Project jupitor
Discussion in 'Project Logs' started by modmaster, 27 Apr 2003.
  1. Fly
    Fly inter arma silent leges
    31 Aug 2001
    Oh, so people do buy those things???
    Well, will be nice to see the end result.
  2. modmaster
    modmaster New Member
    10 Apr 2003
    for some reason the pics arnt showing can someone help me??
  3. the_secret
    the_secret New Member
    29 Sep 2002
    -> rename them to .txt (or get a better host)
    -> geocities does not allow pictures to be viewed from outside sources.
  4. modmaster
    10 Apr 2003
    i am trying to think of what to do about that little rectangular bit that comes off the front of the case i cant think of anything to do to make it look better. it is just an ulg bit of plastic the power and reset buttons are getting replaced with vandal switches but then i am stuck with the plastic thing.
    If you have any ideas i would like to know :D
  5. Altron
    Altron Well-Known Member
    12 Dec 2002
    Amputate it :dremel:
    Making a new bezel is easy, I made mine out of cardboard :thumb:
  6. bilnv
    bilnv New Member
    20 Apr 2003
    A case that size has water-cooling written all over it.
    I use geocities to post my pics but I have an upgraded version. Is't like $5.00 a month and I never had a problem with them showing up anywhere, Plus I can use FTP to upload the files.
  7. Shadowspawn
    Shadowspawn Another hated American.
    1 Jul 2002
    About that power button, I wouldn't disregard it so quickly.
    I see it painted (dyed) black, with the dimples cut out. Fill the resulting holes with clear, or dark tinted plastic with a blue LED behind it.
  8. Dad
    Dad You talkin to me?
    15 Apr 2003
    Instead put a red one behind it to make it look similar to a molten asteroid to match the "Jupiter" (yea, I know it's Jupitor) name... :naughty:
  9. |Jedi|
    |Jedi| New Member
    29 Oct 2002
    i like the window shape... but personally i'll do something with a similar shape of the little holes thinghies.
  10. modmaster
    10 Apr 2003
    haha i like the ideas, the button one i will be looking into and yer i will be using a red led. :p
    aaaahh i have something up my sleave for the holes in my case. there is 224 holes in the side so i am putting 224 LED'S of different colours behind them then rigging it up to a circuite that make randome patterns with the leds, i may even add a few diffrent modes in so that you can have it chacing insted, or even make my logo.:D :D
    i just know that the pcb will be hard to figure out:miffed:
    anyway keep the ideas comming
  11. modmaster
    10 Apr 2003
    ha ha
    i got paid 2day, so i have ordered all my modding parts of maplin, it has most of the parts for the modds i am doing on the case. it has alresdy being dispatched and is on its way by omega standard delivery so it should be here on tuesday (cause of the bank holiday :sigh: ) any ways i will be doing more posts soon with pics.:hehe:
    intil then happy modding:dremel:
  12. Fatboy
    Fatboy Bored
    8 Oct 2001
    Happy soldering !!! :clap: :clap:
  13. modmaster
    10 Apr 2003
    i have finished my case window now!!
    here is the pic
    tell me what you think
  14. Altron
    12 Dec 2002
    Like the design, not the generic rectangle :thumb:
  15. Atomic
    Atomic Gerwaff
    6 May 2002
    Nice, now paint the case!!!!!
  16. acrimonious
    acrimonious Custom User Title:
    8 Nov 2002
    Yeah nice new case window, make sure you get some blowholes in somewhere!
  17. modmaster
    10 Apr 2003
    yer i am picking up the paint tomorrow on my way home from college. i dont know if to go for the halfords black vinal spray or just a plasti-cote black. what do you think?:dremel:
  18. BoCoMoFo
    BoCoMoFo New Member
    30 Sep 2002
    Nice work, dude. I like the border trim, too. :thumb:
  19. Atomic
    Atomic Gerwaff
    6 May 2002
    Never tried the halfords but the plasti-cote stuff is good, i used it to dye my old mouse & Keyboard black and it worked well.
  20. modmaster
    10 Apr 2003
    hiya i am gona do another update.:D
    i have being doing quight a few litle things on my case.
    • external power
    • replacing the reset button with a push to make switch
    • started to spray the case with plasti-cote sating black paint
    • drilled holes in the power button and mounted two red LED'S behid it
    • and i have also made a fan bus
    i will be posting the case pics as soon as all the painting is done and i have put my lacqure on. i will also put up the power button shots and the reset button shots.:hehe:
    anyway here is some pics of the external power mod and the pic of the fans that i am using.
    for the fan bus i used 3 80m clear acrylic fans with rainbow coloured leds inside. and 1 plain and simple 80m black fan.(cause it was getting mounted oin the front of the case where you cant see.
    anyways tell me what you think of these small mods and i am going to get some pics of the others sorted soon.
    i still have things to do:
    • a blowhole on the top of the case for an acrylic fan
    • wireing up the 224 leds in the side pannel
    • making the PCB for the pattern controle on the LED'S
    • Purchacing the computer to go inside the case when it is done
    • Adding in my IR Receiver to remote controle my pc
    • wrapping up all the loose cables
    • stealthing my dvd-cd rw drive
    • relocating the cd drives open/close button and disk activity light
    • thinks of more ideas to do to the case
    till then happy modding:dremel:
