Scratch Build – Complete Project: L3p D3sk - Bit-Tech Mod Of The Year 2011 Winner.
Discussion in 'Project Logs' started by l3p, 1 Nov 2010.
  1. Anubus
    Anubus Minimodder
    7 Jul 2008
    Is that a gigabit Ethernet card? :p
  2. bagman
    bagman Minimodder
    18 Apr 2009
    that tea coaster mod is pure modding arrogance
  3. Djayness
    Djayness phwupupupup
    7 May 2008
    I think you need to look up the word "arrogance", it certainly doesn't apply to making cup holders...
    Excellent work and excellent table mate, keep it up.
  4. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks man :p
    Hmm is that positive or negative ? :cooldude:
  5. bagman
    bagman Minimodder
    18 Apr 2009
    I mean it in a good way. I don't just mod pc's, I mod cup holders.:hip:
    you are just too good
  6. l3p
    l3p www.^.nl
    1 Nov 2010
    Ahh ok, well thanks :D
    But there are alot of others here 10 times better then me :)
  7. l3p
    l3p www.^.nl
    1 Nov 2010
    Still had to change some things under my floor.
    Today i found some time.
    Had to replace some fans on my rad for Scythe GT's
    Replaced the green tube for Tygon black.
    Also replaced the 3 remaining GT's in my desk for green Nanoxia's
    GT's out
    Only 5cm space for my hand.
    Nanoxia's in.
    Here my radiator in the distance.
    On request also made a little movie of my trip :)
    Mobile doesn't work here, but baby phone works fine :D
    De GT's on their place and tubes replaced !
    And another small test.
    Wanted to know what stuff goes trough my loop.
    This way it was easy to discover.
    Click it between my tubes and enable the pumps for one hour.
    Then disconnect the filter while pumping and stop the pumps as fast as you can.
    This is so the dirt really stays in the filter.
    All tiny hairs and wtf, even a piece of my sigarettes :p
    Till next time :p
  8. KidMod-Southpaw
    28 Sep 2010
    Underground rad?
    A-w-e-some.
  9. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Yeah, what the hell is going on under that floor?
    Looked like a scene from Dead Space 2 or something - pure awesomeness!
    So, you'd need a sand filter, or maybe even a bug filter (spiders, anyone?) on that rad, hah!
  10. l3p
    l3p www.^.nl
    1 Nov 2010
    Sand filter isnt needed, it doesnt get blown in.
    By the way, its also a spider shredder ;)
  11. Nutman
    21 Oct 2008
    So, when the loop suddenly starts to heat up rapidly, you know you got a tarantula stuck in the rad!
  12. Telltale Boy
    Telltale Boy Designated CPC Jetwhore
    3 May 2010
    :eek: Very nice!
    Me wants temps now!
  13. l3p
    l3p www.^.nl
    1 Nov 2010
    Haha, who will win.
    Tarantula Vs. Gentle Typhoon @ 1850 rpm :)
  14. voigts
    voigts What's a Dremel?
    26 Apr 2006
    Having the rad under the floor will sure cut out on the fan noise, but its gonna be one pain in the neck whenever you need to go clean out the radiator.
  15. l3p
    l3p www.^.nl
    1 Nov 2010
    Thats true, but i think i need to clean it once every 18 months :)
  16. sixfootsideburns
    sixfootsideburns modeteer
    6 Feb 2009
    It gets very very cold at my house in the winter and I thought about making a system with an outdoor radiator but my worry was about condensation inside my case due to the high difference between the indoor ambient and my working fluid.
    Have you ever had issues with this?
  17. l3p
    l3p www.^.nl
    1 Nov 2010
    Nope, the fittings do feel very cold, but never had any condensation.
    I think that'll occur when having watertemps below 5 degrees.
    The lowest water temperature in the winter i saw was 14 degrees.
    The highest water temperature i was in summer was 23 degrees.
    The indoor ambient temperature is in summer and winter around 22 degrees.
  18. l3p
    l3p www.^.nl
    1 Nov 2010
    Received a nice UV led board today.
    It's specially for making photo's from UV-active parts.
    You can only use it for 5 minutes per time, else it gets too hot :)
    Small surprise between the UV leds :)
    And some pictures with the effect
  19. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    This is awesome, can't wait to see it powdercoated.
    Isn't having UV LEDs shining at all you all the time unhealthy? I have this image of you wearing suncream just to surf the web...
  20. -Jv-
    -Jv- What's a Dremel?
    29 Mar 2011
    Don't LED's have a great advantage because they don't get hot... ?
    Looks smexy, as usual :)
