Case Mod - Complete Project: L3p L4n - Mod Of The Year 2012 Nominee.
Discussion in 'Project Logs' started by l3p, 26 Jun 2011.
  1. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Go hard chrome, it'll be easier to keep up. Nickel can tarnish as well, and it's another layer to make sure there are no impingement corrosion issues. (They found impingement corrosion was an issue in some of the EK failures, though it wasn't the entire issue.)
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
    :lol: I missed this yesterday, at last :clap: a beauty is born. :)
    Bet your face was something like this while unpacking it all, I know mine would have been.
  3. Dragulax99
    Dragulax99 What's a Dremel?
    9 Apr 2012
    love those tools ...:thumb:
  4. Phyonics
    Phyonics What's a Dremel?
    4 Oct 2011
    The block is so stunning that I almost wet myself :jawdrop:
  5. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    get it mounted already ....
  6. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    just went through the whole log and wow amazing work on the custom block and the overall build. :)
  7. l3p
    l3p www.^.nl
    1 Nov 2010
    So do I Sir :)
    Thanks for the advise KayinBlack! (And the PM's :) )
    Would you believe me if I said I was too scared to unpack? :p
    Thanks Waynio!
    Thanks a lot guys!
    Maybe later :D
    Thanks a lot m8! :thumb:
  8. l3p
    l3p www.^.nl
    1 Nov 2010
    Copper part has been sent to the nickel plater.
    So curious how it will look! :)
    Meantime.
    Highflow sent me 3 'Cpu lapping kits' to try polishing the POM part.
    (Hopefully this will succeed :) )
    Thanks Freddy!
    I was looking for O-rings for a while to seal the block.
    Luckily Skiryl had some left from a previous project! :)
    The 'Inspired by' logo was grey anodised aluminum.
    Now I think it should look like the nickel and fittings.
    So lets polish :)
    When I got an hour left next week I will polish the last scratches out.
  9. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    Omg Peter!
    Omg omg omg! That solves my oring-search!
    Where did you get this and is there 1mm-1,3mm thick orings ?
    One problem thow, how will that oring hold from the presure then ?
    I have heard some baad thing with custommade oring thow :/
    Edit:
    I found exactly what i was searching for !
  10. Waynio
    Waynio Relaxing
    20 Aug 2009
    I can believe that :D was it fear of it not being in ok shape or not fitting the GPU like a glove like it does?. :D
    Was some really good teamwork between you & mr3d & quepee, you for measuring everything right & choosing to keep something Asus ROG about it without the need for words, mr3d for inputting the right dimensions in the design & making it that bit more awesome & quepee for doing an excellent job of the machining, very good stuff showing absolutely no compromise. :D:clap:
    Awesome :D look forward to seeing it, should be amazing. :)
    How do you fix the o ring together perfectly when you have it cut to spec?.
  11. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    i'm slightly saddened by the loss of the coppery glory. could it not have been sealed with a clear coat of lacquer? however if all the fittings are also nickel, it would be slightly out of place. i just get a bit of pants-tent for copper;)
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    :lol::D But I agree it would have looked sweet if all the other parts was nicely finished copper also but with most the other parts being nickel plated it will look right. :)
  13. l3p
    l3p www.^.nl
    1 Nov 2010
    Answered you PM on FB, guess you found something? :)
    Well I got no clue how it will hold lol, it's my first WB too :blush:
    I actually got no clue :blush:
    When I got the package I just had it packed on the table for 2 hours, when I unpacked it I just stared at it for half an hour while drinking coffee ... really weird :)
    You mean when you place the O-ring on one side and getting the other half on it?
    Place the beginning of the O-ring (Maybe with some water), then just shove the part over the other part in the length.
    I do like (polished) copper like any watercooling enthusiast here, however I just have to go with the color scheme :D
    I'm actually nickel plating it so I know the copper will always be shining behind that layer :D:D
  14. bulldogjeff
    2 Mar 2010
    I'm loving this build, so many amazing one off parts and it going to be another epic. can't wait to see it all going together.
  15. The_Crapman
    5 Dec 2011
    I have 3 of these arriving at work this week.
    i may have to take a change of underwear.....
    like a magpie, i'm a fan of all things shiny and i'm sure it will look phenominominomal. pure modding pron!
  16. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    you sent it to the platers without going with it ... you had it and you let it go! ;)
    a hard task to let it out of your sights !
    Sure it will look great when jobs done.
  17. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks bulldogjeff!
    There are parts in this build I will also do once in my life :D
    Yes I'm some how addicted to bling bling too. Maybe I was a crow in a previous life :thumb:
    Always thought about doing a copper build, never did it. GO Crapman :)
    I'm totally satisfied with the result RedManc. It seriously was hard to send it away again :D
    Sorry, just a teaser this time ;)
    Need some more time for testing/fitting.
    Already had to adjust the backplate 'a bit' cause of a small miscalculation.
    Very glad I decided to nickelplate it :D
  18. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Ooooohhh! Pretty!
  19. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Holy mackrell!!
  20. KoSoVaR^
    19 Dec 2010
    Ohhhh my gooood ! Give us more and dont tease us !
