Scratch Build – Complete Project: L3p D3sk - Bit-Tech Mod Of The Year 2011 Winner.
Discussion in 'Project Logs' started by l3p, 1 Nov 2010.
  1. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Congrats on the new parts. All that nickel plating truly IS Bling-Bling-Bling-Bling-Bli.....
    But I'm a bit confused. I thought the hardware WAS already in there as it should be? What are you replacing with this new stuff from ASUS?
  2. HobbieZones.com
    HobbieZones.com What's a Dremel?
    13 Feb 2011
    Desk Top PC !
  3. l3p
    l3p www.^.nl
    1 Nov 2010
    Well i had an Asus P6T6 WS, but it was already dieing slowly.
    And i thought buying 2 x gtx580 was better then buying an extra Asus 5970 to run with 2 cards.
  4. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    Truly outstanding level of build and attention to detail - its this kind of work which keeps me coming back to view bit-tech's projects page.
    I say this log before xmas but i was at work so didnt get chance to sit browsing the photos so glad i've taken the time this evening
  5. l3p
    l3p www.^.nl
    1 Nov 2010
  6. Jor1995dan
    Jor1995dan Minimodder
    6 Feb 2011
    I've been following this build log for a while now and your craftsmanship and attention to detail is amazing! Keep it up!
  7. SPNKR
    SPNKR Pretty Good Kid
    22 Feb 2010
    Thats some sick hardware you got, very good choices.
    Also, good video, more people need to listen to the prodigy. :rock:
  8. l3p
    l3p www.^.nl
    1 Nov 2010
    Here some pictures of the conversion.
    First of all, thanks again Highflow, EKWB en Asus !
    Even on air they are lovely.
    But i love WC blocks :p
    You can easily spend a hole evening on 2 cards.
    And thats 1
    And thats 2 :)
    Had a small break, had to wait for a replacement part for the EK rex3 block (broke while shipping)
    And i've been to Cebit to personally thank one of my sponsors :)
    Replacement part came in the next morning :)
    Quite an impressive block, it has 4 O-rings in it
    And now the adjustments for the bigger mainboard and the extra needed cables for the gpu's
    Had to do everything by hand cause i didnt want to clear the hole desk
    Also the mainboard tray needed some work.
    Discs specially aluminum.
    And done.
    Now i can start fitting in the Bitspower parts
    Every SLI connector has to fit exactly.
    One of the many times fitting it in the desk.
    Only one connector to go.
    Got the tip to polish the silvercoil :)
    Hmm..
    But it's shiny again :)
    Cable for the extra molex on the Rex3.
    After one hour i finally found a way to get all the cables under the mainboardtray
    And some teasers for later this week :)
    When looking for the newest bios for the rex3, i also found a driver for symbian phones.
    I had no idea this was so easy :)
  9. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    WOW... i'm speechless :jawdrop: :jawdrop:
  10. jhanlon303
    7 Sep 2006
    ^^ What he said
  11. l3p
    l3p www.^.nl
    1 Nov 2010
    I heard today i should have used slot 1 and 3 for pci-e 16x
    So need to change it :)
  12. suenstar
    suenstar Collector of Things
    13 Sep 2009
    This build continues to look more and more amazing every time I take a look.
    Awesome that you had a chance to see one of your sponsors in person at CeBit, do you know if they were following your build development at all?
  13. ThirtyQuidKid
    ThirtyQuidKid Minimodder
    11 Jun 2010
    Now that is one sweet lookig desk.....
  14. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks alot !
    I was wondering that myself too, but dearest Vincent has a very busy life with Bitspower :)
    He did see the pics a few times, but forgot about it a few months ago :)
    Off course he's totally updated now again :)
  15. KidMod-Southpaw
    28 Sep 2010
    Awesome green, too bad the board doesn't match.
  16. l3p
    l3p www.^.nl
    1 Nov 2010
    It's almost impossible to see the red slots when the leds are on, and 90% of the time they are on :)
  17. l3p
    l3p www.^.nl
    1 Nov 2010
    Cleared some 230V cables for the tft's today.
    Made a 3-way disconnect-able cable ^^
    3 AMP connectors.
    And done
    Still need to fix the resolutions so the conversion looks better
    I almost enjoy the view like in real life :p
    Guest-56605 likes this.
  18. Guest-56605
    Guest-56605 Guest
    I've said it before now I know but that is just pure and utter class :D :thumb:
  19. Nutman
    21 Oct 2008
    Yup, yup - all that's left is do put some ambient lighting behind those screens. :thumb:
  20. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    This is just amazing man!
