Project Lament: HellRaiser Cenobite PC -=FINISHED=-
Discussion in 'Project Logs' started by ARTbyTROY, 24 Feb 2005.
  1. kennylovesyou
    kennylovesyou What's a Dremel?
    2 Sep 2004
    :eyebrow: kinky
    Im really impressed by these type of mods.. i admire your skills :)
  2. -Enforcer-5716M4
    -Enforcer-5716M4 What's a Dremel?
    1 Sep 2004
    It's spelled "dying"...
  3. -Enforcer-5716M4
    1 Sep 2004
    I know what you should do! You should make a couple of arms out of isopor, attach them to the manequin (I guess you understand where) and then hook them up with a couple of servos! Connect the servos to a switch, and you've got yourself a fully working evil-hellraiser-dude! :hip:
    For servos you should check out this site http://www.bpesolutions.com/product.html
    It's the same place that Crimson Sky gets his electronics!
  4. -Enforcer-5716M4
    1 Sep 2004
  5. RiPz
    RiPz What's a Dremel?
    12 Dec 2004
    i certainly wouldnt like that staring at me across my bedroom at night, looks too realistic :D
  6. ARTbyTROY
    ARTbyTROY Mod it Til it Bleeds!
    27 Jun 2002
    Almost all the leather work is finished, there are a couple of spots that I need to attach some Velcro, like the side section for the motherboard ports...
    I also need to Velcro the piece of leather that will wrap around the neck. Since the leather adds a layer of thickness to the cut-out parts of the torso I decided to run a final test fit of components, below is the shoulder mounted fill port and the handle.
    http://www.casemodgod.com/Hell116.jpg
    The abdomen and chest sections are finished, all the hardware is installed and it lines up nicely.
    http://www.casemodgod.com/Hell117.jpg
    I did a test install of the PSU, HDD (with WC block), radiator (without the fan) and the motherboard tray.
    http://www.casemodgod.com/Hell118.jpg
    Here is a shot of the back. I used a plastic mesh to cover the area on the bottom where the pump will be installed to allow easy access to the pump and fittings if needed, it blends in well.
    Next I will begin work on the arms, when the size 6 ladies leather pants arrive I will use those to cover the arms.
  7. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    The handle in the 'neck' is soo good man. People will be looking for you in the lanparties and in the metro if you carry that thing there. Anyways, excellent work. Oh btw, isn't Hellraiser the ex mascot of maidens, or am I just mistaken with the name?
  8. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    beautyfull work man. the face got brilliant.
  9. Peddro
    Peddro What's a Dremel?
    21 Feb 2005
    excelent work, never seen it before... very special and unique! :clap:
  10. (X)TORNADO(X)
    (X)TORNADO(X) What's a Dremel?
    26 Feb 2005
    Unigue and wonderful work... Where did you get your idea for this...
  11. zr_ox
    zr_ox Whooolapoook
    5 Jan 2005
    :jawdrop:
    Thats looks fantastic, really nice work especially the head cant wait to see the dark shots
  12. ARTbyTROY
    27 Jun 2002
    I watch a lot of horror movies, so I am fairly familiar with them. I was at work thinking about the HellRaiser movies and how they have gone downhill since the second one. The third film "Hell on Earth" had cenobites that were created using their surroundings and seemed like their malformities were job related, ie. the DJ cenobite had CDs popping out of his head, the cameraman cenobite had a Borgish camera lens for an eye, the bartender cenobite had a drink shaker etc.
    That little bit of idiocy really got me thinking... what would happen if the cenobites came for a case modder? After thinking about that question for a few days I wrote a short story about it... after that I knew that I had to build it.
  13. Balder
    Balder Calmer than a monk on morphine
    4 Jul 2003
    It looks realy realy nice, and scary....
    No thats eddie or eddy, the mummy :)
  14. ARTbyTROY
    27 Jun 2002
    It isn't Eddie from Iron Maiden, thought there would be nothing wrong with it to me if it were... Iron Maiden rocks old school. Maybe there are some similarities, but Eddie definitely has his own look...
  15. Isuo
    13 Oct 2004
    Ok, thanks for correcting.
    Btw, when is your next update coming?
  16. ARTbyTROY
    27 Jun 2002
    I installed four red LED rocker switches onto the shoulder blades to control the lighting mods.
    To begin making arms I first drew and cut out a template to trace onto the scrap aluminum from the top window on MOBY2... never throw good scraps away.
    http://www.casemodgod.com/Hell121.jpg
    I cut them out with a Dremel and filed them smooth, next I puzzled together some hardware so that they can attach to the torso.
    http://www.casemodgod.com/Hell122.jpg
    Below is a test fit, everything lines up good and feels solid.
    I removed the base from both Viewsonic speakers then cut and drilled four strips of flat Alum-Angle to hold them in place.
    http://www.casemodgod.com/Hell124_copy.jpg
    Here is a parting shot of both speakers installed, not too shabby considering I built the assemblies on the fly with no real plan.
  17. deadly-app
    deadly-app What's a Dremel?
    9 Mar 2004
    are the speakers going to be hidden? as it is it looks pretty roughshod :|
  18. ARTbyTROY
    27 Jun 2002
    Of couse they will be hidden, they don't really fit the theme as-is. I was just updating the work log, not posting anything final.
  19. deadly-app
    9 Mar 2004
    ok good, thats what i thought, but i couldnt tell if that was permanent or not :)
  20. blknoel
    blknoel What's a Dremel?
    14 Jun 2004
    Now thats some serious modding, original ! :)
    Not really to my taste cuz I dun fancy integrating machines into humanoid figure, but definitely impressive :D
    Mod on ! :thumb:
