Case Mod - In Progress Project: JDM As F Xbox 360 Case Mod
Discussion in 'Project Logs' started by prelich, 22 Oct 2010.
What colour should I paint the inside stripe?
  1. Red
    0 vote(s)
    0.0%
  2. Blue
    0 vote(s)
    0.0%
  3. Purple
    2 vote(s)
    50.0%
  4. Green
    1 vote(s)
    25.0%
  5. Orange
    1 vote(s)
    25.0%
  1. prelich
    prelich What's a Dremel?
    22 Oct 2010
    So this is my second case mod now, the first I will be doing a project log about. I would love any suggestions/comments along the way. I will mostly be posting bigger updates on weekends as that's when I will be working on this thing the most. Without further adieu lets start this thing
    To do list:
    • Disassemble console - done
    • Disassemble controller - done
    • Disassemble hard drive
    • Cut side window
    • Cut window in hard drive
    • Fill memory card slots in faceplate
    • Sand everything
    • Prime everything
    • Paint console and hard drive
    • Paint controller
    • Glue in plexiglass
    • Reassemble
    • Happy Times
    So this is a little sketch I made up as for the design of the case. I'm still not 100% sure about the color in the middle (right now purple) so if you have any suggestions plz post. Controller will be painted all black (murdered out)
    [​IMG][​IMG]
    How the console looks at the moment, gotta love that custom Modern Warfare faceplate
    That's right, powered by Asus......wutsup
    Controller at the moment
    Mmmmmm very delicious dirt right there
    Alright time to disassemble the controller
    Gotta take out those seven torx screws in the back
    Didn't have a security bit torx screwdriver bit I managed to get a flathead to fit in and it worked :D
    Screws out
    Taking off the back of the shell
    Some more dirt/dust that looks very tasty
    Got the bottom plate out, just pulls out
    Finally, managed to fiddle the circuit board out, not as easy as it seams
    Took out those rubber things holding in the buttons and the buttons just pop outs
    Now I gotta take out the d pad
    Gotta unscrew these two screws to get it out
    Popped it out
    Now I took out the RB LB buttons
    And pried out the sync button
    Empty shell
    Now to take out the triggers
    Careful so the spring doesn't pop out
    Wasn't so lucky with the second one
    It kinda flew out across my room, luckily I found it lying by my radiator
    All the parts laid out
    So I don't forget what to do with all that crap
    Now on to the console
    Faceplate off, just pull it
    Had to take these feet things out to reach the clips.....
    To take out the top and bottom plates
    Time to press these clips in, kinda a pain
    This magical screwdriver was the perfect size and got the job done pretty well
    Console splitting in two
    Now gotta unclip the clips in the front
    Bottom's off
    Man that things dusty
    Taking off the eject button
    Now these torx screws gotta come out
    EZ mode
    Top coming off
    Taking off the dvd drive cover thing
    Dusty heatsink
    Now to take off that metal plate on one of the insides of the case so I can cut the window
    That's where you belong
    Fan duct (I think that's what it's called) coming out
    Temporary console so I can still play, add me GT: Prelich
    So that's all for dis assembly right now. I'm going to start marking and cutting the window hole tomorrow and I will also take apart the hard drive to get ready to cut. Stay tuned for another update coming soon.
  2. Yaka
    Yaka Modder
    26 Jun 2005
    Nice, tho I'd go for somat like jade green instead of purple
  3. prelich
    22 Oct 2010
    Alright so on to part two
    I marked up the window area on the side of the case. As I do not have a dremel and do not want to buy one just for this one mod, I will be using a drill and jigsaw and a lot of sanding
    Marked where to drill the holes so the corners are round
    Test holes, got a good technique now as you can see the top hole is the cleanest
    Going to use 5 drill bits each consecutively largest so the plastic does not crack and peal off
    First hole drilled
    All done
    Now to take apart the hard drive to drill the holes for it's window
    Tops off
    Took off the side so.....
    I can file these down to make space
    Filed down those stick out thingies
    All the hard drive parts laid out
    Took off the foe metal sticker
    Marked up the window area
    All holes drilled same way as the side of the case
    one of the holes came out a little weird, hopefully when I go ahead and sand the inside it will smoothen out
    Hopefully I will start cutting the window tmrw so stay tuned
  4. Pot Of Jam
    Pot Of Jam What's a Dremel?
    6 Sep 2010
    Good work so far, quite intrested in the finished result!
  5. Skorchio
    Skorchio What's a Dremel?
    16 Oct 2009
    Looks like a good start mate :)
  6. shadow19935
    shadow19935 Whats overclocking? :D
    17 May 2010
    looking nice, but please drench that controller parts in fairy for a day or two :p
  7. spigs_rex
    spigs_rex What's a Dremel?
    1 Oct 2010
    ah wow im looking forward to watching this mod develope! keep it up :thumb:
  8. prelich
    22 Oct 2010
    Alright part 3 now. I spent the last week filing and sanding and have finally finished
    Here's the garage where all the cutting went down
    Got the console clamped down
    Tool of destruction
    Really, really rough cut. Blade strayed off because it jumped off the guide
    Same with the hard drive
    Time to start sanding. Attacking it with the 80 grit.
    Making some progress
    More progress
    Got to grind of these tabs so I can glue the plexiglass somewhere
    Tool of destruction (Probably overkill but whatever)
    Sanded down nice and clean
    Man that took alot of blood, sweat, tears and time (Pic might make it seem curvy but I assure you it is straight)
    Nice and smooth (Pic might make it seem curvy but I assure you it is straight)
    Now I'm going to move on to the faceplate
    Going to fill in the memory card slots
    Dont know why this pic is sideways, crazy gluing the tabs down
    Removing the connect button
    Just cut the lil tabs down
    Victory
    Also sliced down the tabs on the IR receiving thingy to get it out
    Victory again
    That's it for now. I'm going to home depot in about an hour to get some paint and filler and all those goodies. Please check back often for more updates
