Case Mod - In Progress Project KURO: CM 690III by Jesse Palacio
Discussion in 'Project Logs' started by JessePalacio, 29 Jan 2014.
  1. JessePalacio
    JessePalacio New Member
    7 Nov 2013
    hey folks. since i missed the opportunity to share my work log here on my previous build CENTURION, i thought i'd share here my work logs for my next project: KURO. Kuro is japanese for BLACK. this build will feature a dark color theme. yes, i know the color scheme is pretty generic, but that's the challenge.. making it look different. although i do not have an idea on what parts i'll be putting inside this case mod (and how to get them), i will focus first on the case itself. "every journey begins with a single step.."
    i hope you will join me. =)
    sponsored by:
    what i will be working with so far..
    awesome that they include a CPU cooler in the packaging. =)
    first order of business, remove the HDD cages. i like how these werent riveted on. just a few screws, and they are off.
    one thing i also noticed is, the revision has rubber grommets for the cable pass through now. Thank you CM for listening.
    that's it for now. cheers!!
  2. JessePalacio
    7 Nov 2013
    UPDATE:
    still waiting on some new tools to work with, so for now..
    i dont have pics of the painting and priming process.. my hands were dirty. but after 2 hours:
    so far so good. =)
    did the same for the top chrome lining too. =)
  3. JessePalacio
    7 Nov 2013
    tiny update. took a quick break from customer builds to do some work on KURO
    i know it's not alot, but i needed some cash to help me fund this project. i'll be back to focusing on this build very very soon.
    Update:
    i had a PSU cover lying around, so i modded it a bit.. and placed the KURO name. paint is still wet.. too excited to see how it would look.
  4. JessePalacio
    7 Nov 2013
    some goodies came in today. thank you Icemodz.com and Mundi V.
  5. JessePalacio
    7 Nov 2013
    ive been out a few weeks trying to make little cash to fund this project.. then comes kid's school bill, so i threw the goal of getting a new motherboard out the window..
    anyhow, i decided to just build KURO.. so i would get a better idea on what i could do with it, and have little to no issue about compatibility, or mis-fitting things.
    this is how it is now. will work from here.
    didnt like the thickness of my orginal PSU cover, so i decided to make another one.
    perfect fit. =) painting tomorrow. =)
  6. JessePalacio
    7 Nov 2013
    for today..
  7. JessePalacio
    7 Nov 2013
    glamour shots of it's early stages.
  8. JessePalacio
    7 Nov 2013
    Made a CPU block cover and side 5.25 bay cover. didnt have my camera when i made them. but here they are, installed.
    thank you for following. =)
  9. Hukkel
    Hukkel James' minion
    20 Dec 2012
    It looks very nice and clean.
    Too bad about the original psu cover. I really liked it.
  10. JessePalacio
    7 Nov 2013
    bent some acrylic for the HDD bay cover. this is the reason why, before painting.. it is imperative that you wash the surface first.. preferably dish washing soap. i got too lazy, so now the work has been doubled. get it right the first time, is always the shortest way to go.
    sanded down..
    mounted. =)
    Thank you!!
  11. JessePalacio
    7 Nov 2013
    sundays usually give me the most free time to work on Kuro. changing lighting scheme a bit. =)
    then the camera dies after taking a few pics of the result. this one is the best i had. i will update later. =)
    thank you!!
  12. JessePalacio
    7 Nov 2013
    update:
    Face of KURO
  13. JessePalacio
    7 Nov 2013
    so today, i had a little free time.
    testing the bend.
    cut out the Kuro logo.
    testing the placement
    bent some acrylic for the final.. (promise) power supply shroud. then installed white LEDs into the case
    DRUM ROLL....
    opps. wrong PC. :wacko:
    DRUM ROLLLLLLLLL AGAIINNNNN..
  14. Shurika
    Shurika Member
    9 Mar 2012
    Like the front panel very much - realy cool!
  15. thenotincluded
    thenotincluded New Member
    17 Jul 2012
    The logo is a really good touch. Loving the look of this build
  16. JessePalacio
    7 Nov 2013
    thank you. i was starting to feel discouraged about posting here, because i didnt get any replies at all. lol. yeah, i know, it's not an awesome scratch build or a beasty watercooled set up, but im really having fun building it. thanks again. =)
  17. Shurika
    Shurika Member
    9 Mar 2012
    No, you just don't know the bit-tech comunity. We talk if we realy have something to talk about. You build is clear and nice, so we can just watch until the final and applause to finished build. So, common! Do it the best!
  18. JessePalacio
    7 Nov 2013
    front panel re-tuned. often, it's the little stuff that counts.
  19. Meelobee
    Meelobee New Member
    5 Nov 2003
    So much awesome here!
    The front and gpu cover look great, but I prefer the old psu cover, it goes better with the rest :)
    No actually, dish soap tends to leave a thin layer of residue, it's better to use benzene or thinner instead. (On metal parts, not on plexi/plastics)
  20. JessePalacio
    7 Nov 2013
    it was acrylic i was painting on. thinner or benzene would be overkill for it. hehe. but on metals, thinner all the way. the squeeky sound of properly dried soapwashed plastic has worked wonders for me over the years. ive been painting since highschool. =)
    as far as the PSU cover, yes. the older one i made was the best i liked too. but the acrylic on that was too thin. didnt feel solid, like the 3/16 ones im used to using. thank you man. =) i just noticed we are now friends on facebook! cheers!
