Scratch Build – Complete Project: L3p D3sk - Bit-Tech Mod Of The Year 2011 Winner.
Discussion in 'Project Logs' started by l3p, 1 Nov 2010.
  1. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    what war?
  2. l3p
    l3p www.^.nl
    1 Nov 2010
    :naughty:
  3. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Whaha :D!
  4. l3p
    l3p www.^.nl
    1 Nov 2010
    Made some time free to give a little update.
    Still got a lot to do this weekend to be able to update from my main pc :)
    I knew i could get it smaller ! :p
    First leds are working.
    Also some cables ready for under the mainboard tray.
    Further on with the pump-tray and got the reservoir hanging again.
    Used the same anti vibration rubber under my HDD's and tray as i use for my glass.
    I really love this stuff.
    Guess cable management will come later, more and more cables every day :)
    Also a small uv led stroke for the right side fans.
    Now also leds in the pumptops.
    I like it more then the regular black ones i had.
    This photo is with UV leds in it, but thats WAY too purple.
    But somehow i cant show it in photo's
    So i tried blue leds after that, and i liked it :)
    Next update tomorrow :)
  5. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Hm, just wondering why you didn't get the Phobya nickel plated tops for the D5 pumps?
  6. l3p
    l3p www.^.nl
    1 Nov 2010
    I thought about them, but when i started this project i had more nickel plated stuff in it.
    But somehow the plexi blocks with Acid green fluid and a mix of blue and UV leds looks great for me ^^
  7. Nutman
    21 Oct 2008
  8. l3p
    l3p www.^.nl
    1 Nov 2010
    Took me a full hour to find the combination so i can use 2 SLI pipes for the right pump :p
    Molex plugs on the leds of the mainboard
    So ill be busy the rest of the day connecting all these cables :)
  9. l3p
    l3p www.^.nl
    1 Nov 2010
    What a long week this was :)
    Custom length BP pipes
    Bottom also finished.
    Time to fill up :p
    Just had to make some pictures.
    Back to getting the system up and running :)
    So the rubbers for the glass.
    First "backplate" in it's place.
    Now find a way to work away the cables for 3 screens.
    Wow second boot it was up and running.
    I really was happy with this.
    And im so glad i was able to disable the red leds of the Killer 2100 by the software.
    And some pictures of last night.
    This morning went up early again and it was smiling to me :)
    Also very handy those usb connections on Dells
    And some more night pictures.
    Still some small stuff to do.
    Polishing the deskholder and the l3p logo.
    And some cables need to be changed.
    After that ill borrow a better cam and make some better photo's.
    RonanH, jeckulz, k.3nny and 3 others like this.
  10. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Hat off to you mate.
    This thing should get a mag feature IMO
    Top work, seriously epic.
    Im a VERY jealous man
  11. [ZiiP] NaloaC
    [ZiiP] NaloaC Multimodder
    9 May 2008
    Incredible work dude! Congratulations :thumb:
  12. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Great stuff - best desk I've ever seen for sure!
  13. Nutman
    21 Oct 2008
    Lol, +1 rep for the wine glass with the green cooling fluid ;)
  14. The boy 4rm oz
    10 Apr 2008
    Fantastic, just amazing work. Congrats on the job well done mate. +rep
  15. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    Verry well done mate :)
    Wineglass is just a good picture :D! Deffn +1repp for u sir :)
  16. Nutman
    21 Oct 2008
    Is the mobo overclockable from the ROG app seen on your smartphone???
  17. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    yes, Its an android aplication :)
  18. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks a lot all !
    Haha, i even almost drinked out of it by accident :blush:
    Yes it is, you can OC and see all the mainboard info like temps, voltages and rpm's
    Google for this file: RCBluetooth_V108_Android
    dark_avenger, Stem83 and Bufo802 like this.
  19. Bufo802
    Bufo802 Minimodder
    28 Jul 2008
    Looks incredible, definitely worth the 6 months of work. Also + rep for somehow hiding away all those wires - hopefully some day I'll be able to build a desk computer and I'd be pleased if it looked half as good as this.
  20. PureSilver
    16 Dec 2008
    To finish it all off, you now need the LCD panels from Phillips' 58" 21:9 Cinema display, which are about the size of your desk space. Put them under the desktop glass, and show little performance graphs over each relevant component!
