Case Mod - In Progress Project : Infinity CM Stacker (Reservoir 100% complete)
Discussion in 'Project Logs' started by DoOb's, 14 Sep 2007.
  1. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    This is going to be awesome. Keep up to good stuff dude!
  2. DoOb's
    DoOb's Overclocker/Modder
    7 May 2007
    Thanks [USRF]Obiwan, got some more popping ideas...
    Why not just make new Side Panels. That way, i can have a custom window aswell.
    So thats the plan, gonna go buy two cut sized up panels for my case.
    Check at the pic to see how i will mount it. I will have a bend at the back for the screws there aswell, like a normal side panel
    As for the back panel, no window but same idea. If i decide to use the crossblower then i will draw vented holes.
    But im getting a ram cooler like robthepyro's and im gonna mod that to a certain design then i dont think i will need the crossblower, as when i get a 8800GT, which i think my waterblock will fit it will be watercooled, if not i'll be getting KB's fatalty cooler.
    Going to E.I.S to get more nuts and bolts, dome nuts today so...
    DoOb's
  3. Asulc
    Asulc Minimodder
    18 Jul 2007
    No offense, but that red does not look good. I think that it is too bright and metallic-y-ish... I hope that the black or whatever you use will make it look nicer.
  4. DoOb's
    7 May 2007
    LOL, no Asulc, thats just showing where the panel will be. The panels im actually thinking of shiny them all the way to a mirror finished, ive seen it done on another stacker... Looks sick
  5. [USRF]Obiwan
    9 Apr 2003
    Thats a nice idea, a full windowed sidepanel. That is one i did not see before. But you need to clean up the 5.1/4 slot rack on the right. But you probably will. And i personly think that adding more roundish cutout effect will be over the top. Letting the rest of the case "clean" will make it more guessable for viewers fantasy.
  6. DoOb's
    7 May 2007
    Yea there is a cover for that, im also need to make another hole there anyway.... entry hole for fasten nuts and bolts.
    This panel is gonna have door hinges on
  7. DoOb's
    7 May 2007
    Well i did the hinges for the side so i can get in that side of my case.
    Here the pics and a Vid, let them speak for them selves
    I've got a solution for that gap between the two pieces of the hinges
    Enjoy
    DoOb's
  8. Colossous
    Colossous Minimodder
    28 May 2007
    Looking good as ever and coming together DoOBs ! :thumb:
  9. FragileSocks
    FragileSocks What's a Dremel?
    25 Nov 2007
    Really nice work, cant wait to see the finished article. :)
  10. DoOb's
    7 May 2007
    Thanks guys, much appreciated
  11. Asulc
    Asulc Minimodder
    18 Jul 2007
    looks great. I see that you are online. Why is that? Go mod more for us!
  12. DoOb's
    7 May 2007
    jI would but there isnt much i can do. I need to get more dremel disks...
  13. Asulc
    Asulc Minimodder
    18 Jul 2007
    lol, well go buy them!
  14. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Very very nice!!
  15. sasuta
    sasuta What's a Dremel?
    5 Jun 2007
    Super...
  16. Colossous
    28 May 2007
    Any updates in the pipeline DoOBs ? :D
  17. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    subscribed
    looking great will be looking at this closely and hopefully get some inspiration for my mod
  18. DoOb's
    7 May 2007
    Hey Colossous, Well, i havent done anything since that door im afraid, Now that i work, i cant even go to the one place to get me disks, Might have to get them from Joburg. (Johannesburg)
    And then I have to get some more Aluminum for my case, now that im gonna be making completely new side panels. And im gonna get my fan grills laser cut most probably. See how it goes there.
    I get my 8800GT tomorrow, See if my waterblock fits on this card, then i will have full system watercooled case. Im also getting a OCZ XTC Memory cooler, for my ram. I'm not gonna use that Crossblower.
    Thanks Kylevdm, As i mentioned abouve update are at a halt for now, but dont worry, I'm going to finish this case.
    Secret.... gonna be one shiny exterior cause of the aluminum, gonna buff that up and the insides with a touch of red white and black.
    Stay tuned
    DoOb's
  19. DTNguyen107
    DTNguyen107 What's a Dremel?
    26 Feb 2007
    I was just talking to my friend how much potential the CM stalker would have if you mod it.
    Came to the forums and first link was actually your project log and I'm loving it :thumb:
  20. Kylevdm
    4 Oct 2007
    i lived there for 9 years
    anyway back on topic
    hope you get the dremel disks but is a 6 hour drive worth it? cos it is :D
