Project -KirKas- Plexi case (Case working and phase one completed!).
Discussion in 'Project Logs' started by marcoboy, 6 Mar 2005.
  1. marcoboy
    marcoboy What's a Dremel?
    5 Mar 2005
    Finally I got the mobo to the picture ;)
    Mounting the mobo in place... I did have really huge problems getting the screwholes on right places, but managed it somehow.
    Next adveture: attaching out take fan to case...
  2. LunatiC
    LunatiC What's a Dremel?
    4 Sep 2004
    damn man, that looks awsome! the stealth plate for the mobo looks saweet! :rock:
  3. marcoboy
    5 Mar 2005
    Outtake fan installed and light's connected!
    This pic absolutely and most definitely doesn't make right for those lights.
  4. Phaeton
    Phaeton What's a Dremel?
    8 Mar 2005
    I really love the looks of the stealthed mobo in combination with the lighting, absolutely awesome! I'm impressed by the look of the case with the fastening method you used; I didn't think it would look that good unless it was glued. Good luck.
  5. marcoboy
    5 Mar 2005
    Thanx, I too love the lights :)
    Important thing at this point (when the case is incomplete) is that I can assembe and disassemble the case numerous times. That's mainly why I desided to use screws (or those aren't actually screws, more like bolts). And those metal bolts look great when I paint my case in white! I hope...
  6. marcoboy
    5 Mar 2005
    Windowside paint
    Here's the sideplate with window (window's actially vertical, not horizontal like in this picture, and made with racing car window film on backside of plexisheet)
    And here's closeup of the paint/chrome window... you SHOULD see the metallic glitter and white paint, both painted BACKSIDE of plexisheet...
    Windowside at dark, light inside on.
    Windowside at light, light inside on.
  7. Dezjay
    Dezjay What's a Dremel?
    10 May 2004
    How did you isolate the back of the mobo stealthplate ??
  8. marcoboy
    5 Mar 2005
    Isolated?!? Whos he ? ;) only kidding...
    Actually I have NOT isolated it. I have examined every single place on mobo and I can not find any place that stealthplate would come even "close" to anything conductive. There's actually few places where the plate touches mobo components, but all of those components are made of plastic.
    I could be wrong, and that's why I'm lucky to live very near to a computer shop :dremel:
  9. Dezjay
    10 May 2004
    Lol same reson i work in a compushop :)
  10. advance
    advance What's a Dremel?
    18 Apr 2005
    That mobo cover is friggen sweet. Props for the case all together, nice job!
  11. marcoboy
    5 Mar 2005
    Powering mobo for the first time !!!
    OMG !!!!!!!!
    It DID power up... the mobo that is....
    I was so certain that it would fail to boot, after that capasitor moving and stuff...
    Next stage: connecting HD and CDROM and those front panel optics....
  12. kickarse
    kickarse What's a Dremel?
    6 Oct 2004
    looking just like planned!
  13. xcxz
    xcxz What's a Dremel?
    19 May 2005
    Holy **** dude f*cking awesome mobo stealth
    ps. im jelous
  14. korhojoa
    korhojoa durr
    31 Oct 2003
    Stanan MAHTAVAA! TODELLA HIENO!
  15. marcoboy
    5 Mar 2005
    Thanks all :) I feel very good about this project :)
    Now:
    I placed tiny leftover rubberpeaces between plexi and HD brackets to prevent noise from travelling thru care...
    And optics, still working :) I placed optics circuit board in the HD department below all disks...
    AND you may have noticed that I switched my PSU.... to newer Nexus...
  16. marcoboy
    5 Mar 2005
    Optics on frontpanel
    Optics placed on frontpanel. I drilled 1mm holes halfway of plexi and just sticked optic fibers to holes.... in final installation I plan to use hot glue.
  17. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    those front panel lights look really nice, you'll have a big job hiding their wiring though...
  18. marcoboy
    5 Mar 2005
    About wiring: Not problem after I've painted the frontpanel ;) The whole case is going to be painted metallic white from inside. I wish I had proper camera to take quality pics from sidepanel I've made, you would see the "mac like" white finish...
    PS. I don't like the way pictures show those lights.. those are under 1mm in diameter !!! so quite beautifull in real life :)
  19. marcoboy
    5 Mar 2005
    I broke my dremel's diamond disk, so I have no means of cutting prosessor & AGP holes in mobo stealth, that's why stealth has been removed from case at this point :wallbash:
    Case partly assembled again... Powered.
    Closer pic of mobo. Red lights are from bios diasnostics & wake-up power etc.
  20. Da Dego
    Da Dego Brett Thomas
    17 Aug 2004
    I really like that back fan... And where did you get the Fiberops?
