Case Mod - Complete ⭐ Project Interceptor (AH T600 Tactical Assault) Special Extreme Mod.
Discussion in 'Project Logs' started by Y.G Casemod, 16 Mar 2020.
  1. Y.G Casemod
    Y.G Casemod Extreme modder
    8 Feb 2017
    THX Bro.:rock:
    The glue for acrylic bonding used is Collacryil K90.
    It's a solvent glue for capillary bonding by means of a syringe with a surgical needle.:dremel:
    ivory2k19 likes this.
  2. BHB Mods
    BHB Mods Minimodder
    15 Jun 2020
    Aah, I need to get me some! Thank you!
  3. Y.G Casemod
    8 Feb 2017
    Welcome back guys.:rock::dremel:
    Update.
    Here is the video where we will see the motorized movement of the armament and the cockpit opening.
    New updates soon.
    Good vision.
    Stay tuned.
    Worklog on:
    https://www.nexthardware.com/forum/...600-tactical-assault-special-extreme-mod.html
    https://forums.bit-tech.net/index.p...-tactical-assault-special-extreme-mod.373394/
    https://community.thermaltake.com/i...ah-t600-tactical-assault-special-extreme-mod/
    Thermaltake Technology Inc Thermaltake-Italia ADATA XPG Global ASUS Republic of Gamers
  4. Y.G Casemod
    8 Feb 2017
    Update.
    Step 1.
    Here is the summary video of the first phase of processing where we will also see in detail the hardware provided by the sponsors.
    Good vision.
    Stay tuned.
    DB Custom Towers likes this.
  5. Y.G Casemod
    8 Feb 2017
    Update.[​IMG]
    Step 2 (part 1).
    In these photos we will see a first part of the custom pieces made, the machine guns, the flaps, the various parts of the internal cockpit (and how I will be assembled), the 2 appendages on the front and on the side airboxes, up to the union of the two parts of the upper cap and the realization of the cover on the back of the MB tray that will cover all the wiring.
    Stay tuned.
    Worklog on:
    Jean R built and Cheapskate like this.
  6. Y.G Casemod
    8 Feb 2017
    Update.
    Step 2 (parte 2).
    In these photos we will see the second part of the custom made parts and the test assembly of the entire build.
    The construction of the Mod is practically completed and now we go to the painting that we will see in step 3.
    We will see the construction of various parts such as the jet engines (simulation) the 2 separate flaps on the side and other parts including in particular the pump cover on the DP 100 D5-Plus distroplate.
    Stay tuned.
    Worklog on:
  7. Yargen
    Yargen What's a Dremel?
    1 Aug 2020
    It´s looking great, the Plexiwork really rocks :) It´s interesting to see how you expand the original design of the case
  8. jones-965
    jones-965 Modding & tuning
    13 Jul 2011
    wow, very inpressive mod!
    Y.G Casemod likes this.
  9. Y.G Casemod
    8 Feb 2017
    THX Master.:dremel::rock:
  10. Y.G Casemod
    8 Feb 2017
    In this video (the first of the worklog),you can see all the 3D CAD design on the Sketchup.
    I didn't have the original technical drawings, and I had to draw the entire mod from 0 starting from a two-dimensional image of the case and a rectangular solid.
    For measurements that are real and actual, I used the case datasheet.
  11. Y.G Casemod
    8 Feb 2017
    Update.
    Step 2.
    Here is the summary video of the second processing phase where we will see all the custom parts made and the test assembly all in sequence.
    Good vision.
    Stay tuned.
    Worklog on:
  12. Y.G Casemod
    8 Feb 2017
    Update.
    Step 3
    In these photos we will see the first parts completely painted and finished.
    The painting was done exclusively with the airbrush,
    carried out with the Marble and Preshading technique which is carried out in many steps.
    Specifications and painting steps sequence:
    Final color: Nato black Stealth Camo.
    Phase 1: Sanding pieces with 600 and 800 water-based paper.
    Phase 2: Primer and matt black then sanding with 600 and 800 water based paper.
    Step 3: White marble with airbrush.
    Step 4: Shade 1 with Light Sky Gray.
    Step 5: Shade 2 with Dark Sea gray (slightly darker).
    Step 6: Black marble with airbrush.
    Phase 7: Filling with Nato black (the lighter marbles must be seen in transparency).
    Step 8: Cleaning of paint spray residues with Ammo Mig Enamel Thinner.
    Step 9: Finish with 2 coats of Alclad II ALC-313 matt clearcoat.
    NB.This procedure must be carried out for all parts.
    The result is exactly as expected.
    Stay tuned.
    Worklog on:
    Jean R built likes this.
  13. Y.G Casemod
    8 Feb 2017
    Update.
    Step 3
    Final assembly of the supporting structure of the upper shell / cockpit.
    In these photos we will see the assembly of the parts and gas pistons.
    Note in particular the replacement of all rivets with countersunk screws in stainless steel with hexagonal insert.
    The countersink was made for each hole.
    Very demanding work.
    The engine also arrived, Intel Core I7 10700 KF.
    Stay tuned.
    Worklog on:
  14. Y.G Casemod
    8 Feb 2017
    Update.
    Step 3.
    In these photos we will see the final assembly of the MB tray with all it's parts and the final assembly of the base of the case.
    In the details of the MB tray we can see in addition to the front cover also the raised supports in the back that will be used for the closing bulkhead to ensure that the wiring is practically invisible.
    All obviously fixed with countersunk stainless steel screws with hexagonal insert.
    We will also see the lower part of the base of the case with all the parts that make up the stabilizer mechanism for the excursion of the 2 side machine guns consisting of guides and gas pistons.
    Stay tuned.
    Worklog on:
  15. Y.G Casemod
    8 Feb 2017
    Update.
    Step 3.
    The monster begins to take shape.
    Here is the detailed sequence of the first parts in final assembly.
    New updates soon.
    Stay tuned.
    Worklog on:
  16. CustomRigs
    CustomRigs CallMeCleaner
    8 Dec 2017
    impressive work !
  17. Y.G Casemod
    8 Feb 2017
    Update.:cool:
    Step 3.
    The works are proceeding.
    In these photos we will see the final assembly of the canopy / cockpit and all its parts in detail.
    Particular attention should be paid to the painting of the details in the particular parts such as the turbines and the freehand weathering.
    New updates soon.
    Stay tuned.
    Worklog on:
  18. Y.G Casemod
    8 Feb 2017
    Update.
    Video Step 3 (part 1).
    Here is the first part of the summary video of the works carried out in step 3.
    We will see some of the more than 300 custom built parts and how they were assembled when finished
    Good vision.
    Stay tuned.
    Worklog on:
    censored_Prometheus_ likes this.
  19. Y.G Casemod
    8 Feb 2017
    Update.
    Step 3.
    Penultimate worklog update pending video card.
    Here is the sequence of photos of the parts made so far.
    We will also see the first photo of the final assembly.
    NB. The 512GB ADATA SX 8200 PRO SSD was mounted with the heatsink that came with the Maximus Extreme XII and installed into the pre-arranged DIMM on the motherboard.
    Also note the splendid ADATA Spectrix D 60 G rams.
    In the next and last update we will see more details of the permanently mounted parts and the assembly of the custom loop.
    Stay tuned.
    Worklog on:
    lowfat and Jean R built like this.
  20. Y.G Casemod
    8 Feb 2017
    Update.
    Step 3.
    The final assembly continues.
    In these photos some close details, in particular the final assembly of the pump cover, the instrumentation inside the cockpit and the custom sleeve cables.
    Stay tuned.
    Worklog on:
