Project Interceptor - Interactive Modding!!
Discussion in 'Project Logs' started by TheGreatSatan, 16 May 2007.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    Here's the reason the lightbar is being repainted.
    http://www.youtube.com/watch?v=6-zUfvUsq_o
    But the bigger problem is that I've repainted it again and it still looks like crap. The actual color under the red is orange. I thought a light coat of red would make the orange side look good, but no matter what I do it doesn't improve. Suggestions?
  2. TheGreatSatan
    5 Aug 2005
    Big decision! Thank you Larrs27 from TwistedForums! I'm getting rid of the box I made and then I'm cutting the top of the case here:
    Then setting the lightbar into the case (like a real cop car (duh?!))
  3. TheGreatSatan
    5 Aug 2005
    As I said, I'm gonna mount the lightbar within the top of the case. Here's the 1st cut
    I had to cut through the drive cage too.
    That was some pretty thick steel.
    And here it is. More coming.
  4. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    Ey , looking good :)
  5. TheGreatSatan
    5 Aug 2005
    I removed the cover from the lightbar
    And here's the situation inside.
    All the black stuff around the bulbs is silicon. I think it would do a lot of damage to remove the amber bulbs and replace them with red ones. I will, however, try with one of the corner bulbs to see exactly what I could be getting into.
  6. SPQQKY
    SPQQKY Evil Modder
    7 Jul 2007
    Tamiya makes a clear paint, I think it would work much better for your mars bars.
  7. Tyinsar
    Tyinsar 6 screens 1 card since Nov 17 2007
    26 Jul 2006
    OK, it's late and I'm tired and I'm not sure amber LEDs Can be filtered to make red. However, I'd try a filter in the violet to blue range. Truth is, I suspect it will just block too much light.
    Also, Is there anyway to change the speed of the blinking? - It looks a little fast to me.
    Good work so far though :thumb:
  8. TheGreatSatan
    5 Aug 2005
    I went with a plastic drying paint called Fire Engine Red and while it dries....
    I added a switch to the lightbar that will attach in the back.
    Check it out here:
    http://www.youtube.com/watch?v=n3K9O3n8WTE
  9. TheGreatSatan
    5 Aug 2005
    It's been a week since I've updated you because I've been working 40 hour weeks and doing finals for school, but I will be back to it next week.
  10. Morphine-Kitty
    Morphine-Kitty Dead account.
    22 Apr 2007
    Hope you do well on those finals, and can't wait for the next update. :thumb:
  11. TheGreatSatan
    5 Aug 2005
    Finally a little bit more done.
    I attached the lightbar wires to a molex and added a switch to the back.
    Then I put in a 400 Watt Antec. Any idea on what to do with the wiring mess?
  12. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    sleeve it and tuck it away somewhere.... if you have space you can put it on top of your PSU.
  13. TheGreatSatan
    5 Aug 2005
    Anything Police-Like?
  14. Morphine-Kitty
    22 Apr 2007
    Maybe hide it behind a custom motherboard tray that has a sheriffs badge painted on?
  15. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Sleeve it in white sleeving with black heatshrink.
  16. dacust
    dacust What's a Dremel?
    10 Mar 2007
    My vote goes for this.
  17. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    testors candy red paint (model paint) works great. it is clear, so it doesnt look so opaque like what you have and it only gives off a red light. i painted my taillights (altexxa-style) with it and i love it. it comes in a little spray can and i got it at wal-mart. several coats of that should work and look a lot better than a half-opaque light bar. if that doesnt work, replacing the LED's is your best bet.
  18. TheGreatSatan
    5 Aug 2005
    O.K. I really need to complete this real soon as I am starting another project. Here's the top with black electric tape (Just for show), I think I may use silver instead.
  19. Morphine-Kitty
    22 Apr 2007
    I like the look of the black. :thumb:
