Project: invalid LI - Update 4-03 - COMPLETE for now...
Discussion in 'Project Logs' started by invalid, 7 Mar 2005.
  1. unrealhippie
    unrealhippie What's a Dremel?
    24 Jul 2004
    thats really really cool! looks so good on the outside!
    Keep us updated! :rock:
  2. invalid
    invalid What's a Dremel?
    23 Jan 2005
    My server is down right now. Sorry for red x's. Should be back soon. :(
    Edit: Back up
  3. invalid
    23 Jan 2005
    Server back up. Pics loading. :thumb:
  4. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    amazing pics, first time i have seen the window the other side (and making a good clean job of it)
    - S
  5. mightynimrod
    mightynimrod What's a Dremel?
    7 Jan 2004
    Looks very clean matey......looking forward to more :D
  6. Pistol
    Pistol Guest
    Curses...I suppose I'll settle for not being first for the outside window idea...
    ...Zap's AMD Shuttle did the outside window, I saw it in person at Quakecon, it was really very nice. It's where I got the idea.
  7. mightynimrod
    7 Jan 2004
    Has anyone put some LED's in an outside window?
    By that i mean into the outside edge so the whole lot lights up with the perspex acting like a prism.
    Could be a good mod :D
  8. invalid
    23 Jan 2005
    I've seen it a few times as well. Just could never remember where. lol
  9. Razor_cut
    Razor_cut What's a Dremel?
    12 Mar 2004
    Like it two that you put the window outside the case :thumb:
    Dude, what cooling are you going to use? water air etc..?
  10. Pitbull
    Pitbull What's a Dremel?
    20 Mar 2005
    look great keep on modding :rock:
  11. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    Very very very shexy!
  12. invalid
    23 Jan 2005
    Air will be used at first. Water down the road. When I get the water stuff I will remove the HD bay at the bottom and insert most of it down there.
    Now I am moving to the inside of the case while I wait for some more stuff. :)
  13. invalid
    23 Jan 2005
    Small update
    Worked on the front intake.
    First I measured a center point and drilled a starter hole.
    Next I drilled a hole for the 92mm fan hole. Then I screwed on the ring for a quick look.
    Then I installed the fan with spinner on the middle.
    Also I repainted the hose so the inner area was black and not blue like before.
  14. grumblemarc
    grumblemarc What's a Dremel?
    12 Dec 2004
    Sweet sweet. I'm going to do something smiliar on my LI. Did you lose the Power/HDD activity leds by mounting that there? I plan on moving the 120mm fan up there as well and when I do I'll have to nix that.
    Also like the idea of the shower hose as well. Again I have something similar planned but with clear tubing and 6 holes drilled.
    Great minds do indeed think alike.
    BTW. It looks like you did some work in the front drive cage area. What are those 3 bolts for?
  15. G4m3R_X3r0
    G4m3R_X3r0 What's a Dremel?
    3 Sep 2004
    That is just B E A Utiful!!
  16. invalid
    23 Jan 2005
    The power and HDD led will indeed be mounted elsewhere. Although where exactly is still being weighed. I bought some chrome led holders for where ever I end up mounting them. When I mounted this I could have moved it up to keep the front usb, etc ports but I have no use for them so I decided to put it as low as possible to cover this area instead. Even with that I still had to lose at least the HDD activity led. So I finally decided to lose both on the front all together. Leaving only the switch.
    The 3 bolts in the drive area are to hold some wire mesh that will cover the area below it from the windows view. The window design shows a small area of the bottom on the left and really there is nothing there to see. (The last picture above shows this) So I wanted to mount something that let light shine through, but would not really grab your attention. So above you are seeing the bolts, but I have not yet added the mesh in that picture.
  17. pr0xZen
    pr0xZen What's a Dremel?
    5 Nov 2004
    I really like it :) A nice job so far, looking forwards to see it complete.
  18. dubya01
    dubya01 What's a Dremel?
    22 May 2004
    those fan rims are so frickin hot and secksie...
  19. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    This is so smart, the chrome rings from mnpctech really do give it some class :baby: Keep it up, you're setting standards for us all :D
  20. invalid
    23 Jan 2005
    Thanks guys! :rock: Heres a new pic with some of the hardware that came in thus far. Waiting on more.
