Project -KirKas- Plexi case (Case working and phase one completed!).
Discussion in 'Project Logs' started by marcoboy, 6 Mar 2005.
  1. marcoboy
    marcoboy What's a Dremel?
    5 Mar 2005
    Case temps
    My cases temps seems to be a bit too high. :wallbash: I have those fans connected to 5v line. Maby I have to connect to 12v with some kind of trimmers....
    Will have to search thru bit-tech for ideas.
  2. BBurger
    BBurger What's a Dremel?
    7 Apr 2005
    Maybe build one of CPEmma's DioBuses for fan control?
    I'm thinking of one for my case, wired into a four-port fanbus to control all the case fans at once. Run them at full 12V under load, and turn it down when I'm just doing desktop stuff.
  3. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    plug them to 7 volt
  4. marcoboy
    5 Mar 2005
    Thanx for that http://www.cpemma.co.uk/ link !! there's so many great ideas for my fan adjusting needs, and diagrams to use 7v connection too.. I will use 7v-way as temp solution. I will use trimmers some day...
  5. LightStar
    LightStar What's a Dremel?
    21 Sep 2004
    Hmm very nice project i like your stealed mobo :p go on with the good work
  6. TTmodder
    TTmodder Hammertime
    9 Apr 2005
    use the 5volt+ as minus and 12volt+ as plus 12-5=7
  7. dubya01
    dubya01 What's a Dremel?
    22 May 2004
    Or maybe run fans in series. 2 12v fans will be 6v each/
  8. arkadur
    arkadur What's a Dremel?
    3 May 2005
    what about bay bus?
    or
    quite fans at 12V?
  9. marcoboy
    5 Mar 2005
    Yes I'm going to build bay bus in future.
    My fans are quite quiet, at least I think so, compared to my old comp.... manufacturer promised 19-21dB. Allthough those are not quietest possible fans :(
    Now I'm going to use 7v! :)
    Thanks all for great suggestions !
  10. marcoboy
    5 Mar 2005
    Going to continue project.
    Now, my second summer holiday is going to start this friday! So i'm back with my project :) I bought new LG DVD DL -drive and are going to install thet next.
    I allso have to get parts for fan controllers!
    (I have been working on my HTPC -project, but I dont have any pics of that) :(
  11. marcoboy
    5 Mar 2005
    Hi all!
    Today I got back to this project :)
    Here's what I have done today:
    - Cut remaining holes to Motherboard stealth
    - Soldered Eject-switch and LED -wires to DVD-drive
    Motherboard stealth at place
    Motherboard powered
    I was thinking that maby I should paint the VGA cooler with spraypaint. It's getting quite hot, so what kind of paint would I need for that?
  12. FragK
    FragK What's a Dremel?
    18 Jul 2005
    i would put another cooler on it, as you say its kinda hot in your case. My advice is the vf700 cu from zalman, i have it myself too, and it cools like hell. Maybe for the overall case temp: more fans on lower voltage, also cuts down in the noise.
    the white is great, far more stylish than the transparant plexi (which alot of premods have).
  13. mediacoretex
    mediacoretex What's a Dremel?
    28 Feb 2005
    nice job on the stelth
  14. Dries
    Dries What's a Dremel?
    24 Jun 2004
    Much compliments for the mobo stealth ;).
    I really like the idea of hiding all the unfancy looking components of a motherboard. It looks really clean!
    Especially the ugly 'rotten orange' colored Asus boards are worth stealthing.
  15. marcoboy
    5 Mar 2005
    Thanks :) I have 3 casefans at the moment (and I really don't want to add more fans) using 5v and I am going to try 7v for those. I'll see if that lowers the temps enough. :) I've been experimenting with 7v and fan noise stays tolerable in my opinion.
  16. marcoboy
    5 Mar 2005
    Thanks and you are so right about the ugly components! BUT I had so many problems fitting that stealth on place... I just screamed and pulled my hair... nightmare! Don't reccomend to anyone with weak nerves :wallbash:
  17. KJSatz
    KJSatz What's a Dremel?
    14 Jul 2005
    I like it.
  18. slaw
    slaw At Argos buying "gold"
    13 Feb 2003
    WOW simply amazing
    some great original ideas!!
  19. Cardan
    Cardan What's a Dremel?
    21 Jun 2005
    WOW that is awesome!
    if u dont mind im gonna use that idea for the mobo stealthing on project Classifed :-D
  20. Samurai75007
    Samurai75007 What's a Dremel?
    27 Oct 2004
    Good GOD that thing is sweet!!!!
