Case Mod - Complete ⭐ Project J.A.R.V.I.S (reborn)
Discussion in 'Project Logs' started by Deblow, 18 Jul 2019.
  1. Deblow
    Deblow Minimodder
    12 Dec 2013
    It's a mission, I will have some bad tennis elbow when done lol
  2. Deblow
    Deblow Minimodder
    12 Dec 2013
    The video as promised, hope its easy to follow and helps show things in a bit more detail.
  3. Deblow
    Deblow Minimodder
    12 Dec 2013
    Taken a break from modding due to a recent family bereavement, during this time some more parts have arrived so I will start by updating the log with
    the items and intentions for them.
    Over the next week I will post some more of the build progress.
    Thanks to my new sponsors ADATA and EL Wire&Tape for sending me some cool bits for the build.
    https://elpanelandtape.co.uk/ have provided parts for other projects in the past so very happy they are on-board as I know the quality cant be beaten.
    EL tape for some logos and case feet, along with some splitters and the power brick to run them all.
    ADATA provided the SX8200 M.2 card for the main boot device and a SSD.
  4. Deblow
    Deblow Minimodder
    12 Dec 2013
    The moving metal panels on the side of the gantry are also 3D printed, along with all the other parts I have spent 100s of hours planning, designing and working on the 3D renders/ then converting to usable print files, starting with smaller or lower resolution prints to check they look the part and function as intended before printing the higher quality versions at full size.
    So this is the parts that will attach to the main gantry arms on both sides, so im making double but the design and shape will be different per side.
    Depending on what the weather is like, I swap between painting, sanding and the printing.
    So moving back to the base, this needs a lots of finishing like the 3D prints, because it will be painted with high gloss paints (2K) the primer and base need to be PERFECT or all the gaps, bumps and other imperfections would show.
    Glued, nailed and some screws are used to hold the base together, all them need to be as flat as possible, any that stick out slightly are sanded and filled, then the wood base paint is applied over the MDF sealer.
    This is the first grey primer of many, in total it will have around 4 full coats that will all be sanded back and left to dry for a week.
  5. Deblow
    Deblow Minimodder
    12 Dec 2013
    Here's some photos showing the arms im still working on sanding, can't wait to be done sanding as my arms and fingers hurt bad [​IMG]
    The arms are very big fully extended but will fit nicely in place once bent to the correct angles needed for the parts they will be holding.
    The wood filling is also nearly done and I will be priming the arms soon, had a spot of bad weather so I have invested in a rather large tent to use as a temporary paint shop.
    Some of the 3D prints need filling also, a couple of my first ones didn't go to plan but I improved as I went along by tweaking the settings, all part of the fun with 3d Printing.
    I will have x4 of these arm parts, they will be the main parts holding the robot arms to the frame but allowing for movement so I can position them and change position without much trouble.
  6. Deblow
    Deblow Minimodder
    12 Dec 2013
    The fan covers for both the sides are now printed and most the pre work completed.
    Some more filling and sanding needed but they will soon be ready for the base colours and top coats.
    Doing the paint right, using high quality car paints for the bulk of the build, some parts will have some airbrush work on top of the main paint.
    Some more parts for the build have arrived, x2 pacific r22 reservoirs.
    Unfortunately the water cooling might look a little overkill for the build due to problems getting hold of a GPU waterblock, so I might reduce the amount of RADs & pumps used down from x2 to just 1 each and use the spares are props.
    Still getting very bad weather in the UK and all my painting has to be done outside, so I have built up a temporary canopy, its surviving at the moment but can be a problem on windy days lol.
  7. Cheapskate
    13 May 2007
    THERE'S Mr Bean! The poor guy is hidden under boxes. :lol:
    You should be using finishing/paneling nails. They make a punch for them so you can tap them into the wood deeper. It's a lot easier to fill a dent than it is to sand off a nail head.
    Deblow likes this.
  8. pcroombrasil
    pcroombrasil Minimodder
    27 Nov 2017
    my god
    Deblow likes this.
  9. Deblow
    Deblow Minimodder
    12 Dec 2013
    haha poor Bean, i was going to change that poster but had a major flood that distracted me :(
    For the nails, I wasn't planning on using any but had problems using the clamps so grabbed some I had close by lol.
    Countered most the screws that wont be covered but some of the nails will have more panels over them so shouldn't see any sign they was used hopefully.
  10. Deblow
    Deblow Minimodder
    12 Dec 2013
    It's full steam ahead now all my parts are/have confirmed/arrived.
    This is the 3rd primer getting put down on the main frame for JARVIS, the first was MDF/wood sealers then grey primers and now the black primer, this will all be sanded down for the 3rd time, followed by a black base (mat), some gloss on top of that, then silvers and chromes.
    Link to FB Video -
    kim likes this.
  11. Cheapskate
    13 May 2007
    Lat pic is like a robot torture tent. :worried:
    Deblow likes this.
  12. Deblow
    Deblow Minimodder
    12 Dec 2013
    The neighbours have been very curious as to whats going on, seeing me walking in and out with strange looking robot parts lol
  13. Deblow
    Deblow Minimodder
    12 Dec 2013
    New design for the top of the case with the added keyboard, case stripped and modded a bit to allow for all the lighting another other things.
    Black primer now completed on all the parts, base black in progress and will be followed by the other paints asap.
    Had some problems uploading to the forum so I have a backlog, next post going up soon.
  14. Deblow
    Deblow Minimodder
    12 Dec 2013
    The edge panels for the lv20 case are very easy to remove making it easier for me to paint, sanded down the original plastic, primed and a basecoat of black before quickly adding some clear on the top.
    This finish looks great as is, but once its hard and been sanded you get a very smooth finish that's even better to see in person.
    after some sanding prior to buffing
    Once buffed they look great, even as gloss black but im wanting to go with a dark chrome
    with the dark chrome they really help the centre panel pop. 20191126_105150.jpg
  15. Deblow
    Deblow Minimodder
    12 Dec 2013
    Very happy to be using the Nvidia RTX 2080 in JARVIS, this will be obviously be watercooled to make use of all my Tt cooling [​IMG]
    Prior to the GPU arriving I did a test on all the lighting and other components, problems with the MB so I bought another.
    Should be good to go now, only the GPU to be added in to the loop along with some internal panels to cover the wires and other parts
    I want hidden to help keep it clean looking.
    craigbru and Cheapskate like this.
  16. WarBoys
    WarBoys What's a Dremel?
    25 Nov 2015
    OMG a lot of parts :jawdrop:
    Deblow likes this.
  17. 4LIEN
    4LIEN Modder
    4 Jan 2020
    WOW i love this project, i'm really curious to see the finish look! Good job!
    Deblow likes this.
  18. Deblow
    Deblow Minimodder
    12 Dec 2013
    Thanks guys, should be done soon, I will get some more photos up this weekend.
    Just had some issues with the MB and blocks that's messed with my timeline but now resolved
    hopefully.
  19. Deblow
    Deblow Minimodder
    12 Dec 2013
    The last time you will have seen the base the black base-coat was down, then I sanded, sanded and sanded, possibly 2 or 3 days spent sanding the base and the arms.
    every layer of paint has to be perfect or the end result will be turd.
    Once all that hard work was done I stayed in the shed as the weather had dropped to -1c in the paint tent, so I got myself a new heater and continued with the gloss top coat, this was done in 3 stages to ensure it had a nice thick coat to make it super resistant to possible bangs and scratched should this end up at a show.
    Although I had my shed done up like a Dexter kill room, a daddy long legs decided to drop in and stick around lol
    The sides had lots of orange peal, I was aware of this problem as I painted but needed it to be very thick.
    The base was not too bad as its flat, but still needed sanding one last time to make it 100% flat and get rid of the daddy long legs.
    This is how it all looks when fully sanded flat.
    Next stage is the fine wet sand and polish, I didn't take many photos as it was too messy.
  20. Cheapskate
    13 May 2007
    That's a mosquito hawk, and a default accessory for paint jobs in my region. Be thankful it's only one.
    Deblow likes this.
