar 2004
    Its a western Digital, 160gig, 8mb cache, 7,200 rpm. I got it for 59.99 after $30 rebate :rock:
  5. Firehed
    15 Feb 2004
    Crap thats a good price. If it was sata I'd ask for one :hehe:
    Hmm... almost makes me want to mod the compaq my mom uses. That a presario 7000? Looks just like ours although we picked up the green front for it. Actually ours has 3 5.25" bays so it's probably a different model. "THE Athlon 800MHz processor" could do with an upgrade though... shame it's slotload. Maybe it would take any mATX board though, can it take a standard PSU as well?
    Nice work so far. That heatercore is sure a beast... looks like it just barely fits in there.
  6. Rekarp
    Rekarp New Member
    7 Mar 2004
    Today i fixed the issues of the closing door and the hinges preventing the psu from fitting. I soldered the socket in and mounted it in the psu to. I have run it to anouther problem tho. Seems that i have 1/2" clearance between the door and the radiator and pump. This will make my window mount reservor very thin. I could make one side thinner than the other side like this
    The front will be UV reactive and the rest will be regular plexi.
    First i removed the top of the psu and disconnected the switch. The switch was connected by 2 brown wires so these were clipped off.
    Next i conneted the two brown wires from the switch
    with a cap. I then drilled a hole in the side of the psu to allow the pump cord to enter.
    I then soldered the ends of the pump to the socket, leaving the black end of the pump off and connecting a red wire for a switch that will turn of the pump.
    Put back together
    I then fixed the cam lock with a washer. This allowed enough clearance between the radiator and the cam lock.
    Heres what the case looks like right now
    [​IMG]Close fits all around
    Now i have to wait till i get the rest of my parts and plexi in before i can continue.
  7. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    ha ha ha looks sweet, and don't worry bout the room cause what is modding without a challenge?!?!?!?
  8. Romirez
    Romirez New Member
    31 Jul 2004
    Looking good so far :thumb:
    Can't wait to see the finished thing, the concept looks great
  9. X-W4rrioR
    X-W4rrioR New Member
    14 Oct 2003
    Hang on, i think i missed something here.. why did u put an addition connector? i read the theread, (well most of it :p) can u explain?
  10. Firehed
    15 Feb 2004
    That's a bit dangerous.... exposed AC terminals. Or I completely mistook that and that's the new power plug for the pump so it can use a normal power cable.
    I guess it helps to read the post more carefully. But oh well I'm too lazy to go back and cancel this post.
  11. Goblin Tinkerer
    Goblin Tinkerer New Member
    24 May 2004
    Hey what kinda slot fan was that for you graphics card?
  12. SMOVE
    SMOVE New Member
    17 Apr 2004
    Hey, this is really dangerous :eeek:
    Don't you know, what happens when somebody puts his fingers into the terminal? :eyebrow:
  13. Shadowed_fury
    Shadowed_fury Active Member
    21 Nov 2003
    Was thinking the same thing, i guess if u want a new hair style...
  14. Rekarp
    Rekarp New Member
    7 Mar 2004
    The socket is hooked up to the pump??
  15. Shadowed_fury
    21 Nov 2003
    yeah. but if it isnt for some reason, and the computer is on (thinking about this, this probly won't happen) but they'd be exposed...
  16. Rekarp
    Rekarp New Member
    7 Mar 2004
    But no power is going to the socket intill the pump is pluged in, covering the socket. Ill go back and edit it to make it more clear in a little bit with better pics.
  17. SMOVE
    SMOVE New Member
    17 Apr 2004
    Ah, now i understand, you just use it to get the cable for the pump into the case and it isn't connected to the psu plug ;)
    Then it's ok :)
    But i would have done something more usefull, so you need to plug in two cables....
    You could have connected the pumpcable directly to the psu plug ;)
    So you would just need one cable.
  18. Rekarp
    Rekarp New Member
    7 Mar 2004
    I stuck on this mod untill i get my arcylic in. But i did order my mobo and other components for it. Updates next week!
  19. Rekarp
    Rekarp New Member
    7 Mar 2004
    Well i got alot done over the weekend so klets go to the pics!
    first i sleeved the psu
    I took of the cover first
    My female molex remover
    Removed plugs and floppy connectors
    Sleeved and heatshrinked
    Removed ATX connector via paperclips
    Pump sleeved
    Completed except a good paint job
    Mmmmm. UV :hip:
  20. Rekarp
    Rekarp New Member
    7 Mar 2004
    Next i did my fan rheobus. Used the plans that i found on bit-tech :thumb: except no leds yet.
    Topside. For the heatsink i cut up a old p1 one.
    Bottom.
    I also wired in a switch for 12volts since i cant get it thu the bus
    Volt gauge
    Whole system
    well for my first major soldering job i think i did very well :)
