--Hello Community-- This is my first work log in english so if you find some errors or something else please let me know! Thank you and enjoy it First to me My first project was an HTPC from air cooling to water cooling, but I have only the german work log, so I don´t know if I can link it here. If someone want to know more about this project send me a PM. But now it´s time for something new and bigger thing, a real case mod! The pictures are taken with a Canon 700D so the quality should be better as my cell phone. Info: The hardware is still adjusted and ordered, as well as the cooling, as soon as all components are fixed, the start post is adapted and the photos are added. The Project As already written in the title, the project name is J.A.R.V.I.S. as the AI of the film Iron Man, now you can imagine how it should look like… Case: The case is a Aerocool Xpredator Cube Micro-ATX Gehäuse Edition-Rot/Gold (sorry about the Color but i can't change it from red/black to red/gold) Spoiler - Coming Soon - On the case, the front is redesigned and partially made new, there you will also see parts of the helmet. I am still not sure with the fan controls and the I/O, this part I would like to build new with touch sensors to turn on the computer and to control the fan. Hardware: CPU: RAM: PSU: GPU: Board: SSD: HDD: Spoiler - Coming Soon - Cooling: Radiator: Pump: Fittigns: CPU Block: Fan: Tubes: Reservoirs: Liquid: Spoiler - Coming Soon - I want to build a clean system, so i use hard tubes for the cooling and they are cleaner than the soft tubes. The eye catcher inside is the CPU BLOCK that looks like the Arc Reactor from the suit. No Arc Reactor no Iron Man. Accessories: Sleeve: Wire: Connectors: Touch Sensor: Various: Adhesive, Plexiglass, Tools, ... -UPDATES- 26/09/17: Here i will add all the updates about the blog. Cooling, Hardware or Accessories.
RULE #1 - Post some actual progress pictures of a build in the first post of a buildlog. THIS SHOULD BE DELETED ASAP. 1 H8 FKN RUL3BR34K3RS
Good evening comm... Now i can show you how i want to build the helmet. I found a program called Papakura with this program i can print the parts on normal paper and cut them out really easy but a lot of work... There are 106 parts to cut, so it will take some time, but the first 6 I already have
Good evening Comm! Now I can finally post you something again it took a long time but now all the parts are cut out and can be glued. If I had known that it is so much work then I would have bought the helmet of Amazon xD
A nice present from the guys from Gosumodz. Thank you very much!! Very high quality and really good prices check out for more info: https://www.gosumodz.com/
