Scratch Build – In Progress Project: Iron Revenge -- Finished--
Discussion in 'Project Logs' started by Herodj95, 9 Sep 2011.
  1. Herodj95
    Herodj95 New Member
    9 Sep 2011
    Purchasing Day :hehe:
    I'm going to buy some thing for my Iron Revenge...
    2 black satin spray (but in this mod i use one other color for the front panel :)
    2 sheets of acrylic
    2 packs of screws
    now see my favorite screws :blush:
    After this I going to get the measure to create the lateral panels (thee will only acrylic)
    and the first is cut...
    Can you see the little recess of the structure than the panels... then, i have do it to encase the acrylic sheet on it to have an homogeneous structure :)
    ok guys, for today i close there....
    See later :D:thumb:
    Jampotp likes this.
  2. Jampotp
    Jampotp dem spacers are well phat init blud
    11 May 2010
    Great work! The "Iron Revenge" text looks really good - and you did all that with a Dremel!? :clap:
  3. Herodj95
    Herodj95 New Member
    9 Sep 2011
    Yes i have do that all with the dremel! :thumb:
  4. L1U
    L1U Member
    1 Sep 2011
    can't wait do see your dremel skills ;)
    (in bocca al lupo)
  5. Herodj95
    Herodj95 New Member
    9 Sep 2011
    Thank you L1U :)
    ok, start with other up :D
    now, i have get one other iron sheet!
    There i'm going to install 2 80mm T.B Silence, an usb Hub and the power botton!
    Start whit the allogement of the fan...
    And you can see the future position of the hub! i'm going to do an hard work of file!
    and this is the hub where i'm going to install!
    after the other works i'm going to try the sheet on the top!
    After i'm going to cut the 2 pieces signed!
    ok, now i show you the top complete! :D
    the usb hub cutted!
    and the space to fix the fans...
    now i'm going to install the hub...
    Yeah!
  6. Herodj95
    Herodj95 New Member
    9 Sep 2011
    now i show you the guide to fix the engraved sheet :)
    Cut 2 pieces of angular...
    With the silicon i fix the at the panels...
    When it is dry I try the guide!
    Good! :clap:
    when i finish the guide i have cutted the panel for the 120mm fans on the front panels!
    now i'm going to fix the power supply...
    but i don't fix it whit the all chassis but i'm going to delete it and use only the pcb....
    Cut a piece of iron sheet...
    bended!
    and there is its future space...
    after i cut a piece of plywood and i have create the base of pcb...
    paint it!
    and this is the final result!
    at the next up i show you the power supply pcb installed on it! :)
    But this you can see tomorrow! :D
    Bye bye! :dremel:
  7. Herodj95
    Herodj95 New Member
    9 Sep 2011
    hey guys! other updeates! :D
    Today i have create a panel for power sypply card!
    on it i have installed the power connection and the switch to turn on/off the neon! ;)
    After this i'm going to paint it...
    and now is installed on the back panel of the case...
    And there are the holes to block the powers supply support...
    installed (yes, when i'm going to assemble the case i change the card ;))
    all closed! (sorry for bad photo :()
  8. Herodj95
    Herodj95 New Member
    9 Sep 2011
    now i'm going to fix the top!
    i cut other angular and i fix they with the silicon...
    when it is dry i can take off the clamps...
    try it!
    Perfect! :)
    there is the interior...
    now i'm going to to the holes on the top to fix it!
    and.... i have cut the screws!
    ok, we are a good point!
    Before close i have do 2 holes at the mobo structure to pass the cables behind the mobo plate from the base (where is the accomodation of the power supply)
    and next i do 2 other holes for 2 screws useful to block the base at the mobo structure....
    ok guys.... for today that's all!
    no! i have get this mini-pack.... what's into it??
    At the next UP :p
    Bye bye ;)
  9. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Very nice work mate :).
  10. Herodj95
    Herodj95 New Member
    9 Sep 2011
  11. Herodj95
    Herodj95 New Member
    9 Sep 2011
    Hero is back! :)
    Today i show you the content of the pack!
    there is the content!
    :rock: :rock::rock:
    of these 2 i'm going to use (at the moment) one of there.... this!
    This is the back of the bottons!
    there is the final result!
    1 line for the power and 1 for the light!
    Yeah!
    Now, i'm going to install it into the top panel!
    That's a big hole (19mm)
    fix on the power botton!
    turn on the led!
    A general looking!
  12. Herodj95
    Herodj95 New Member
    9 Sep 2011
    the top is finished and i can paint it!
    There is the result!
    Botton installed!
    and this is a test with the screws....
    and install the usb hub!
    get the acrylic panel for T.B. Silence 80mm!
    I like it! :D
    a fast test on the top!
  13. Big_malc
    Big_malc Well-Known Member
    7 Sep 2010
    Socket head bolt not screw :thumb:
  14. Herodj95
    Herodj95 New Member
    9 Sep 2011
    now i have create a little cage for the Cd burner and the hard drive!
    and this is his future allogement!
    and i paint it!
  15. Herodj95
    Herodj95 New Member
    9 Sep 2011
    sorry but I didn't know their english name! :)
  16. Big_malc
    7 Sep 2010
    was only kidding m8 :p you going to spray all of case or go for a powder coat ??
    nice work on little bracket for hdd and drive :thumb:
  17. Herodj95
    Herodj95 New Member
    9 Sep 2011
    now i start to paint the other parts!
    start with the engraved sheet!
  18. Herodj95
    Herodj95 New Member
    9 Sep 2011
    I'm going to paint all case pieces whit a satin black, but the front will paint whit a galvanizing spray ;)
  19. Herodj95
    Herodj95 New Member
    9 Sep 2011
    And after a long day of paint this is the result and all the component (without the hardware) that i'm going to install!
    Who want to see the the case installed??? :D
  20. Big_malc
    7 Sep 2010
    careful with galvanizing spray can clog and run like a bitch
