Scratch Build – Complete ⭐ Project JDM | ITX scratch build!
Discussion in 'Project Logs' started by Jokot, 7 Sep 2017.
  1. Jokot
    Jokot Minimodder
    6 Sep 2017
    Project JDM
    So its finally time to start on a new build log this time of a project i call "JDM". The core inspiration of the project was Japanese styled drift cars hens the radiator with outwards mounted ports to illustrate a oil cooler. And the other ̶b̶i̶g̶ small thing that is that i wanted it to be in mini-ITX format. So after a few weeks of thinking i decided to go with a tube frame to keep it true to the theme. Here are some of the renders i made after some designing in Fusion 360. Also big thanks to Alphacool, Bequiet and Teamgroupe for helping out with the hardware.
    MLyons likes this.
  2. Jokot
    Jokot Minimodder
    6 Sep 2017
    First update to start things off.
    One of the first obstacles i encountered was the corner pieces. I had a few options but after some thinking i decided to make some custom 3D-printed parts for the job.
    These are the 2 versions I made but I ended up going for the simpler design.
    First print turned out great!
    Removing the support material
  3. Jokot
    Jokot Minimodder
    6 Sep 2017
    Starting on the metalwork.
    I will be using some 16/14mm metal pipes for the frame.
    Test fitting.
    Dot_Kappa likes this.
  4. Jokot
    Jokot Minimodder
    6 Sep 2017
    More metal work.
    Making the support for the front radiator.
    I made a bracket from wood to make the welding a bit easier.
    Ready to start welding.
    This is what it looked like with no clean up and still 2 pieces left to go.
    Now lets clean it up a bit.
  5. Jokot
    Jokot Minimodder
    6 Sep 2017
    More work on the front.
    I applied a light coat of primer to make it easier to see imperfections.
    Still need to glue the bottom piece together.
    kim, Guest-23315 and MLyons like this.
  6. Jokot
    Jokot Minimodder
    6 Sep 2017
    More 3D printing and plastic parts
    I made a small bracket for the start button which in this case will be a real key.
    Next upp is the part that connects the plexi tubes to the frame. You might ask why i didn't just go with metal tubes and the reason for that is LED's [​IMG] but more on that later.
    I still had to make some kind of motherboard mount so thats what i did.
    And with motherboard in place.
    There is also some other stuff i am working on like gpu braket, a good way to mount the rear fans and a psu mount. But yeah its mostly small stuff left on the frame.
  7. Jokot
    Jokot Minimodder
    6 Sep 2017
    Its getting there!
    So time for an update, currently just have some sleeving and finale Assembly left so should be coming together soonish.
    I wanted some lighting effects but still didn't want any thing to flashy so i decided to integrating the leds there into the plexi tubes under neat the motherboard which i think turned out really nicely.
    I also made made the supports for rear 80mm fan, psu and some case feet.
    Some test fitting before painting.
    Ready for some paint.
    Some days later i masked of the painted parts and made the rest glossy white.
    And ofc some pictures after it was all painted [​IMG]
  8. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    This is looking amazing! I can't wait to see more. Well done.
  9. Jokot
    Jokot Minimodder
    6 Sep 2017
  10. Jokot
    Jokot Minimodder
    6 Sep 2017
    Final assembly
    This will be the last update before final pictures so enjoy [​IMG]
    First time bending plexi, turned out better then i would have thought.
    After a lot of debating i decided to go with stock cables because sleeving them would have made them to thick and the all black cables fit the aesthetic really well anyways.
    Sleeved tubes <3
    Modded eisbaer ready to be installed.
    MLyons likes this.
  11. Cheapskate
    13 May 2007
    Looks good. :D The tubing screams for stainless steel braid because of the theme. -Makes me think of all the SS braided plumbing I've tossed over the years. I could have salvaged it. :(
  12. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    coming along nicely!
    Arboreal likes this.
  13. Jokot
    Jokot Minimodder
    6 Sep 2017
    Late answer as always :grin: honor to see some of the best moders of all time like my build :happy:
  14. Jokot
    Jokot Minimodder
    6 Sep 2017
    Final pictures [​IMG]
    Big thanks to Alphacool, Teamgroup and Be quiet for helping out with hardware!
    Imgur album of all the pictures can be found HERE
    Make sure to follow me to get notified about future projects!
    Instagram- jokot.tech
    facebook- JokotTech
    Cheapskate and (deleted member) like this.
  15. Dietec
    Dietec Minimodder
    2 Oct 2017
    Those LEDs look awesome! The perfect amount of flashy
  16. Jokot
    Jokot Minimodder
    6 Sep 2017
    Thanks, yeah you actually don't need to much RGB too look cool ;)
  17. mnpctech
    21 Apr 2003
    Awesome job! the color scheme turned out perfect, too!
  18. Jokot
    Jokot Minimodder
    6 Sep 2017
    Thank you :)
  19. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Does it make sense to bump up thread one year old just to say "wow" or "awesome"?
    You can give a like, it works better :lol:
    kim likes this.
  20. Cheapskate
    13 May 2007
    @Dot_Kappa - I'm guessing SA mod guy just bumped? :lol: His post count has been reset for at least the 3rd time. All his one-word posts were nuked.
    Still, I missed the final pics on this. It came out great. :D
    kim and MLyons like this.
