Scratch Build – In Progress Project: Iron Revenge -- Finished--
Discussion in 'Project Logs' started by Herodj95, 9 Sep 2011.
  1. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    Hi all,
    my name is Francesco and i from Italy! :)
    Nice to meet you! :D
    Before presentation i believe that is'n my first project, i have create other cases!
    I want to show you my last project!
    It's name is
    IRON REVENGE
    Materials
    In this mod i want to use more sheets of iron, excactly sheet of 1.2mm for the "body" plexyglass for the lateral panels and angular of alluminium
    Use of the case
    First, this case will be built from 0, so I can build a case according to my-self ..
    Let's say that this case comes prepared for a water-cooled setups, but until there are a few of money available i install the configuration of my htpc :duh:
    Furthermore, this case will not be developed in length (as all the "normal" cases) but in width as the liquid in case I did not have to install at least I would not be limited to the installation of tower heatsinks (mugen 2 or other big heatsinks if i didn't install the liquid cooling) ..
    The dimensions of the case are very small and compact: 33 cm (depth) - 45cm (height) - 19cm (width)
    Cooling
    As a fan I will use the 2 Enermax 120mm TB Silence placed on the front and 2 Enermax T.B Silence 80mm on top!
    I chose for their first silent and then for their price / performance ratio!
    Lighting and colors
    I thought as a light to illuminate the case with the red neon that I will need for a specific thing you can see soon on this mod!
    The case will be painted only in black but the front of case will be painted whit metallic grey!
    After this i show you the first up!
    :thumb::rock:
  2. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    COOLING
    ok, start with the first pack!
    this is the content! :D
    i love it! :blush:
    _________________________________________
    SLEEVING
    a clue of second pack:
    :hehe::hehe:
    opend the pack:
    there are:
    - 50 precuts of heatsrink
    - 10mt of white sleeving
    - 10mt of black sleeving
    and an offer from Nils
    after i have sleeved the cables of all T.B silence
    SLEEVING 2
    With a little patience I have sleeves on 24-pin individually :)
    PS: Molex is still painted
    Here is a picture of the ensemble:
    (blur :duh:)
    with the red sleeve (offerted from Nils) i have sleeved the cables of the VGA (a stupid nvidia 8400GS :wallbash:) and the cable of the heatsink (Arctic cooling 7 LP)
    and the 4 pin of the motherboard...
    the sleeving has be done without an extractor... because i have created one! :idea:
    i have sleeved the cable with there!
    all with a litte screwdriver and a paper clip! :jawdrop:
    Here's how I did it:
    I put the paper clip on one side of the pin
    The screwdriver on the other side:
    Grave screwdriver ... aaaaaaannnnnnddddd!
    sleeeeeeeeeeeeevvvvvvvvviiiiiiiinnnnnnng!!! :rock::rock::rock:
    _______________________________________________________
    FIRST CUT
    ok, let's start with the first of 5 plates that I will use in this mod ....
    The plate is made of iron of 1.2mm and with sandpaper and water, which I removed all the rust on the sheet
    So, I will use this sheet to create the "compartment" between the top (where there will be the motherboard and his sons :hehe:) and bottom (power, HDD, CD burner, etc.) and I had in mind to reproduce the logo of the mod whit the dremel :dremel:
    i bend it!
    So with the help of dremel, discs 409 and begin to cut the plate! :worried:
    Iron Revenge :rock::clap:
    But you think I'll leave it without even make perfect it?? no! :nono:
    So armed with a profile of alluminium and a rasp i'm going to align all the letters... before the bottom line
    and then the upper
    the result! :clap: :D
    turn on the lights! :thumb:
    for today it's all!
    wait the next up! :D
    Bye :)
    Fuganater likes this.
  3. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    anyone? :(
    go with the second plate!
    I trace the lines to be bent ....
    i haven't a vice and i can't bend it... but i have an idea! :idea:
    with 2 terminals and a profile of alluminium fixed on my house's ring i have created a vise!! :thumb::D
    Good!!! :clap:
    And finally, the end result ....
    while we are stuffing it for good .... :rock:
    everything seems to fit :thumb:
    i want to trying with engraved plate...
    Ok, that's all for today!
    See you soon! :)
    bye
  4. Rai
    Rai What's a Dremel?
    22 Jun 2011
    Interesting vice. :lol:
  5. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Good job on cuttin the letters out. I know how long it takes to file that stuff to get it perfect.
  6. jamsand
    jamsand Minimodder
    21 May 2011
    Don't seem afraid of a little hard work withm all the sleeving and filing going on lol. keep up the pace :)...letters look great btw :)
  7. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    thank you all :D
    in the evening new up :thumb:
  8. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    sorry but i have problems whit the connection and i haven't posted the work! :(
    in this up i show you a lot of things, first I created the predisposition to install a 120/140 mm fan on top of the "compartment" further to cool the power supply "warm"
    Well, now I can proceed to design the backplate of the motherboard, where these profiles have enlightened me :D
    detail of profile:
    I now explain, i want to use these profile to create a cable menagement system in the case and to make it i use a plexyglass sheet fixed on the profile and on it i'm going to lodging the motherboard!
    to do it i cut the first sheet of plexyglass of 3mm to do the motherboard tray!
    after the cut:
    and ther is whit the profile
    obviously i cut the profiles :hehe:
    next i have cut the profiles at 45 degrees to do a perfect 90° angle :thumb:
    i assemble the profiles...
    i add the plexyglass sheet (but i haven't fix it because before i must fix the profiles)
    on the plexyglass sheet i have do the holes fot to fix the motherboard...
    to fix it i use an home made system....
    at the first i get the screw
    i block it with a nut
    insert the o-ring
    and when i have intalled the mobo i lockit whit other nut...
    ok, it's time to try on it the mobo!
    Fit perfectly! :thumb::thumb::thumb::rock::rock:
    Ok guys, we have finish for today!
    Bye bye! :)
  9. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    Today I am dedicated to the backplate of the motherboard where I finished making the structure
    to fix the profiles i haven't buy angular because i have created they...
    a very simple thing where I have used a discard of a iron sheet....
    i have cut 4 strips from it...
    next i have bend and hole they but i have lose the photos :duh:
    this is the result!
    it's very solid and heavy! :clap:
    this is one of 4 angular created.... it's fixed by 4 rivets every angle!
    Detail of angle....
    and just to finish I also tried the plexyglass on the angular's structure!
    next i have get the last sheets of iron ... on they i'm going to create the rear panel whit motherbard and its pci-e slots at the first and the space to fix 2 fan of 120mm and the cd burner aperture on second!
    i'm going to draw the cuts on the future front panel...
    too on the rear panel...
    and now.... who want to see the result??? :D
  10. Omoobhs
    Omoobhs One giant fsb hole
    15 Nov 2010
    I'm certainly wanting to see more! :D
  11. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    hey guys... i'm back! :)
    i have lost the photo of the cuts but i have the photo of the final result :D
    After 6 hour of dremel and rasp i have obtain this!
    i have cut the front and the rear of the case, and i have glue the plexy mobo tray on the structure... at the moment the panels are locked by a paper tape, in a next time i'm going to fix all of there whit a trasparent silicon (i have choise it to use it to avoid to use all screws)
    next i have cut a piece of black plexyglass and whit a 120mm hole saw have create the holes fot the 2 fans...
    turn on the neon...
    and this is the moment to install the fans..
    for the moment this is all... see you soon! :)
    Bye! :clap:
  12. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Looks like a back breaker! nice idea though
  13. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Wow with the limited tools you have, this is coming along very well :thumb:
  14. DK63
    DK63 Resident magpie
    8 Sep 2009
    Looks very nice so far.
  15. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    thank you all! I'm very happy you like this! :)
  16. jamsand
    jamsand Minimodder
    21 May 2011
    coming together nicely
  17. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Good luck with the project, good start :)
  18. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    Thank you too, in the evening new up!! : Thumb:
  19. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    hey guys, i'm back... sorry for my absence, but I've got a problem with internet but now i'm back i show you my updates what i have do in this time....
    after complete most parts of iron sheets panels we going to fix they...
    We start with the front and back panels... i'm going to fix they at mobo's backplate structure whit a the rivets :)
    ok, remove the first part of backplate...
    i'm going to copy the holes to the panels...
    i do the holes and i rivet the first panels ;)
    and now the other panel..
    After this I going to try the motherboard on the backplate :)
    PERFECT! :clap::clap:
    Now see the back panel :rock:
    Perfect too :D
    now i show you the future disposition of the component in the case... :worried:
    and now with engraved sheet :dremel:
    Continue ...
  20. Herodj95
    Herodj95 Minimodder
    9 Sep 2011
    The next up include the work on the "grond" of the case...
    i have do some cuts :)
    Do you remember the alluminium profile that i have used for the structure??
    Now, i have cut they in the half and i have create the "home made angular" :dremel:
    i'm going to try the bended sheet in the structure.... It fits perfectly :clap:
    After this i'm going to fix they at the bended sheet...
    Continue :worried:
    :hehe::hehe:
