Project -KirKas- Plexi case (Case working and phase one completed!).
Discussion in 'Project Logs' started by marcoboy, 6 Mar 2005.
  1. marcoboy
    marcoboy What's a Dremel?
    5 Mar 2005
    I got it from http://www.verkkokauppa.com from Finland. And it's called ProDige Mercury.
  2. marcoboy
    5 Mar 2005
    OK! I will be buying new BIOS for my mobo next week and then I wil get to test if it works or not........ exciting times we live :worried:
    ps. I will never ever buy any of those one BIOS mobos EVER! Have to have mobo with some kind of bios backup function.
  3. antoniohawk
    antoniohawk What's a Dremel?
    21 Oct 2004
    Thanks for the info marco. I really want that case, but the cost would be outrageous with shipping and everything. That is if they would even ship to the U.S.
  4. ehrnam45
    ehrnam45 What's a Dremel?
    5 Jul 2004
    wow, there's no way I would try and desolder the caps from a mobo of my own! :p Looks like there's some great things happening here. One note about the PCI-E/AGP slot: don't forget that AGP has a tab at the inside end of the edge connector for the lock mechanism, and will require about 1.5-2 cm additional length in the cover slot to let the card fit in.
  5. marcoboy
    5 Mar 2005
    Yes, thats good point on AGP-slot :) I have not made the AGP-slot hole yet because........... I destroyed the diamond blade of my "dremel" :( :( :( Will have to buy new blade before easter, ie tomorrow!
  6. acidfire
    acidfire What's a Dremel?
    11 May 2004
    Awesome looking case design and progress. I love the white lite with the mesh cover. One quick question, where did you get you fiber optics cable?
  7. marcoboy
    5 Mar 2005
    That optic fiber is from regular 5m Toslink-cable (between Hifi amplifier and CD-player etc...) about 10€ www.bebek.fi here in Finland. I just stripped the outer plastic "shield" so that the fiber will be thinner... And cut it to 10 half meter pieces :)
  8. marcoboy
    5 Mar 2005
    Hi all!
    I've been waiting to get some money to buy that plexi that I need to properly start my REAL moddig...
    But while we're waiting..... here's new render on my plans:
    I decided to move PSU to case bottom so that it might be easier to mount in to plexi.
  9. Rh1n0x
    Rh1n0x What's a Dremel?
    15 Nov 2004
    Wise decision to mount your psu underneath.. as mine is above the motherboard and makes to plexi-panels kinda 'bent'. Still have to solve it with some extra screw/holding mechanism. Still waiting on a beter psu to do it for.
    Nice mod! subscribed :cooldude:
  10. marcoboy
    5 Mar 2005
    Finally project moving forward !!!
    Hi all!
    Finally I have 2 weeks summer break from work :) And some money to buy all those planned parts :clap:
    5mm thick plexiglass (9 sheets). price 95€
    Two Aerocool aluminium fans. price 8€ for one
    Aerocool centaurus strange looking ledfan 11€
    Revoltec ram freezer Platinum edition 11€
    Arctic cooling copper silent 2L CPU cooler 28€
    And now..... I'll start the actual building :) Stay tuned!!
    ps. I also bought 200GB Seagate HD (114€), Athlon XP 3000 400FBS processor (129€) & Nexus 450W powersupply (80€).
  11. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Excellent job with the motherboard lighting!
  12. drinn
    drinn What's a Dremel?
    16 Jul 2004
    Like your mod in the motherboard :)
    Great job! :thumb:
  13. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Instead of using ugly angle brackets you could get some cast acrylic cubes and drill/tap them for the same purpose.
  14. marcoboy
    5 Mar 2005
    I have not posted this picture before, because I wanted this to come up later, but...
    This is the paint I'm going to use inside my plexicase ;) (actually clear metallic color and white color over that) so SURPRISE: It's not going to be all transparent. Only a transparent "window" on one side.
    I'm after somekind of "mac white" feel...
    So, it doesn't matter if I use angle brackets ;)
  15. marcoboy
    5 Mar 2005
    Testfit of plexipanels
    Here's what I did last night:
    Testfit of plexipanels.
    Now I need to measure and testfit the right positions for "false bottom" and HD / CD-ROM "bay?".
  16. marcoboy
    5 Mar 2005
    Got few bags of screws and nuts...
    I hotglued these cornerpeaces and nuts together...
    ...to these beauties.
    (Just to be able to attach the last panel to the case).
    And here: PSU on place (notice that I changed my plans from renders to place the PSU UNDER the midsole)
  17. aevitas
    aevitas What's a Dremel?
    6 Mar 2005
    Looking good dude.. I might have to borrow the mobo idea if you don't mind hehe..
    One question.. is that plexi blue transparant or is it just the cover on it?
    Keep on modding dude.. I can't wait to see how this turns out :rock:
  18. marcoboy
    5 Mar 2005
    That's completely clear plexi, with blue covers on it.
    ps. I just drilled two holes IN WRONG PLACES !!!! :waah:
  19. marcoboy
    5 Mar 2005
    CD-ROM Drive fitting and HD fitting.
    I aquired some metal rails to fit 3.5in HD:s to 5.25in driveplace.
    Installed the backpanel of massmedia compartment. Panel has one fan too...
    And SORRY about the quality of these new pictures!! (including past few days) My digital camera broke down and I have to use my mobile... :waah:
  20. Anthony
    Anthony What's a Dremel?
    6 Jan 2005
    Looking good, again one expert finnish modder on the move :D
