Project : La veuve noire, 26th october, major update
Discussion in 'Project Logs' started by Shinuza, 15 Oct 2005.
  1. Shinuza
    Shinuza What's a Dremel?
    13 Oct 2005
    Hello all
    So this is the result of watching all beautiful casemods : making my own project.
    The project is based on a Lian Li PC7 B, some photos :
    This case is pretty simple, but sophisticated, the project is the meaning of Black Widow in French.
    Let's Go :
    My rig will by composed by :
    DFI NF4 Ultra D
    1gb Gskill GBLA
    AMD 3000+ Winchester
    Maxtor 80 Go
    Seagate 160 Go
    Leadtek Nvidia 6600 Gt
    Thermalright Xp 120
    This will be full Air cooled for now, but my phase change cooling will be operational in some days.
    The complete rig
    My PSU, 14cm fan
    24 pin
    Shiny :blush:
    It's bigger than my previous PSU
    Let's mount it
    It's big but silent, this psu need cable sleeving :duh:
  2. Shinuza
    13 Oct 2005
    Silent Rack
    Before the PSU, I will make some job on the HDD rack. I've mounted it a first time, and it's very noisy. So here is how I do it.
    I think this part is useless, and it allow vibrations so...
    I drill the rivets that hold the rack.
    It's clean, and now I can choose how to fix the rack.
    I use plastic separator.
    This is the SATA cable :
    Test fitting, look nice, and simple, I use only one cable for both HDD.
    Notice the holes I've drill, and look at the following.
    Drill, drill, and drill.
    Bolts and plastic separator, I hope this will absorb noise, and vibrations.
    Fitting, nice (sorry for dust, and poor quality picture)
  3. Shinuza
    13 Oct 2005
    Fan cable sleeving and chair mounting
    I will sleeve the fan cable as I'll do for every fan and cable in my case :
    This part is very useful, and I'll use it :D
    I've received that
    Perfect chair, with wheel, and height ajustable :D
    Next steps are :
    -Graphic card silencing
    -Cd Rom hidding
    -Window cutting
    -Many more things
  4. Shinuza
    13 Oct 2005
  5. Lemur 6
    Lemur 6 What's a Dremel?
    15 Mar 2005
    Uh... are you drilling and making aluminum dust while your mobo is installed? Might want to.... uh... not do that...
    But other than that, looks nice so far.
    -Lemur 6
  6. Shinuza
    13 Oct 2005
    I fact, not, I've made this shot after completing the drilling and re-installing the mobo, I were not really drilling at this moment. I know doing this could put some aluminium on the mobo, and fry it :duh:. I don't think drill and shot can be at the same time.
  7. Confused Fishcake
    Confused Fishcake Minimodder
    25 Sep 2005
    That's going to look really professional when done, you planning on lights?
  8. serial_
    serial_ What's a Dremel?
    11 Oct 2005
    Bon, Shinuza, qu-est-que je peux dire? C'est très bon, et je pense que, avec quelque modifications que tu peux faire une chose extraordinaire.
    J'aime noir, alors un project comme ça est un qui est... exactement que je voudrais.
    Meme que avec toi et l'anglais, le francais n'est pas ma langue maternelle, mais je l'apprend pendant deux an que j'ai passé en Haiti. Alors, si il-y-a des erreurs, j'suis desolé.
    Mais felicitations de quoi t'as à l'instant.
    - serial_
  9. Shinuza
    13 Oct 2005
    Graphic Card Silencing
    My 6600 is noisy, very noisy. So I've bought a Zalman VF700 CU
    And today, I've installed it.
    This is temp i've got before installation
    The card with stock fan
    VF-700
    Nakedness, very hot :jawdrop:
    Packaging, very complete, it also include thermal paste.
    Heatsink installation, very easy, you just to tear off a sheet of paper, and stick it to the chip.
    Here it is, total operation time : 10 minutes
    This is great, but...
    ... this is better!
    And this is pretty much better :thumb: :clap:
    The packaging included this, but I won't switch every time from **chilling on Bit-tech's forum** configuration to **Playing a FPS with loud sound** (as so my mother can become crazy :D ) configuration.
    So switch is the word, and I'll use a switch, easy to reach, but hidden. More to come :dremel:
  10. Shinuza
    13 Oct 2005
    Lights yeah, I mean not, a complete night club, this project is dedicated to sophitication and pratical stuffs. I want it as something silent, but efficient (overclocking) and beautiful, but not extravagant.
    Thanks for comments, you french is very good, way much better than my english I think. I have many more than 2 years studying english... :D
    A plus tard :hip:
    For next I will, overclock the Graphic card, and work on a switch for gaming to working and reverse.
    If someone now if I can return 5v input to 12v ground without damaging my PSU...
    Thanks
    Au revoir
    Shinuza San
  11. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    Nice work Shinuza, welcome to the forums :clap:
  12. Shinuza
    13 Oct 2005
    Thanks, glad to see you like it! :p
    I promise bigger MODifications in the next days. I've to do :
    -Graphics card 5v/12v switch and integration
    -Optical Drives hidding, and open buttons moving and integration
    -many many things... :idea:, but this is what I've in my mind right now.
  13. Shinuza
    13 Oct 2005
    Sleeving & Electronics
    Hi, a little update here.
    Some sleeving action :
    My tools
    How to unmount the 3 pins connector.
    All finished, this fan will come in front of my case, right behind the HDD.
    Now we'll attack the 5v/12v switch.
    I take two 4 pins to 3 pins stuffs.
    Cut it, and then I take part that split the molex connectors in two part.
    Now I mount it back in the molex
    ... and start connect the whole stuff.
    This allow a fan to run on 5v or 12v.
    Sleeving again, this wire will be connected to the Graphic Card for Gaming/Working switching. :dremel:
    And now I test the placement of the wire for the graphic card, and I'm thinking of a fake floor.
    More to Come
    Comments apreciated :
    http://forums.bit-tech.net/showthread.php?t=100091
    Shinuza San
  14. kiljoi
    kiljoi I *am* a computer king.
    13 Oct 2003
    Looks very good so far, I like it a lot. You do good sleeving. That vga cooler really made that much of a differnce? Hrm, I might get one of those.
  15. Shinuza
    13 Oct 2005
    Graphic Card Overclocking
    Here's a little update, I'm working on it, but this is my current playable (12v switched :D ) frequencies. Stock are 500mhz/1ghz
    More to come tomorrow :dremel: :dremel:
  16. Shinuza
    13 Oct 2005
    Thank you mate.
    This vga cooler is pretty great, I win overclock too, about 59 mhz on the core and so for the memory, comparing to the stock fan. :thumb:
  17. Shinuza
    13 Oct 2005
    Major Update
    Hello, I'm back after a few days, but I'm pretty busy, with looking for a job, and a flat.
    Sorry for blurry pictures, but I borrow this camera sucks a lot :eyebrow:
    Let's start :
    I need to sleeve my front fan.
    With RCA
    Then Install it
    Here is a zoom on the fan bolt, I use a rubber ring.
    [Off topic]
    Dude, I just broke a glass
    [/Off topic]
    Now I drill a hole through the mobo plate, so I can install the female RCA connector.
    This female RCA is connected to the 12v line.
    Now installing the 5v/12v switch
    Now I drill a hole through the mobo plate, and make...
    Remember my 5v/12 switch.
    ...this pass through.
    Then I have to connect the switch to a molex connector.
    I drill the rear of the case, for insert the switch
    HDD cage
    Lian li give with his case a cable holder (?) which I stick on the side of this HDD cage.
    Here it is installed.
    Global view
    Here is a global view, I have a few cable on the floor, so the fake floor will be usefull.
    I still have to do : Side window stuff, DVD writer hidding, cable organisation
  18. frodo
    frodo What's a Dremel?
    1 Nov 2003
    btw, its better to put the rubber inbetween the stuff your trying to reduce vibrations with
    so it goes
    Bolt
    hdd holder
    rubber washer
    case
    nut
    but otherwise this mod looks kickass, very clean :)
  19. Shinuza
    13 Oct 2005
    Yop, thank you for comment, I will try your set up.
    Tommorow I will start cutting through then case, and in many way. :D
