Project: Inu (first mod of mine) [UPDATED 23.10]
Discussion in 'Project Logs' started by dewon, 13 Oct 2004.
  1. dewon
    dewon What's a Dremel?
    13 Oct 2004
    So...This is the first time I'm involved in modding.
    This case will propably be one of those "blue case and a blue cathode" things, but anyway, I'll put this here.
    So, the case is compucase's damn ugly white 6919. I'll do a side- and topwindow to it and make a hole to the front for a radiator. I'll also paint it.
    Heres a pic of new 6919
    More to come... :dremel:
  2. Caso
    Caso What's a Dremel?
    20 Mar 2004
    good luck ;)
  3. dewon
    13 Oct 2004
    After pulling down the case, i searched a nice bunnypic from web and drew it on a top of the case. Click picture for bigger pic.
  4. dewon
    13 Oct 2004
    Then I made a starting point with drilling machine and cut out the figure with compass saw. Afterwards I figured out that I should have sawed closer to the contour. :rolleyes:
  5. dewon
    13 Oct 2004
    Unfortunately I didn't took a pic when dremeling, but this is how it looked after that. I also drilled the pop-rivets away and separated the body from the case.
  6. Redd_Herring_1974
    Redd_Herring_1974 What's a Dremel?
    3 Sep 2004
    im not seein any pix after the very first post at all not even a red x :confused:
  7. dewon
    13 Oct 2004
    After that, I made a hole for the radiator to the body.
    That was an ordinary compass saw action.
    The next thing to do is to paint the body, but I'll not do it until two weeks.
  8. Rexxie
    Rexxie What's a Dremel?
    18 Nov 2002
    Hah, nice playboy logo :p
    Looks like a nice bit of dremeling, good work :thumb:
  9. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    Looks nice so far, but dude seperate the unipanel. Those things drive me nuts.
  10. dewon
    13 Oct 2004
    What do you mean by unipanel? Sorry, as you can see, my english isn't fluent enough.
  11. Tulatin
    16 Oct 2003
    look at how the top, right and bottom panels are all one. You could cut the right panel out of that, making your case now having four independant panels over two. Along with that, you could detach/attach the right panel as neccicary, and gain access to the wire hiding places behind the motherboard.
  12. Litecore
    Litecore What's a Dremel?
    21 Sep 2003
    yeah, i gotta agree with that. sure is one strange looking panel.
    i dont think i've ever seen any case like that before. just wierd..
    anyway, your playboy cut looks good, a bit of filing left though :thumb:
    MOD ON ! :dremel:
  13. -Enforcer-5716M4
    -Enforcer-5716M4 What's a Dremel?
    1 Sep 2004
    You should paint the case (or the frame) pink, and the frame (or the case) black...... Really Hugh Heffner style
  14. Buzku
    Buzku What's a Dremel?
    7 May 2004
    Anna palaa!
    Good luck!
  15. Thealien=CCTF=
    Thealien=CCTF= What's a Dremel?
    1 Aug 2004
    Jepso :hip:
  16. dewon
    13 Oct 2004
    So...A bit of progress here.
    Half of the painting is done. But everything didn't go as planned (as usual).
    Maybe we should let the pictures do the talking :)
    This was the paint, which I planned to do the paintjob of the body (inside the case)
    Here it is, it was really nice looking paint.
    But...Okay, it was a small can, but I believed that there would have been a little bit more of it.
    So I went to search through our garage and found some blue paint. Actually I didn't like it, but it'll do.
    But what has happened? Well, i put some tape too early :duh:
    Fortunately the rearpanel will be against the wall, so no one will see it.
    Of course I painted the radiator also! :)
    More to come. I'm eager to see how ugly this will look :hehe:
  17. blknoel
    blknoel What's a Dremel?
    14 Jun 2004
    :sigh: I'm not sure if thick layer of paint reduces the thermal performance of a rad ?
    (black and blue, nice, but the "blue" you used does not seem right to me :( )
  18. dewon
    13 Oct 2004
    Then I must gently sandblast it. Well, we'll see.
    Flash distorts the color, but I don't like it either. But I didn't have anything else in shelfs. :sigh:
  19. DigitalX
    DigitalX What's a Dremel?
    26 May 2004
    Mitä vittuu, jätkä modaa saunassa. :wallbash:
    WTF! You are modding in Sauna. :duh:
    ainakin näyttäs siltä.
  20. Muon
    Muon What's a Dremel?
    1 Dec 2004
    it looks pretty good to me, i was waiting to see this painted ^^ ya know, sometimes its good to not be anxious and wait on getting more paint ;)
