Case Mod - Complete Project: L3p L4n - Mod Of The Year 2012 Nominee.
Discussion in 'Project Logs' started by l3p, 26 Jun 2011.
  1. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks!
    Lol, maybe we should create a diamond WC block sicne that has some kind of thermal conductivity :D
  2. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    Hmm... Lets brainstorm here, what is the thermal conductivity of diamond compared to copper:D
    And how do we find a tap that can tap the G1/4 holes:p
  3. l3p
    l3p www.^.nl
    1 Nov 2010
    Ordered something last week i could really use today :)
    First some holes for the buttons of the pump/fan controller.
    Tape so it won't move.
    And some holes with 3.5mm.
    Wow, it fits :)
    Sanded the frame so i can paint it.
    Oops almost forgot i also had to paint the edge where the plexi goes.
    Glued the plexi.
    Bitspower fanguards back in after the paintjob.
    And some glue.
    Rub it in with a wet finger.
    Believe me this glue doesn't let go :)
    Next problem, what to do with this..
    Ah we'll see :)
    Hmm... needs more cutting.
    Losing the sharp edges and create some nice roundings.
    Paint it black.
    Also glued the frame for the pump/fan controller.
    Second part of the ex-5.25" slot.
    Let's stick the Dremel in there too.
    (Not easy to hold a Dremel in one hand and a cam in the other :) )
    And more polishing.
    Making it rough so i can paint it.
    And some fitting.
    Painted.
    Lots of work for something you hardly see back, but im satisfied for today.
    Time for BBQ! :p
    Marcos_Viegas likes this.
  4. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    Nice - but won't you see the glue trough those grills?
  5. Drysofar
    Drysofar What's a Dremel?
    5 Nov 2006
    Would be good, Diamond is 2 to 6 times a better conductor of heat than copper, bitch to mill though.. Maybe you could grow it :)
  6. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks and nope, you can't see it, i'll make some detailed photo's soon for you ;)
  7. Nutman
    21 Oct 2008
    Yup. You can. ;)
  8. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    good work in progses dude!, i cant whait to put my hands into my build :D!, the case has finally arrived and om my birthday too :D!
  9. rayson
    rayson Damn sure it was legal
    23 Jul 2010
    beautiful
  10. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks guys!
    Kosovar, let me know when you've got it :)
  11. KoSoVaR^
    19 Dec 2010
    I have got it today on my bithday amd a pacage from bitspower aswell :D. what a epic day :D!!!!
  12. l3p
    l3p www.^.nl
    1 Nov 2010
    Congratulations m8!
  13. KoSoVaR^
    19 Dec 2010
    hehe thanks dude :D!, i will make an update later, will pst when on fb :)
  14. Fuganater
    Fuganater What's a Dremel?
    6 Jul 2011
    Good work so far l3p. Can't wait for the next update!
  15. l3p
    l3p www.^.nl
    1 Nov 2010
    Assembled the case again this week
    Quite some work cause of the lcd screen
    After that tested if the Velcro would work out.
    Works great, i think it can hold me too :p
    Pulling it off again wasn't that easy :)
    Placed the other stuff again too.
    Don't want too much lights on the outside, i like it this way.
    Maybe some red glow from the bottom...
    Maybe the top casewindow will be blood red plexi too.
    Here an airflowtest with the new fanholes.
  16. Attila
    Attila still thinking....
    22 Feb 2008
    Well, I never would have thought of velcro to hold the radiator. Great idea. And nice work all round. :thumb:
  17. l3p
    l3p www.^.nl
    1 Nov 2010
    Thanks Attila :lol:
    I will probably start a scratch build again after seeing your latest work :)
  18. KoSoVaR^
    19 Dec 2010
    why velcro on such a serious build mate :O, i dont think it will hold with all the water in place :/
  19. l3p
    l3p www.^.nl
    1 Nov 2010
    Venhar, don't worry, the velcro doesn't have to hold the rads weight, just to hold it on it's place.
    The rad itself wil be standing on a few layers of rubber tape. :)
  20. KoSoVaR^
    19 Dec 2010
    ahaa i see :D! great thought and great idea!
